Sun, Nov 22, 2015 7:51 PM
Marius makes a good point that "native" plugins (using a C/C++ API) would
fragment the community, as most authors would not have the resources to
produce mac, windows and linux versions of their plugins.
My personal preference is to extend the OpenSCAD language so that it is
expressive enough to program advanced geometric shapes and operations, like
the generalized non-affine transform discussed earlier.
I have a roadmap for this, and it does include a more powerful language for
writing user defined functions, and direct access to the mesh.
On 22 November 2015 at 12:17, Parkinbot rudolf@parkinbot.com wrote:
@doug: such an interface is not meant to be redefined for each release,
and I
doubt it will have to at all, if it is well specified.
@Marius
user defined functions have a very limited foot print. As the OpenSCAD
syntax for functions is rather restrictive, and porting useful code to
OpenSCAD can be quite painful, the language could gain a lot from it.
object representation might be interfaced at a polyhedron basis. If the
polyhedron object allowed for a combined parameter like [points , faces],
e.g.
it even could be constructed by a user defined function as well.
object operators this is a more complex theme, as it requires to expose a
lot of information about internal representations. But I guess one could
easily expose a restricted interface for unary transform operators
operating
over sets of xyz-points as already suggested in the "nonlinear
transformations" thread.
kintel wrote
Now, if we were to support plugins, here are some ideas:
- DO NOT support native plugins. This will introduce huge requirements
authors to provide binaries for all supported platform, or splintering
user community by selectively making their plugin available only on
certain platforms.
- Limit the API to perform operations with a very limited exposed API
(e.g. implement user-defined functions/modules where the only API is how
to call and how to return values and shapes).
- Allow plugins to generate OpenSCAD code from a UI dialog (i.e. using
built-in QtScript to create dialogs) -> i.e. separate the plugin from the
language run-time.
- Use a plugin language which doesn’t require any OS-level infrastructure
installed; i.e. make the plugin language fully embedded.
Another request I get relatively often is for OpenSCAD to efficiently be
used with a different front-end language, allowing people to use one of
the wrappers/generators directly in the OpenSCAD GUI, alternatively, plug
the OpenSCAD viewer into their corresponding IDE or editor. Automatic
Reload covers most use-cases for this though.
> and I
> @Marius
> *user defined functions* have a very limited foot print. As the OpenSCAD
> *object representation* might be interfaced at a polyhedron basis. If the
> e.g.
> *object operators* this is a more complex theme, as it requires to expose a
> operating
> - Rudolf
> kintel wrote
> > Now, _if_ we were to support plugins, here are some ideas:
> > * DO NOT support native plugins. This will introduce huge requirements
> for
> the
> > certain platforms.
> > * Limit the API to perform operations with a very limited exposed API
> > * Allow plugins to generate OpenSCAD code from a UI dialog (i.e. using
> the
> > language run-time.
> > * Use a plugin language which doesn’t require any OS-level infrastructure
> > -Marius
> > OpenSCAD mailing list
> > Discuss@.openscad
> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
> View this message in context:
> http://forum.openscad.org/feature-request-plug-ins-tp14663p14700.html
Sun, Nov 22, 2015 8:19 PM
There is already direct access to the mesh with polyhedron. I.e. you
specify the mesh, not query it, as with everything in OpenSCAD. You use
maths to describe geometry, not the other way around.
Adding the ability to mix in other languages will be very fragmenting
because in order to use other people's code you will need to install and be
fluent in random computer languages. As it stands you only need to install
OpenSCAD and be fluent in that very simple language and maths to be able to
create any geometry.
for writing user defined functions, and direct access to the mesh.
and I
@Marius
e.g.
a
operating
certain platforms.
language run-time.
>> and I
>> @Marius
>> e.g.
>> a
>> operating
>> - Rudolf
>> for
>> the
>> > certain platforms.
>> the
>> the
>> > language run-time.
>> infrastructure
>> plug
>> > -Marius
>> > Discuss@.openscad
Sun, Nov 22, 2015 9:03 PM
Adding the ability to mix in other languages will be very fragmenting […]
Allowing mix-ins like that is indeed scary. My “plug-in” I was mostly thinking about ways of extending OpenSCAD by installing components exposing some API to the OpenSCAD language, keeping those two universes separated.
AC
Alan Cox
Sun, Nov 22, 2015 9:19 PM
Blender exports a python API. It allows a very low level access to the
data structures and meshes but being python is portable if you are
sensible.
Python is obviously rather slower than C but given the costs in OpenSCAD
are all elsewhere it's hardly going to matter for performance.
At that point though there is also pyscad which does things the other way
up and which is probably the right approach as it doesn't break the
functional nature of OpenSCAD or the parallising opportunities.
Alan
On Sun, 22 Nov 2015 14:51:55 -0500
sensible.
Alan
Sun, Nov 22, 2015 10:04 PM
for
Can you elaborate on that?
this would be more or less what I meant and already a large step towards
interop.
tp3 wrote
Plug-ins could cover other use cases, like prototyping new features
and implementing very special things.
You name it.
I'm afraid that branching out own experimental versions of OpenSCAD just to
test a new feature, is a bit too involving - especially if there is a lack
of documentation. A plug-in interface is much more charming.
nophead wrote
As it stands you only need to install OpenSCAD and be fluent in that very
simple language and maths to be able to create any geometry.
> for
interop.
You name it.
If it was like this, I wouldn't discuss.
Rudolf
View this message in context: http://forum.openscad.org/feature-request-plug-ins-tp14663p14705.html
Sun, Nov 22, 2015 10:27 PM
You name it.
