treatment of syntax errors in OpenSCAD
PF
Peter Falke
Mon, Mar 16, 2015 9:44 PM
I'm very much worried by the way OpenSCAD  treats what I call syntax errors:
square([2,3,]); //works like square([2,3]);
translate(1)circle();// translate() fails silently
square([10,10,10]); // fails silently
To remedy this I would like to initiate a discussion of what should be the
expected behavior, what should lead to an error, and what should lead to a
warning.
To facilitate this discussion, I wrote a small program that, as a test
case, lists all  possible values a variable could take on.
It than calls the module print_boolean() for all values which echos their
value and its Boolean value.
This program could then be used as a template for testing other calls (e.g.
sphere(value);).
Please have a look at it: Are there any other values that would be
important to include as test cases?
// syntax_boolean_v0
// List all possible values of vaiables to later
// use them as a template to define and test the syntax
// of (internal) module calls.
// This is shown here for the boolean value, as an example.
// GPLv2
// (c) 2015 TakeItAndRun
// variables
var_true=true;
var_false=false;
var_zero=0;
var_number=3;
var_negnumber=-3;
var_small=0.494066e-323;
var_large=1.7976931348623158080999999e+308*1;
var_undef=true*true;
var_inf=1/0;
var_char="a";
var_string="TEXT";
var_emptystring="";
// 2 dim-vectors
vec2_true=vec2(var_true);
vec2_false=vec2(var_false);
vec2_zero=vec2(var_zero);
vec2_number=vec2(var_number);
vec2_negnumber=vec2(var_negnumber);
vec2_small=vec2(var_small);
vec2_large=vec2(var_large);
vec2_undef=vec2(var_undef);
vec2_inf=vec2(var_inf);
vec2_char=vec2(var_char);
vec2_string=vec2(var_string);
vec2_emptystring=vec2(var_emptystring);
// 3 dim-vectors
vec3_true=vec3(var_true);
vec3_false=vec3(var_false);
vec3_zero=vec3(var_zero);
vec3_number=vec3(var_number);
vec3_negnumber=vec3(var_negnumber);
vec3_small=vec3(var_small);
vec3_large=vec3(var_large);
vec3_undef=vec3(var_undef);
vec3_inf=vec3(var_inf);
vec3_char=vec3(var_char);
vec3_string=vec3(var_string);
vec3_emptystring=vec3(var_emptystring);
// generate vectors from variables
function vec2(var)=[var,var];
function vec3(var)=[var,var,var];
// print the value and the boolean value of it
module print_boolean(var){
echo(var,var?true:false);
// var
print_boolean(var_true);
print_boolean(var_false);
print_boolean(var_zero);
print_boolean(var_number);
print_boolean(var_negnumber);
print_boolean(var_small);
print_boolean(var_large);
print_boolean(var_undef);
print_boolean(var_inf);
print_boolean(var_char);
print_boolean(var_string);
print_boolean(var_emptystring);
// echo -->> The boolean value of false, zero, undef, and empty string
gives false, everything else gives true
// 2-dim vector
print_boolean(vec2_true);
print_boolean(vec2_false);
print_boolean(vec2_zero);
print_boolean(vec2_number);
print_boolean(vec2_negnumber);
print_boolean(vec2_small);
print_boolean(vec2_large);
print_boolean(vec2_undef);
print_boolean(vec2_inf);
print_boolean(vec2_char);
print_boolean(vec2_string);
print_boolean(vec2_emptystring);
// echo -->> The boolean value of any (!) 2-dim vector is always true
regardeless of its value
// 3-dim vector
print_boolean(vec3_true);
print_boolean(vec3_false);
print_boolean(vec3_zero);
print_boolean(vec3_number);
print_boolean(vec3_negnumber);
print_boolean(vec3_small);
print_boolean(vec3_large);
print_boolean(vec3_undef);
print_boolean(vec3_inf);
print_boolean(vec3_char);
print_boolean(vec3_string);
print_boolean(vec3_emptystring);
// echo -->> The boolean value of any (!) 3-dim vector is always true
