Feature request: extension of cube center functionality.
K
kdtop
Sun, Nov 29, 2020 4:35 PM
Native OpenSCAD includes the ability to place a cube based on a center point,
rather than based on one corner.  E.g.
*cube([10,10,10]);*
http://forum.openscad.org/file/t2397/Capture1.png
vs
*cube([10,10,10], center=true);*
http://forum.openscad.org/file/t2397/Capture2.png
I find, however, that I often need to center the cube in just one dimension,
for example y axis only.  Thus I sometimes write the following code to
extend cube centering functionality:
module cube2(size, center=[0,0,0]) {
translate([-(size.x/2)*center.x, -(size.y/2)*center.y,
-(size.z/2)*center.z])
cube(size);
Examples of use:
*TestSize = [10,10,10];
color("red") cube2(TestSize, center=[0,1,0]);
color("blue") cube2(TestSize, center=[1,0,1]);*
http://forum.openscad.org/file/t2397/Capture3.png
Feature request:
I would like to see this implemented into native OpenSCAD.  Thus the
center parameter would be overloaded as follows:
-- If a boolean (true / false) is passed, then it would work as previously.
-- if an expression that evaluates to 0, then interpreted as false, if any
other number, then as true.  (currently passing in "1" is interpreted as
false.)
-- if a vector ([1,1,1]) is passed, then each element is interpreted as
boolean for each dimension.  E.g. center.x would be parameter for centering
in x axis, and so on for .y and .z
I suspect this would be a relatively easy bit of code to implement.
Yes, I can just make my own custom library and include this for my own use.
But does anyone else think this would be a helpful addition to the native
language?
Thanks
Kevin T
Native OpenSCAD includes the ability to place a cube based on a center point, rather than based on one corner. E.g. *cube([10,10,10]);* <http://forum.openscad.org/file/t2397/Capture1.png> vs *cube([10,10,10], center=true);* <http://forum.openscad.org/file/t2397/Capture2.png> I find, however, that I often need to center the cube in just one dimension, for example y axis only. Thus I sometimes write the following code to extend cube centering functionality: * module cube2(size, center=[0,0,0]) { translate([-(size.x/2)*center.x, -(size.y/2)*center.y, -(size.z/2)*center.z]) cube(size); } * Examples of use: *TestSize = [10,10,10]; color("red") cube2(TestSize, center=[0,1,0]); color("blue") cube2(TestSize, center=[1,0,1]);* <http://forum.openscad.org/file/t2397/Capture3.png> Feature request: I would like to see this implemented into native OpenSCAD. Thus the center parameter would be overloaded as follows: -- If a boolean (true / false) is passed, then it would work as previously. -- if an expression that evaluates to 0, then interpreted as false, if any other number, then as true. (currently passing in "1" is interpreted as false.) -- if a vector ([1,1,1]) is passed, then each element is interpreted as boolean for each dimension. E.g. center.x would be parameter for centering in x axis, and so on for .y and .z I suspect this would be a relatively easy bit of code to implement. Yes, I can just make my own custom library and include this for my own use. But does anyone else think this would be a helpful addition to the native language? Thanks Kevin T -- Sent from: http://forum.openscad.org/
Sun, Nov 29, 2020 4:54 PM
Much more useful extensions have been rejected as unnecessary complication,
so I doubt you'll see this in native OpenSCAD.  Especially since it is easy
to do what you want with user-written modules...or many would argue by just
sticking a translate() in front of your cube.
The BOSL2 library supports this via a syntax like:
cuboid([10,10,10], anchor=LEFT)
which places the center of the left side of the cube on the origin, or
equivalently anchor=[-1,0,0].  (So that's centered in y and z.)
You could use anchor=[-1,0,-1] or equivalently anchor=LEFT+BOTTOM to center
on Y only.
