Belfry OpenScad Library v2 (BOSL2)
Jan Öhman
Wed, Mar 23, 2022 10:59 PM
Hi!Want to test the library BOSL2 - but i'm not sure if it works as desire.
Home · revarbat/BOSL2 Wiki
The Belfry OpenScad Library, v2.0. An OpenSCAD library of shapes, masks, and manipulators to make working with ...
  1. I downloaded the zip file(https://github.com/revarbat/BOSL2 and selected "<> Code" and the green button "Code" and "Download ZIP")
    the file .: BOSL2-master.zip is downloaded.
  2. Then unzip the file to .: "openSCAD\BOSL2-master"
    Many files and directories are created.
3) Renamed the unpacked main directory (BOSL2-master) to BOSL2
4) Moved the the "BOSL2" directory to "MyDocuments\OpenSCAD\libraries\BOSL2"
So far, I think I have done the right way.
But all BOSL2 examples do not seem to work. One example is .:
"....\OpenSCAD\libraries\BOSL2\examples\boolean_geometry.scad"
This code below gives the following warning .: WARNING: Can't open include file 'BOSL2/debug.scad'
Yes, debug.scad is missing (I have no idea what this file adds)
include <BOSL2/std.scad>include <BOSL2/debug.scad>
$fn = 36;
rgn1 = [    square(100),    move([50,50], p=circle(d=60)),    [[35,35],[35,65],[65,65]]];
rgn2 = [    [[0,0], [100,100], [100,0]],    [[27,10], [90,73], [90,10]],    move([70,30], p=circle(d=25))];
polycolor=[0.5,1,0.5];outlinecolor="black";
module showit(label, rgn, poly=polycolor, outline=outlinecolor, width=0.5) {    move([-50,-50]) {        if(outline) color(outline) linear_extrude(height=max(0.1,1-width)) for(path=rgn) stroke(path, width=width, closed=true);        if(poly) color(poly) linear_extrude(height=0.1) region(rgn);        color("black") right(50) fwd(7) linear_extrude(height=0.1) text(text=label, size=8, halign="center", valign="center");    }}
ydistribute(-125) {    xdistribute(120) {        showit("Region A", rgn1, poly=[1,0,0,0.5]);        showit("Region B", rgn2, poly=[0,0,1,0.5]);        union() {            showit("A and B Overlaid", rgn1, poly=[1,0,0,0.5]);            showit("", rgn2, poly=[0,0,1,0.5]);        }    }    xdistribute(120) {        showit("Union A+B", union(rgn1, rgn2));        showit("Difference A-B", difference(rgn1, rgn2));        showit("Intersection A&B", intersection(rgn1, rgn2));        showit("Exclusive OR A^B", exclusive_or(rgn1, rgn2));    }}
// vim: expandtab tabstop=4 shiftwidth=4 softtabstop=4 nowrap
  • . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ .
    No file in the test directory works (but you may have to do something for these files to produce something? - or...)
    No error messages are displayed either.
Hi!Want to test the library BOSL2 - but i'm not sure if it works as desire. Home · revarbat/BOSL2 Wiki | | | | | | | | | | | Home · revarbat/BOSL2 Wiki The Belfry OpenScad Library, v2.0. An OpenSCAD library of shapes, masks, and manipulators to make working with ... | | | 1) I downloaded the zip file(https://github.com/revarbat/BOSL2 and selected "<> Code" and the green button "Code" and "Download ZIP") the file .: BOSL2-master.zip is downloaded. 2) Then unzip the file to .: "openSCAD\BOSL2-master" Many files and directories are created. 3) Renamed the unpacked main directory (BOSL2-master) to BOSL2 4) Moved the the "BOSL2" directory to "MyDocuments\OpenSCAD\libraries\BOSL2" So far, I think I have done the right way. But all BOSL2 examples do not seem to work. One example is .: "....\OpenSCAD\libraries\BOSL2\examples\boolean_geometry.scad" This code below gives the following warning .: WARNING: Can't open include file 'BOSL2/debug.scad' Yes, debug.scad is missing (I have no idea what this file adds) include <BOSL2/std.scad>include <BOSL2/debug.scad> $fn = 36; rgn1 = [    square(100),    move([50,50], p=circle(d=60)),    [[35,35],[35,65],[65,65]]]; rgn2 = [    [[0,0], [100,100], [100,0]],    [[27,10], [90,73], [90,10]],    move([70,30], p=circle(d=25))]; polycolor=[0.5,1,0.5];outlinecolor="black"; module showit(label, rgn, poly=polycolor, outline=outlinecolor, width=0.5) {    move([-50,-50]) {        if(outline) color(outline) linear_extrude(height=max(0.1,1-width)) for(path=rgn) stroke(path, width=width, closed=true);        if(poly) color(poly) linear_extrude(height=0.1) region(rgn);        color("black") right(50) fwd(7) linear_extrude(height=0.1) text(text=label, size=8, halign="center", valign="center");    }} ydistribute(-125) {    xdistribute(120) {        showit("Region A", rgn1, poly=[1,0,0,0.5]);        showit("Region B", rgn2, poly=[0,0,1,0.5]);        union() {            showit("A and B Overlaid", rgn1, poly=[1,0,0,0.5]);            showit("", rgn2, poly=[0,0,1,0.5]);        }    }    xdistribute(120) {        showit("Union A+B", union(rgn1, rgn2));        showit("Difference A-B", difference(rgn1, rgn2));        showit("Intersection A&B", intersection(rgn1, rgn2));        showit("Exclusive OR A^B", exclusive_or(rgn1, rgn2));    }} // vim: expandtab tabstop=4 shiftwidth=4 softtabstop=4 nowrap - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ . - . _ .  No file in the test directory works (but you may have to do something for these files to produce something? - or...) No error messages are displayed either.