Output:
ECHO: true, true
ECHO: false, false
ECHO: 0, false
ECHO: 3, true
ECHO: -3, true
ECHO: 4.94066e-324, true
ECHO: 1.79769e+308, true
ECHO: undef, false
ECHO: inf, true
ECHO: "a", true
ECHO: "TEXT", true
ECHO: "", false
ECHO: [true, true], true
ECHO: [false, false], true
ECHO: [0, 0], true
ECHO: [3, 3], true
ECHO: [-3, -3], true
ECHO: [4.94066e-324, 4.94066e-324], true
ECHO: [1.79769e+308, 1.79769e+308], true
ECHO: [undef, undef], true
ECHO: [inf, inf], true
ECHO: ["a", "a"], true
ECHO: ["TEXT", "TEXT"], true
ECHO: ["", ""], true
ECHO: [true, true, true], true
ECHO: [false, false, false], true
ECHO: [0, 0, 0], true
ECHO: [3, 3, 3], true
ECHO: [-3, -3, -3], true
ECHO: [4.94066e-324, 4.94066e-324, 4.94066e-324], true
ECHO: [1.79769e+308, 1.79769e+308, 1.79769e+308], true
ECHO: [undef, undef, undef], true
ECHO: [inf, inf, inf], true
ECHO: ["a", "a", "a"], true
ECHO: ["TEXT", "TEXT", "TEXT"], true
ECHO: ["", "", ""], true
schreiben.
Enjoy!
I'm very much worried by the way OpenSCAD treats what I call syntax errors: square([2,3,]); //works like square([2,3]); translate(1)circle();// translate() fails silently square([10,10,10]); // fails silently To remedy this I would like to initiate a discussion of what should be the expected behavior, what should lead to an error, and what should lead to a warning. To facilitate this discussion, I wrote a small program that, as a test case, lists all possible values a variable could take on. It than calls the module print_boolean() for all values which echos their value and its Boolean value. This program could then be used as a template for testing other calls (e.g. sphere(value);). Please have a look at it: Are there any other values that would be important to include as test cases? _____________________________________ // ----------------------------------------------------------------------- // // syntax_boolean_v0 // // List all possible values of vaiables to later // use them as a template to define and test the syntax // of (internal) module calls. // This is shown here for the boolean value, as an example. // // GPLv2 // (c) 2015 TakeItAndRun // // ----------------------------------------------------------------------- // variables var_true=true; var_false=false; var_zero=0; var_number=3; var_negnumber=-3; var_small=0.494066e-323; var_large=1.7976931348623158080999999e+308*1; var_undef=true*true; var_inf=1/0; var_char="a"; var_string="TEXT"; var_emptystring=""; // 2 dim-vectors vec2_true=vec2(var_true); vec2_false=vec2(var_false); vec2_zero=vec2(var_zero); vec2_number=vec2(var_number); vec2_negnumber=vec2(var_negnumber); vec2_small=vec2(var_small); vec2_large=vec2(var_large); vec2_undef=vec2(var_undef); vec2_inf=vec2(var_inf); vec2_char=vec2(var_char); vec2_string=vec2(var_string); vec2_emptystring=vec2(var_emptystring); // 3 dim-vectors vec3_true=vec3(var_true); vec3_false=vec3(var_false); vec3_zero=vec3(var_zero); vec3_number=vec3(var_number); vec3_negnumber=vec3(var_negnumber); vec3_small=vec3(var_small); vec3_large=vec3(var_large); vec3_undef=vec3(var_undef); vec3_inf=vec3(var_inf); vec3_char=vec3(var_char); vec3_string=vec3(var_string); vec3_emptystring=vec3(var_emptystring); // generate vectors from variables function vec2(var)=[var,var]; function vec3(var)=[var,var,var]; // print the value and the boolean value of it module print_boolean(var){ echo(var,var?true:false); } // var print_boolean(var_true); print_boolean(var_false); print_boolean(var_zero); print_boolean(var_number); print_boolean(var_negnumber); print_boolean(var_small); print_boolean(var_large); print_boolean(var_undef); print_boolean(var_inf); print_boolean(var_char); print_boolean(var_string); print_boolean(var_emptystring); // echo -->> The boolean value of false, zero, undef, and empty string gives false, everything else gives true // 2-dim vector print_boolean(vec2_true); print_boolean(vec2_false); print_boolean(vec2_zero); print_boolean(vec2_number); print_boolean(vec2_negnumber); print_boolean(vec2_small); print_boolean(vec2_large); print_boolean(vec2_undef); print_boolean(vec2_inf); print_boolean(vec2_char); print_boolean(vec2_string); print_boolean(vec2_emptystring); // echo -->> The boolean value of any (!) 2-dim vector is always true regardeless of its value // 3-dim vector print_boolean(vec3_true); print_boolean(vec3_false); print_boolean(vec3_zero); print_boolean(vec3_number); print_boolean(vec3_negnumber); print_boolean(vec3_small); print_boolean(vec3_large); print_boolean(vec3_undef); print_boolean(vec3_inf); print_boolean(vec3_char); print_boolean(vec3_string); print_boolean(vec3_emptystring); // echo -->> The boolean value of any (!) 3-dim vector is always true regardeless of its value _____________________________________ Output: _____________________________________ ECHO: true, true ECHO: false, false ECHO: 0, false ECHO: 3, true ECHO: -3, true ECHO: 4.94066e-324, true ECHO: 1.79769e+308, true ECHO: undef, false ECHO: inf, true ECHO: "a", true ECHO: "TEXT", true ECHO: "", false ECHO: [true, true], true ECHO: [false, false], true ECHO: [0, 0], true ECHO: [3, 3], true ECHO: [-3, -3], true ECHO: [4.94066e-324, 4.94066e-324], true ECHO: [1.79769e+308, 1.79769e+308], true ECHO: [undef, undef], true ECHO: [inf, inf], true ECHO: ["a", "a"], true ECHO: ["TEXT", "TEXT"], true ECHO: ["", ""], true ECHO: [true, true, true], true ECHO: [false, false, false], true ECHO: [0, 0, 0], true ECHO: [3, 3, 3], true ECHO: [-3, -3, -3], true ECHO: [4.94066e-324, 4.94066e-324, 4.94066e-324], true ECHO: [1.79769e+308, 1.79769e+308, 1.79769e+308], true ECHO: [undef, undef, undef], true ECHO: [inf, inf, inf], true ECHO: ["a", "a", "a"], true ECHO: ["TEXT", "TEXT", "TEXT"], true ECHO: ["", "", ""], true -- stempeldergeschichte@googlemail.com <karsten@rohrbach.de> P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu schreiben. Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. P.S. In case my e-mail is shorter than you enjoy: I am currently trying short replies instead of no replies at all. Please let me know, if you like to read more. Enjoy!
Mon, Mar 16, 2015 9:55 PM
On Mar 16, 2015, at 17:44 PM, Peter Falke stempeldergeschichte@googlemail.com wrote:
This has been discussed quite a bit. I agree that this needs a cleanup.
We could start with providing warnings for all such cases, with an option of treating warnings as errors, to give people some sort of bug compatibility.
Then there are corner cases..
On Mar 16, 2015, at 17:44 PM, Peter Falke <stempeldergeschichte@googlemail.com> wrote: > I'm very much worried by the way OpenSCAD treats what I call syntax errors: > This has been discussed quite a bit. I agree that this needs a cleanup. We could start with providing warnings for all such cases, with an option of treating warnings as errors, to give people some sort of bug compatibility. Then there are corner cases.. -Marius
Mon, Mar 16, 2015 9:57 PM
Only the first one could be called a syntax error. Other languages allow
trailing comma for lists sometimes as it makes extending the list easier.
The rest are valid syntax but wrong argument type.
On 16 March 2015 at 21:44, Peter Falke stempeldergeschichte@googlemail.com
errors:
warning.