point,
 *cube([10,10,10]);*
vs
dimension,
Much more useful extensions have been rejected as unnecessary complication, so I doubt you'll see this in native OpenSCAD. Especially since it is easy to do what you want with user-written modules...or many would argue by just sticking a translate() in front of your cube. The BOSL2 library supports this via a syntax like: cuboid([10,10,10], anchor=LEFT) which places the center of the left side of the cube on the origin, or equivalently anchor=[-1,0,0]. (So that's centered in y and z.) You could use anchor=[-1,0,-1] or equivalently anchor=LEFT+BOTTOM to center on Y only. kdtop wrote > Native OpenSCAD includes the ability to place a cube based on a center > point, > rather than based on one corner. E.g. > > *cube([10,10,10]);* > > &lt;http://forum.openscad.org/file/t2397/Capture1.png&gt; > > vs > > *cube([10,10,10], center=true);* > > &lt;http://forum.openscad.org/file/t2397/Capture2.png&gt; > > I find, however, that I often need to center the cube in just one > dimension, > for example y axis only. -- Sent from: http://forum.openscad.org/
AC
A. Craig West
Sun, Nov 29, 2020 4:55 PM
It seems useful, but also pretty trivial to implement in userspace. The
cube I use in most of my code specifies x, y, and z offsets for the faces.
There are any number of ways to specify a cube, and it is difficult to
justify any particular ones as being necessary
point,
 *cube([10,10,10]);*
vs
dimension,
cube(size);
Examples of use:
Feature request:
previously.
false.)
use.
language?
Thanks
Kevin T
It seems useful, but also pretty trivial to implement in userspace. The cube I use in most of my code specifies x, y, and z offsets for the faces. There are any number of ways to specify a cube, and it is difficult to justify any particular ones as being necessary On Sun, 29 Nov 2020, 11:36 kdtop, <kdtop3@gmail.com> wrote: > Native OpenSCAD includes the ability to place a cube based on a center > point, > rather than based on one corner. E.g. > > *cube([10,10,10]);* > > <http://forum.openscad.org/file/t2397/Capture1.png> > > vs > > *cube([10,10,10], center=true);* > > <http://forum.openscad.org/file/t2397/Capture2.png> > > I find, however, that I often need to center the cube in just one > dimension, > for example y axis only. Thus I sometimes write the following code to > extend cube centering functionality: > * > module cube2(size, center=[0,0,0]) { > translate([-(size.x/2)*center.x, -(size.y/2)*center.y, > -(size.z/2)*center.z]) > cube(size); > } * > > Examples of use: > > *TestSize = [10,10,10]; > color("red") cube2(TestSize, center=[0,1,0]); > color("blue") cube2(TestSize, center=[1,0,1]);* > > <http://forum.openscad.org/file/t2397/Capture3.png> > > Feature request: > I would like to see this implemented into native OpenSCAD. Thus the > center parameter would be overloaded as follows: > -- If a boolean (true / false) is passed, then it would work as > previously. > -- if an expression that evaluates to 0, then interpreted as false, if any > other number, then as true. (currently passing in "1" is interpreted as > false.) > -- if a vector ([1,1,1]) is passed, then each element is interpreted as > boolean for each dimension. E.g. center.x would be parameter for centering > in x axis, and so on for .y and .z > > I suspect this would be a relatively easy bit of code to implement. > > Yes, I can just make my own custom library and include this for my own > use. > But does anyone else think this would be a helpful addition to the native > language? > > Thanks > Kevin T > > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
JL
Jean-Paul Louis
Sun, Nov 29, 2020 4:59 PM
Kevin,What you're asking is the perfect example of feature creep. A feature that does not add any value to the existing code. If you really want it, create a module that will do what you want, and don't bloat a good feature with useless stuff.
Just my two cents,Jean-Paul N1JPL
Sent from Yahoo Mail on Android
On Sun, Nov 29, 2020 at 11:36 AM, kdtopkdtop3@GMAIL.COM wrote:  Native OpenSCAD includes the ability to place a cube based on a center point,
    cube([10,10,10]);
vs
        cube(size);
Examples of use:
Feature request:
false.)
language?
