Hello,
I'm back to doing chamfering inside OpenSCAD after playing a bit with doing
the chamfering/filleting as a second step manually in Blender. That got
tiresome really quick. I've now read the BOSL2 docs a few times more and
maybe I understand it enough now to use :) My question is: there is a
chamfer_cylinder_mask(), but from what I can tell, not the 'hole
equivalent' of it, i.e. countersinking a hole. Say I have this:
How do I make a chamfer on the inside of the hole in a way that is as
convenient as chamfer_cylinder_mask, i.e. without constructing and
difference()'ing a cone manually? Thanks.
cheers
Roel
In BOSL2, you can chamfer a hole by just differencing away a cyl() with a negative chamfer size.
For example:
diff()
cyl(h=50, d=50, chamfer=5)
tag("remove") cyl(h=50.01, d=20, chamfer=-5);
or:
cyl(h=50, d=50, chamfer=5);
Both of which give the following:
On Mar 3, 2024, at 11:49 AM, Roel Vanhout via Discuss discuss@lists.openscad.org wrote:
Hello,
I'm back to doing chamfering inside OpenSCAD after playing a bit with doing the chamfering/filleting as a second step manually in Blender. That got tiresome really quick. I've now read the BOSL2 docs a few times more and maybe I understand it enough now to use :) My question is: there is a chamfer_cylinder_mask(), but from what I can tell, not the 'hole equivalent' of it, i.e. countersinking a hole. Say I have this:
<image.png>
How do I make a chamfer on the inside of the hole in a way that is as convenient as chamfer_cylinder_mask, i.e. without constructing and difference()'ing a cone manually? Thanks.
cheers
Roel