Well, a plug-in documentation will also not write itself. And first
the plug-in API has to be designed and written too :-).
Hmm, still, maybe the "How to extend OpenSCAD" documentation could
use an external python call as example...
> You name it.
Mon, Nov 23, 2015 12:00 AM
"Python is obviously rather slower than C but given the costs in OpenSCAD
are all elsewhere it's hardly going to matter for performance."
Let's think about the performance issues more carefully.
Consider that, in the current architecture, this plugin API would need to
be invoked both during script evaluation, and also during CGAL rendering,
and I guess also preview. The generalized non-affine transformation
operator would have to be invoked during rendering, because only then is
the mesh available.
If we use Python, then we are invoking Python code in the middle of CGAL
rendering. We have to convert CGAL numeric objects (which are dynamically
allocated rational numbers) into Python numeric objects, run the plugin
code, then convert the Python numbers back into CGAL numbers. This isn't
cheap, as I suspect that operations on CGAL numbers are the bulk of the
cost of rendering.
We haven't implemented any of our ideas yet for speeding up rendering by
using multiple cores, or by using the GPU, although that has been discussed
a lot. If part of the rendering code is written in Python, this becomes
much more difficult.
sensible.
Alan
the mesh available.
cost of rendering.
> sensible.
> Alan
Mon, Nov 23, 2015 5:28 AM
At Parkinbot's request, here are some thoughts about the road ahead for
OpenSCAD:
- Make the core language more expressive and powerful. My current
proposal for this is OpenSCAD2 https://github.com/doug-moen/openscad2.
- Make rendering much faster, so that it is as fast as preview. There
are lots of things we can do, for example:
- Replace CGAL with a faster and more memory efficient geometry
engine that uses 64 bit floating point numbers, instead of
variable-length
rationals.
- Exploit multi-core parallelism.
- Exploit the FPU, eg by using OpenCL or the new Vulkan API.
- Make the graphics primitives more powerful, by permitting the mesh to
be queried. Script evaluation and rendering are now interleaved. Trygon's
transform() operator can now be written in OpenSCAD.
- At this point, the performance choke points have changed, and we are
now motivated to speed up the core language. A good approach is to use LLVM
as our back end, which lets us compile OpenSCAD into optimized machine
code. If Vulkan is now available on all platforms, then we can also use
LLVM to generate optimized GPU code.
I think that OpenSCAD can be evolved into a much more powerful language for
3D solid modelling, without ruining the characteristics that our users find
valuable, such as simple, declarative semantics and convenient syntax.
OpenSCAD can be extended to become a better "plugin" language for writing
advanced solid modelling libraries than Python or some other general
purpose language.
In the long run, there are clear advantages to having a single language
that supports both simple and advanced solid modelling. You don't need to
jump the chasm from OpenSCAD to Python to start using more advanced
techniques in your models.
for
interop.
You name it.
OpenSCAD:
1. Make the core language more expressive and powerful. My current
proposal for this is OpenSCAD2 <https://github.com/doug-moen/openscad2>.
2. Make rendering much faster, so that it is as fast as preview. There
variable-length
rationals.
3. Make the graphics primitives more powerful, by permitting the mesh to
4. At this point, the performance choke points have changed, and we are
purpose language.
On 22 November 2015 at 17:04, Parkinbot <rudolf@parkinbot.com> wrote:
> > for
> interop.
> You name it.
> Rudolf
AC
Alan Cox
Mon, Nov 23, 2015 4:39 PM
the mesh available.
Now go measure how much of the CPU wall clock time is spent in the depths
of intersections unions and friends.
If you implement a complex operator in python it'll suck yes. Ditto with
Blender btw. But if you need a fundmanetal mathematical operation the
chances are it should be in the core anyway.
The Blender examples are interesting in that to put it bluntly Blender
shows it works for real world problems.
cost of rendering.
And if you want OpenSCAD to every run at useful speed for larger objects
you'll have to either remove CGAL or replace the numbers implementation
you select with a fixed point integer one which also fixes that.
Yes, but not half as difficult as debugging crashes caused by scribbles
from non parallel safe C++ code. The number of people who can write good
parallel C++ code is rather smaller than you'd want, not helped by the
fact that computer science as often taught if anything damages rather
than enhances those skills.
Alan
> the mesh available.
> cost of rendering.
Alan
Mon, Nov 23, 2015 4:56 PM
@doug
Thanks for the link. I had a closer look at the roadmap and can see, that a
lot will be changed – obviously to the better. And I am looking forward to
the results with pleasure.
As it concerns functions, I must admit that I'm not a fan of functional
programming at all, even I’ve done lots of it in my life. Its nested
structure is merely academic, and thus very confusing for novices, who might
have done some BASIC, Pascal, Java, C/C++ or even just some scripting
before. As most algorithms and library implementations are given in
iterative/procedural form, it requires a lot of (in my eyes: needless)
translation work, when it comes to port given code, and after all, with no
debugging available (or did I miss this?).
Well, a paradigm is surely a matter of taste and tradition and I've
understood your "Non-goal" paragraph quite well. Thus I would never go so
far to request a paradigm change, which by the way might easily be done by
allowing local variables and sequences of statements, with the last one, or
why not a "return", denoting the result, instead of just one aggregated,
overly nested, and sometimes even recursive statement denoting the result in
a non-readable fashion.
For my part, I guess, it is this functional purism that puts even more
weight to the request of an API for user defined functions.
Rudolf
View this message in context: http://forum.openscad.org/feature-request-plug-ins-tp14663p14721.html
@doug
Rudolf
