Hi.
It would be nice that:
1 - The animation should not start automatically when we start introducing
the frame rate. It should start after "Enter" key pressed or by pressing a
start button.
2 - An option for looping/no looping should exist. Useful specially if "Dump
Pictures" is checked.
3- In order to facilitate several animation sequences easily, a field should
exist for the sequence number and the .png name would have some of the most
significant digits allocated to that sequence number.
Thanks
jpmendes
View this message in context: http://forum.openscad.org/UI-animation-fields-operation-mode-request-tp16663.html
Ooops, one more:
In the preferences window it would be nice to have a field to define path
for the animation files dump.
Thanks
jpmendes
View this message in context: http://forum.openscad.org/UI-animation-fields-operation-mode-request-tp16663p16665.html
Related to #3, I filed Issue 1573 a little while ago requesting $frame, $frames and $fps for animate use/reference inside the code:
https://github.com/openscad/openscad/issues/1573 https://github.com/openscad/openscad/issues/1573
Andrew.
On Mar 22, 2016, at 2:54 PM, jpmendes jpmendes54@gmail.com wrote:
Hi.
start button.
Thanks
jpmendes
"The future is already here. It's just not very evenly distributed" -- William Gibson
Let me add one more request I think useful too:
Why not implementing an echof() a echo() to a log file? So one can decide
which changing parameters to record for analysis or for future use. For
example: constructing tables, record the changing of values during an
animation, etc. . I mean a file with only the contents that we decide to
record, not a replica of the console output.
jpmendes
View this message in context: http://forum.openscad.org/UI-animation-fields-operation-mode-request-tp16663p16672.html