Thanks
Kevin T
Kevin,What you're asking is the perfect example of feature creep. A feature that does not add any value to the existing code. If you really want it, create a module that will do what you want, and don't bloat a good feature with useless stuff. Just my two cents,Jean-Paul N1JPL  Sent from Yahoo Mail on Android On Sun, Nov 29, 2020 at 11:36 AM, kdtop<kdtop3@GMAIL.COM> wrote: Native OpenSCAD includes the ability to place a cube based on a center point, rather than based on one corner.  E.g.     *cube([10,10,10]);* <http://forum.openscad.org/file/t2397/Capture1.png> vs     *cube([10,10,10], center=true);* <http://forum.openscad.org/file/t2397/Capture2.png> I find, however, that I often need to center the cube in just one dimension, for example y axis only.  Thus I sometimes write the following code to extend cube centering functionality: *     module cube2(size, center=[0,0,0]) {       translate([-(size.x/2)*center.x, -(size.y/2)*center.y, -(size.z/2)*center.z])         cube(size);     }  * Examples of use:     *TestSize = [10,10,10];     color("red") cube2(TestSize, center=[0,1,0]);     color("blue") cube2(TestSize, center=[1,0,1]);* <http://forum.openscad.org/file/t2397/Capture3.png> Feature request:   I would like to see this implemented into native OpenSCAD.  Thus the center parameter would be overloaded as follows: -- If a boolean (true / false) is passed, then it would work as previously.  -- if an expression that evaluates to 0, then interpreted as false, if any other number, then as true.  (currently passing in "1" is interpreted as false.) -- if a vector ([1,1,1]) is passed, then each element is interpreted as boolean for each dimension.  E.g. center.x would be parameter for centering in x axis, and so on for .y and .z I suspect this would be a relatively easy bit of code to implement. Yes, I can just make my own custom library and include this for my own use. But does anyone else think this would be a helpful addition to the native language? Thanks Kevin T -- Sent from: http://forum.openscad.org/ _______________________________________________ OpenSCAD mailing list Discuss@lists.openscad.org http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Sun, Nov 29, 2020 5:02 PM
I often want the XY centred and not Z, or perhaps vice versa. That can be
done by linear_extude() square() because you get two separate center
parameters.
On Sun, 29 Nov 2020 at 16:59, Jean-Paul Louis via Discuss <
Kevin,
Just my two cents,
Jean-Paul
N1JPL
https://go.onelink.me/107872968?pid=InProduct&c=Global_Internal_YGrowth_AndroidEmailSig__AndroidUsers&af_wl=ym&af_sub1=Internal&af_sub2=Global_YGrowth&af_sub3=EmailSignature
point,
 *cube([10,10,10]);*
vs
dimension,
cube(size);
Examples of use:
Feature request:
previously.
false.)
use.
language?
Thanks
Kevin T
I often want the XY centred and not Z, or perhaps vice versa. That can be done by linear_extude() square() because you get two separate center parameters. On Sun, 29 Nov 2020 at 16:59, Jean-Paul Louis via Discuss < discuss@lists.openscad.org> wrote: > Kevin, > What you're asking is the perfect example of feature creep. A feature that > does not add any value to the existing code. > If you really want it, create a module that will do what you want, and > don't bloat a good feature with useless stuff. > > Just my two cents, > Jean-Paul > N1JPL > > Sent from Yahoo Mail on Android > <https://go.onelink.me/107872968?pid=InProduct&c=Global_Internal_YGrowth_AndroidEmailSig__AndroidUsers&af_wl=ym&af_sub1=Internal&af_sub2=Global_YGrowth&af_sub3=EmailSignature> > > On Sun, Nov 29, 2020 at 11:36 AM, kdtop > <kdtop3@GMAIL.COM> wrote: > Native OpenSCAD includes the ability to place a cube based on a center > point, > rather than based on one corner. E.g. > > *cube([10,10,10]);* > > <http://forum.openscad.org/file/t2397/Capture1.png> > > vs > > *cube([10,10,10], center=true);* > > <http://forum.openscad.org/file/t2397/Capture2.png> > > I find, however, that I often need to center the cube in just one > dimension, > for example y axis only. Thus I sometimes write the following code to > extend cube centering functionality: > * > module cube2(size, center=[0,0,0]) { > translate([-(size.x/2)*center.x, -(size.y/2)*center.y, > -(size.z/2)*center.z]) > cube(size); > } * > > Examples of use: > > *TestSize = [10,10,10]; > color("red") cube2(TestSize, center=[0,1,0]); > color("blue") cube2(TestSize, center=[1,0,1]);* > > <http://forum.openscad.org/file/t2397/Capture3.png> > > Feature request: > I would like to see this implemented into native OpenSCAD. Thus the > center parameter would be overloaded as follows: > -- If a boolean (true / false) is passed, then it would work as > previously. > -- if an expression that evaluates to 0, then interpreted as false, if any > other number, then as true. (currently passing in "1" is interpreted as > false.) > -- if a vector ([1,1,1]) is passed, then each element is interpreted as > boolean for each dimension. E.g. center.x would be parameter for centering > in x axis, and so on for .y and .z > > I suspect this would be a relatively easy bit of code to implement. > > Yes, I can just make my own custom library and include this for my own > use. > But does anyone else think this would be a helpful addition to the native > language? > > Thanks > Kevin T > > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Rob Ward
Sun, Nov 29, 2020 5:20 PM
It is also the perfect example of why the "OpenSCAD language - replace it with Python3" discussion thread is worth reading.
