ahmad
Sun, Jul 23, 2017 9:45 PM
I am new to openscad. I want to project a 3d object into 2d. I used this:
projection() import(filename);
My input file(zipped stl) is attached. The projection has a very low
accuracy. Am I missing something?
P.S: I used the scale([1,1,0]) instead of projection, and it worked pretty
well. but I know the output of scale is still a 3D object. I need 2D.
Sun, Jul 23, 2017 10:01 PM
There is a bug in OpenSCAD with tiny 2D objects. Scaling up the import,
doing the projection and scaling it down again will probably work.
Sun, Jul 23, 2017 10:16 PM
I scaled it by 1000 in netFabb and it looked much better.
Also the object is not flat(~45degrees in XY), is that why you are doing the
projection?
View this message in context: http://forum.openscad.org/problem-with-accuracy-of-projection-tp21916p21918.html
projection?
ahmad
Sun, Jul 23, 2017 10:19 PM
No. I want to convert it to 2D, and then generate dxf file.
On Sun, Jul 23, 2017 at 3:16 PM, MichaelAtOz oz.at.michael@gmail.com
projection?
On Sun, Jul 23, 2017 at 3:16 PM, MichaelAtOz <oz.at.michael@gmail.com>
> the
> projection?
> Admin - PM me if you need anything, or if I've done something stupid...
> Unless specifically shown otherwise above, my contribution is in the
> Public Domain; to the extent possible under law, I have waived all
> copyright and related or neighbouring rights to this work. Obviously
> inclusion of works of previous authors is not included in the above.
F
fred
Sun, Jul 23, 2017 10:25 PM
Just a wild guess here, but do you know that when you render the model (F6), it will become 2D?
On Sunday, July 23, 2017, 6:20:59 PM EDT, ahmad ahmad.razavi@gmail.com wrote:
projection?
View this message in context: http://forum.openscad.org/ problem-with-accuracy-of- projection-tp21916p21918.html
http://lists.openscad.org/ mailman/listinfo/discuss_ lists.openscad.org
On Sunday, July 23, 2017, 6:20:59 PM EDT, ahmad <ahmad.razavi@gmail.com> wrote:
On Sun, Jul 23, 2017 at 3:16 PM, MichaelAtOz <oz.at.michael@gmail.com> wrote:
projection?
______________________________ _________________
HJ
Hugo Jackson
Sun, Jul 23, 2017 10:26 PM
Right, so do the following….
scale([1/500,1/500])
projection()
scale([500,500,1])
import(filename);
Then export it as a dxf file.
Note that the scaling of [1/500,1/500] only operates on two of the vertices so it preserves the 2 dimensional projection.
On Sun, Jul 23, 2017 at 3:16 PM, MichaelAtOz <oz.at.michael@gmail.com mailto:oz.at.michael@gmail.com> wrote:
projection?
View this message in context: http://forum.openscad.org/problem-with-accuracy-of-projection-tp21916p21918.html http://forum.openscad.org/problem-with-accuracy-of-projection-tp21916p21918.html
projection()
scale([500,500,1])
import(filename);
> On Sun, Jul 23, 2017 at 3:16 PM, MichaelAtOz <oz.at.michael@gmail.com <mailto:oz.at.michael@gmail.com>> wrote:
> projection?
> Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above.
> The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ <http://www.ourfairdeal.org/> time is running out!
> View this message in context: http://forum.openscad.org/problem-with-accuracy-of-projection-tp21916p21918.html <http://forum.openscad.org/problem-with-accuracy-of-projection-tp21916p21918.html>
> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org>
ahmad
Sun, Jul 23, 2017 10:29 PM
worked pretty well. but I am not sure how much I have to scale up an object
to resolve the problem.
projection()
scale([500,500,1])
import(filename);
projection?
> projection()
> scale([500,500,1])
> import(filename);
>> the
>> projection?
HJ
Hugo Jackson
Sun, Jul 23, 2017 10:38 PM
Well that would all depend on what your end use is I suppose. I mean, the current size of the object is so tiny its not like you’d be getting worthwhile results on a 3D FFM printer.
It’s a little like adjusting the $fa, $fs and $fn values… it all depends on what you’re using it for.
If you’re doing a lot of this kind of thing, you could write a general purpose module that could (for example) take a scaling factor from the current value of say $fn. something like this….
module dxf_prepare() {
scaleFactor = $fn * 50;
scale([1/scaleFactor, 1/scaleFactor])
projection()
scale([scaleFactor, scaleFactor, 1])
then you could do what you require with:
dxf_prepare()
import(filename);
and then adjust $fn to give you the results you want, either globally…
$fn = 50;
dxf_prepare()
import(filename);
or just for the module call:
dxf_prepare($fn = 50)
import(filename);
On Jul 23, 2017, at 3:29 PM, ahmad ahmad.razavi@gmail.com wrote:
worked pretty well. but I am not sure how much I have to scale up an object to resolve the problem.
On Sun, Jul 23, 2017 at 3:26 PM, Hugo Jackson <hugo@apres.net mailto:hugo@apres.net> wrote:
projection()
scale([500,500,1])
import(filename);
On Jul 23, 2017, at 3:19 PM, ahmad <ahmad.razavi@gmail.com mailto:ahmad.razavi@gmail.com> wrote:
projection?
Sent from the OpenSCAD mailing list archive at Nabble.com http://nabble.com/.
projection()
dxf_prepare()
import(filename);
$fn = 50;
dxf_prepare()
import(filename);
import(filename);
> On Sun, Jul 23, 2017 at 3:26 PM, Hugo Jackson <hugo@apres.net <mailto:hugo@apres.net>> wrote:
> projection()
> scale([500,500,1])
> import(filename);
>> On Jul 23, 2017, at 3:19 PM, ahmad <ahmad.razavi@gmail.com <mailto:ahmad.razavi@gmail.com>> wrote:
>> projection?
>> Sent from the OpenSCAD mailing list archive at Nabble.com <http://nabble.com/>.
Sun, Jul 23, 2017 10:45 PM
It depends what you want to do with it.
While stl files are technically unit-less, most tools presume mm.
The 4.stl is 0.12 0.13 x 0.09 mm, so sending that to a typical machine
(CNC, laser cutter etc), is not going to be useful.
So if the item is meant to be 12 x 13 cm then scale(1000) etc.
View this message in context: http://forum.openscad.org/problem-with-accuracy-of-projection-tp21916p21924.html
