On Thursday 12 August 2021 12:09:28 Ned Young via Discuss wrote:
Gene, I think the problem you're dealing with is intrinsically part of
FDM, and possibly other 3D printing methods as well. At root, the
technology is using an icing bag and attempting to achieve precision.
There are so many production-time variables that can affect the result
that it is impossible to solve the problem at design time.
I created test blocks in OpenSCAD for different fasteners. Through
holes, self-tapping holes, tapped holes, in several orientations.
Before beginning the design of an object, I run the test blocks
using exactly the same production parameters (temps, feeds,
materials, and yes, even color) to discover what values I need to
specify at design time to get the dimensions I need.
Well, I have since done an autopsy on the failed drive, and that has
given me the seeds of a better idea that wold be hard to assemble. I had
not used ball bearings on an arm, but an eccentric armature with 2
printed bearings wrapped around it to transfer the eccentricity needed
to the floating ring. The inner bearing races were too thin at the
bottom of the bearing groove, so it split at the bottom of the bearing
groove and chewed up the inner races. Everything else is dirty but 100%
OK and could theoretically be re-used.
Now I need to nap on the changes as they would make for a more difficult
assembly.. :o( Or make the armature smaller and give that room to the
bearing race. I like that idea better. But first, find and fix the
plastic leak. On a prusa, thats a major teardown. I had about a dozen bb
sized plastic balls loose on the build plate from the last print.
-Ed Howdershelt (Author)
of FDM, and possibly other 3D printing methods as well. At root,
the technology is using an icing bag and attempting to achieve
precision. There are so many production-time variables that can
affect the result that it is impossible to solve the problem at
design time.
had not used ball bearings on an arm, but an eccentric armature with 2
100% OK and could theoretically be re-used.
difficult assembly.. :o( Or make the armature smaller and give that
room to the bearing race. I like that idea better. But first, find and
fix the plastic leak. On a prusa, thats a major teardown. I had about
a dozen bb sized plastic balls loose on the build plate from the last
print.
Is anyone interested in what I found with the prusa and how I /think/
I've fixed it?
Cheers, Gene Heskett