Cheers, RobW
On 30 November 2020 3:59:04 am AEDT, Jean-Paul Louis via Discuss discuss@lists.openscad.org wrote:
point,
    cube([10,10,10]);
vs
dimension,
        cube(size);
Examples of use:
Feature request:
previously.
any
as
false.)
centering
use.
native
language?
Thanks
Kevin T
It is also the perfect example of why the "OpenSCAD language - replace it with Python3" discussion thread is worth reading. Cheers, RobW On 30 November 2020 3:59:04 am AEDT, Jean-Paul Louis via Discuss <discuss@lists.openscad.org> wrote: >Kevin,What you're asking is the perfect example of feature creep. A >feature that does not add any value to the existing code. If you really >want it, create a module that will do what you want, and don't bloat a >good feature with useless stuff. >Just my two cents,Jean-Paul N1JPL  > >Sent from Yahoo Mail on Android > >On Sun, Nov 29, 2020 at 11:36 AM, kdtop<kdtop3@GMAIL.COM> wrote: >Native OpenSCAD includes the ability to place a cube based on a center >point, >rather than based on one corner.  E.g. > >    *cube([10,10,10]);* > ><http://forum.openscad.org/file/t2397/Capture1.png> > >vs > >    *cube([10,10,10], center=true);* > ><http://forum.openscad.org/file/t2397/Capture2.png> > >I find, however, that I often need to center the cube in just one >dimension, >for example y axis only.  Thus I sometimes write the following code to >extend cube centering functionality: >* >    module cube2(size, center=[0,0,0]) { >      translate([-(size.x/2)*center.x, -(size.y/2)*center.y, >-(size.z/2)*center.z]) >        cube(size); >    }  * > >Examples of use: > >    *TestSize = [10,10,10]; >    color("red") cube2(TestSize, center=[0,1,0]); >    color("blue") cube2(TestSize, center=[1,0,1]);* > ><http://forum.openscad.org/file/t2397/Capture3.png> > >Feature request: >  I would like to see this implemented into native OpenSCAD.  Thus the >center parameter would be overloaded as follows: >-- If a boolean (true / false) is passed, then it would work as >previously.  >-- if an expression that evaluates to 0, then interpreted as false, if >any >other number, then as true.  (currently passing in "1" is interpreted >as >false.) >-- if a vector ([1,1,1]) is passed, then each element is interpreted as >boolean for each dimension.  E.g. center.x would be parameter for >centering >in x axis, and so on for .y and .z > >I suspect this would be a relatively easy bit of code to implement. > >Yes, I can just make my own custom library and include this for my own >use. >But does anyone else think this would be a helpful addition to the >native >language? > >Thanks >Kevin T > > > > > >-- >Sent from: http://forum.openscad.org/ > >_______________________________________________ >OpenSCAD mailing list >Discuss@lists.openscad.org >http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
KT
Kevin Toppenberg
Sun, Nov 29, 2020 6:06 PM
Thanks for the replies.  I guess I will just keep it in a library for
myself.
Kevin T
Cheers, RobW
Kevin,
Just my two cents,
Jean-Paul
N1JPL
point,
 *cube([10,10,10]);*
vs
dimension,
cube(size);
Examples of use:
Feature request:
previously.
false.)
centering
use.
language?
Thanks
Kevin T
Thanks for the replies. I guess I will just keep it in a library for myself. Kevin T On Sun, Nov 29, 2020 at 12:20 PM Rob Ward <rl.ward@bigpond.com> wrote: > It is also the perfect example of why the "OpenSCAD language - replace it > with Python3" discussion thread is worth reading. > Cheers, RobW > > On 30 November 2020 3:59:04 am AEDT, Jean-Paul Louis via Discuss < > discuss@lists.openscad.org> wrote: >> >> Kevin, >> What you're asking is the perfect example of feature creep. A feature >> that does not add any value to the existing code. >> If you really want it, create a module that will do what you want, and >> don't bloat a good feature with useless stuff. >> >> Just my two cents, >> Jean-Paul >> N1JPL >> >> Sent from Yahoo Mail on Android >> <https://go.onelink.me/107872968?pid=InProduct&c=Global_Internal_YGrowth_AndroidEmailSig__AndroidUsers&af_wl=ym&af_sub1=Internal&af_sub2=Global_YGrowth&af_sub3=EmailSignature> >> >> On Sun, Nov 29, 2020 at 11:36 AM, kdtop >> <kdtop3@GMAIL.COM> wrote: >> Native OpenSCAD includes the ability to place a cube based on a center >> point, >> rather than based on one corner. E.g. >> >> *cube([10,10,10]);* >> >> <http://forum.openscad.org/file/t2397/Capture1.png> >> >> vs >> >> *cube([10,10,10], center=true);* >> >> <http://forum.openscad.org/file/t2397/Capture2.png> >> >> I find, however, that I often need to center the cube in just one >> dimension, >> for example y axis only. Thus I sometimes write the following code to >> extend cube centering functionality: >> * >> module cube2(size, center=[0,0,0]) { >> translate([-(size.x/2)*center.x, -(size.y/2)*center.y, >> -(size.z/2)*center.z]) >> cube(size); >> } * >> >> Examples of use: >> >> *TestSize = [10,10,10]; >> color("red") cube2(TestSize, center=[0,1,0]); >> color("blue") cube2(TestSize, center=[1,0,1]);* >> >> <http://forum.openscad.org/file/t2397/Capture3.png> >> >> Feature request: >> I would like to see this implemented into native OpenSCAD. Thus the >> center parameter would be overloaded as follows: >> -- If a boolean (true / false) is passed, then it would work as >> previously. >> -- if an expression that evaluates to 0, then interpreted as false, if any >> other number, then as true. (currently passing in "1" is interpreted as >> false.) >> -- if a vector ([1,1,1]) is passed, then each element is interpreted as >> boolean for each dimension. E.g. center.x would be parameter for >> centering >> in x axis, and so on for .y and .z >> >> I suspect this would be a relatively easy bit of code to implement. >> >> Yes, I can just make my own custom library and include this for my own >> use. >> But does anyone else think this would be a helpful addition to the native >> language? >> >> Thanks >> Kevin T >> >> >> >> >> >> -- >> Sent from: http://forum.openscad.org/ >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Troberg
I just made my own cube module, which has three extra arguments, xalign,
yalign and zalign. If they are 0, it's centered, if -1, the bottom (or, more
precisely, the negative side) aligns with the axis, if 1, the top (the
positive side) aligns with the axis.
Literally a 5 minute job to make.
I don't see a need for this in the core language.
I just made my own cube module, which has three extra arguments, xalign, yalign and zalign. If they are 0, it's centered, if -1, the bottom (or, more precisely, the negative side) aligns with the axis, if 1, the top (the positive side) aligns with the axis. Literally a 5 minute job to make. I don't see a need for this in the core language. -- Sent from: http://forum.openscad.org/
Sun, Nov 29, 2020 8:23 PM
Before I added the anchor= functionality to BOSL2, I used to have upcube(), leftcube(), etc modules that centered the cube above, to the left, etc of the origin.
-Revar
Kevin T
Cheers, RobW
Kevin,
Just my two cents,
Jean-Paul
N1JPL
 *cube([10,10,10]);*
vs
cube(size);
Examples of use:
Feature request:
false.)
language?
Thanks
Kevin T
Before I added the anchor= functionality to BOSL2, I used to have upcube(), leftcube(), etc modules that centered the cube above, to the left, etc of the origin. -Revar > On Nov 29, 2020, at 10:07 AM, Kevin Toppenberg <kdtop3@gmail.com> wrote: > >  > Thanks for the replies. I guess I will just keep it in a library for myself. > > Kevin T > >> On Sun, Nov 29, 2020 at 12:20 PM Rob Ward <rl.ward@bigpond.com> wrote: >> It is also the perfect example of why the "OpenSCAD language - replace it with Python3" discussion thread is worth reading. >> Cheers, RobW >> >>> On 30 November 2020 3:59:04 am AEDT, Jean-Paul Louis via Discuss <discuss@lists.openscad.org> wrote: >>> Kevin, >>> What you're asking is the perfect example of feature creep. A feature that does not add any value to the existing code. >>> If you really want it, create a module that will do what you want, and don't bloat a good feature with useless stuff. >>> >>> Just my two cents, >>> Jean-Paul >>> N1JPL >>> >>> Sent from Yahoo Mail on Android >>> >>> On Sun, Nov 29, 2020 at 11:36 AM, kdtop >>> <kdtop3@GMAIL.COM> wrote: >>> Native OpenSCAD includes the ability to place a cube based on a center point, >>> rather than based on one corner. E.g. >>> >>> *cube([10,10,10]);* >>> >>> <http://forum.openscad.org/file/t2397/Capture1.png> >>> >>> vs >>> >>> *cube([10,10,10], center=true);* >>> >>> <http://forum.openscad.org/file/t2397/Capture2.png> >>> >>> I find, however, that I often need to center the cube in just one dimension, >>> for example y axis only. Thus I sometimes write the following code to >>> extend cube centering functionality: >>> * >>> module cube2(size, center=[0,0,0]) { >>> translate([-(size.x/2)*center.x, -(size.y/2)*center.y, >>> -(size.z/2)*center.z]) >>> cube(size); >>> } * >>> >>> Examples of use: >>> >>> *TestSize = [10,10,10]; >>> color("red") cube2(TestSize, center=[0,1,0]); >>> color("blue") cube2(TestSize, center=[1,0,1]);* >>> >>> <http://forum.openscad.org/file/t2397/Capture3.png> >>> >>> Feature request: >>> I would like to see this implemented into native OpenSCAD. Thus the >>> center parameter would be overloaded as follows: >>> -- If a boolean (true / false) is passed, then it would work as previously. >>> -- if an expression that evaluates to 0, then interpreted as false, if any >>> other number, then as true. (currently passing in "1" is interpreted as >>> false.) >>> -- if a vector ([1,1,1]) is passed, then each element is interpreted as >>> boolean for each dimension. E.g. center.x would be parameter for centering >>> in x axis, and so on for .y and .z >>> >>> I suspect this would be a relatively easy bit of code to implement. >>> >>> Yes, I can just make my own custom library and include this for my own use. >>> But does anyone else think this would be a helpful addition to the native >>> language? >>> >>> Thanks >>> Kevin T >>> >>> >>> >>> >>> >>> -- >>> Sent from: http://forum.openscad.org/ >>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> Discuss@lists.openscad.org >>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Sun, Nov 29, 2020 9:06 PM
I have a module jcube (for justified cube) that takes dims and a
[jz,jy,jz] justify vector where -1 means the cube goes negative from the
origin, 0 means centered, and +1 means positive from the origin.
It's based on a more general justify module that similarly justifies its
children.  It takes a bounding box (either [dx,dy,dz] dimensions with an
implied origin at [0,0,0], or [[ox,oy,oz], [dx,dy,dz]]) and a justify
vector as above.
Both also take a simple boolean center equivalent to j=[0,0,0], but I
don't know if I've ever used it since it's longer.
With respect to whether such a feature should be in the base... undecided.
It could certainly be in MCAD and so available in every installation.
Argument for putting it in the base:  so you don't have to have a module
that is almost, but not quite, the same as "cube".  Also helps to
establish a convention for how to represent this sort of justification,
so that it's obvious how justifying a cylinder, or sphere, or whatever
would work.
Argument against:  it doesn't need to be.  (But note:  "center" doesn't
need to be either, so we aren't strictly minimal.)
use <default.scad>
// @brief       Given an [x,y] or an [x,y,z], return an [x,y,z].
// @param   a   A two- or three- element array
// @returns     A three-element array
function make3(a) =
    assert(len(a) == 2 || len(a) == 3)
    len(a) == 3 ? a : concat(a, 0);
// @brief        Justify children as specified by argument.
// @param center Equivalent to justify=[0,0,0].
// @param j      [jx,jy,jz]:
//                   +1 toward-positive
//                    0 center
//                   -1 toward-negative
// @param bb     Bounding box:
//                   [dimx,dimy,dimz]
//                   [ [ox,oy,oz], [dimx,dimy,dimz] ]
// @children     Object(s) to be justified.
// @note Works for two- or three- dimensional objects.
// @note If more than one object is supplied as a child, they
//       are all justified en mass with respect to the specified
//       bounding box.
module justify(center, j, bb) {
    origin = make3(
        assert(is_list(bb))
        is_list(bb[0])
            ? assert(len(bb) == 2) bb[0]
            : [0,0,0]
    dims = make3(
            is_list(bb[0])
                ? bb[1]
                : bb
    j = make3(default(j, center ? [0,0,0] : [1,1,1]));
    function o(flag, dim) = flag > 0 ? 0 :
        flag < 0 ? -dim :
        -dim/2;
    translate([o(j[0], dims[0]),
        o(j[1], dims[1]),
        o(j[2], dims[2])])
        translate(-origin)  // Move BB minima to [0,0,0]
// @brief        A justified cube
// @param dims   Dimensions of the cube
// @param center Equivalent to j=[0,0,0]
// @param j      As for justify() above
module jcube(dims, center, j) {
    justify(center=center, j=j, bb=dims) cube(dims);
// Test/demos
for (xj=[-1:1], yj=[-1:1], zj=[-1:1]) {
    justify(j=[xj,yj,zj], bb=[[-10,-10,-10],[20,20,20]])
        color([(xj+1)/2, (yj+1)/2, (zj+1)/2]) sphere(r=10);
translate([30,0]) for (xj=[-1:1], yj=[-1:1]) {
    justify(j=[xj,yj], bb=[[-10,-10],[10,10]])
        color([(xj+1)/2, (yj+1)/2, 0]) circle(r=10);
It depends on a trivial function "default":
function default(val, def) = is_undef(val) ? def : val;
I have a module jcube (for justified cube) that takes dims and a [jz,jy,jz] justify vector where -1 means the cube goes negative from the origin, 0 means centered, and +1 means positive from the origin. It's based on a more general justify module that similarly justifies its children.  It takes a bounding box (either [dx,dy,dz] dimensions with an implied origin at [0,0,0], or [[ox,oy,oz], [dx,dy,dz]]) and a justify vector as above. Both also take a simple boolean center equivalent to j=[0,0,0], but I don't know if I've ever used it since it's longer. With respect to whether such a feature should be in the base... undecided. It could certainly be in MCAD and so available in every installation. Argument for putting it in the base:  so you don't have to have a module that is almost, but not quite, the same as "cube".  Also helps to establish a convention for how to represent this sort of justification, so that it's obvious how justifying a cylinder, or sphere, or whatever would work. Argument against:  it doesn't need to be.  (But note:  "center" doesn't need to be either, so we aren't strictly minimal.) use <default.scad> // @brief Given an [x,y] or an [x,y,z], return an [x,y,z]. // @param a A two- or three- element array // @returns A three-element array function make3(a) = assert(len(a) == 2 || len(a) == 3) len(a) == 3 ? a : concat(a, 0); // @brief Justify children as specified by argument. // @param center Equivalent to justify=[0,0,0]. // @param j [jx,jy,jz]: // +1 toward-positive // 0 center // -1 toward-negative // @param bb Bounding box: // [dimx,dimy,dimz] // [ [ox,oy,oz], [dimx,dimy,dimz] ] // @children Object(s) to be justified. // @note Works for two- or three- dimensional objects. // @note If more than one object is supplied as a child, they // are all justified en mass with respect to the specified // bounding box. module justify(center, j, bb) { origin = make3( assert(is_list(bb)) is_list(bb[0]) ? assert(len(bb) == 2) bb[0] : [0,0,0] ); dims = make3( is_list(bb[0]) ? bb[1] : bb ); j = make3(default(j, center ? [0,0,0] : [1,1,1])); function o(flag, dim) = flag > 0 ? 0 : flag < 0 ? -dim : -dim/2; translate([o(j[0], dims[0]), o(j[1], dims[1]), o(j[2], dims[2])]) translate(-origin) // Move BB minima to [0,0,0] children(); } // @brief A justified cube // @param dims Dimensions of the cube // @param center Equivalent to j=[0,0,0] // @param j As for justify() above module jcube(dims, center, j) { justify(center=center, j=j, bb=dims) cube(dims); } // Test/demos for (xj=[-1:1], yj=[-1:1], zj=[-1:1]) { justify(j=[xj,yj,zj], bb=[[-10,-10,-10],[20,20,20]]) color([(xj+1)/2, (yj+1)/2, (zj+1)/2]) sphere(r=10); } translate([30,0]) for (xj=[-1:1], yj=[-1:1]) { justify(j=[xj,yj], bb=[[-10,-10],[10,10]]) color([(xj+1)/2, (yj+1)/2, 0]) circle(r=10); } It depends on a trivial function "default": function default(val, def) = is_undef(val) ? def : val;