// GPLv2
// variables
var_true=true;
var_false=false;
var_zero=0;
var_number=3;
var_negnumber=-3;
var_inf=1/0;
var_char="a";
var_string="TEXT";
var_emptystring="";
// 2 dim-vectors
// 3 dim-vectors
// var
// 2-dim vector
// 3-dim vector
Output:
ECHO: true, true
ECHO: false, false
ECHO: 0, false
ECHO: 3, true
ECHO: -3, true
ECHO: undef, false
ECHO: inf, true
ECHO: "a", true
ECHO: "TEXT", true
ECHO: "", false
ECHO: [0, 0], true
ECHO: [3, 3], true
schreiben.
Enjoy!
Only the first one could be called a syntax error. Other languages allow trailing comma for lists sometimes as it makes extending the list easier. The rest are valid syntax but wrong argument type. On 16 March 2015 at 21:44, Peter Falke <stempeldergeschichte@googlemail.com> wrote: > I'm very much worried by the way OpenSCAD treats what I call syntax > errors: > > > square([2,3,]); //works like square([2,3]); > > > translate(1)circle();// translate() fails silently > > > square([10,10,10]); // fails silently > > > > To remedy this I would like to initiate a discussion of what should be the > expected behavior, what should lead to an error, and what should lead to a > warning. > > > To facilitate this discussion, I wrote a small program that, as a test > case, lists all possible values a variable could take on. > > It than calls the module print_boolean() for all values which echos their > value and its Boolean value. > > This program could then be used as a template for testing other calls > (e.g. sphere(value);). > > > Please have a look at it: Are there any other values that would be > important to include as test cases? > > > _____________________________________ > > // ----------------------------------------------------------------------- > > // > > // syntax_boolean_v0 > > // > > // List all possible values of vaiables to later > > // use them as a template to define and test the syntax > > // of (internal) module calls. > > // This is shown here for the boolean value, as an example. > > // > > // GPLv2 > > // (c) 2015 TakeItAndRun > > // > > // ----------------------------------------------------------------------- > > > // variables > > > var_true=true; > > var_false=false; > > var_zero=0; > > var_number=3; > > var_negnumber=-3; > > var_small=0.494066e-323; > > var_large=1.7976931348623158080999999e+308*1; > > var_undef=true*true; > > var_inf=1/0; > > var_char="a"; > > var_string="TEXT"; > > var_emptystring=""; > > > // 2 dim-vectors > > > vec2_true=vec2(var_true); > > vec2_false=vec2(var_false); > > vec2_zero=vec2(var_zero); > > vec2_number=vec2(var_number); > > vec2_negnumber=vec2(var_negnumber); > > vec2_small=vec2(var_small); > > vec2_large=vec2(var_large); > > vec2_undef=vec2(var_undef); > > vec2_inf=vec2(var_inf); > > vec2_char=vec2(var_char); > > vec2_string=vec2(var_string); > > vec2_emptystring=vec2(var_emptystring); > > > // 3 dim-vectors > > > vec3_true=vec3(var_true); > > vec3_false=vec3(var_false); > > vec3_zero=vec3(var_zero); > > vec3_number=vec3(var_number); > > vec3_negnumber=vec3(var_negnumber); > > vec3_small=vec3(var_small); > > vec3_large=vec3(var_large); > > vec3_undef=vec3(var_undef); > > vec3_inf=vec3(var_inf); > > vec3_char=vec3(var_char); > > vec3_string=vec3(var_string); > > vec3_emptystring=vec3(var_emptystring); > > > // generate vectors from variables > > > function vec2(var)=[var,var]; > > function vec3(var)=[var,var,var]; > > > // print the value and the boolean value of it > > > module print_boolean(var){ > > echo(var,var?true:false); > > } > > > // var > > > print_boolean(var_true); > > print_boolean(var_false); > > print_boolean(var_zero); > > print_boolean(var_number); > > print_boolean(var_negnumber); > > print_boolean(var_small); > > print_boolean(var_large); > > print_boolean(var_undef); > > print_boolean(var_inf); > > print_boolean(var_char); > > print_boolean(var_string); > > print_boolean(var_emptystring); > > > // echo -->> The boolean value of false, zero, undef, and empty string > gives false, everything else gives true > > > // 2-dim vector > > > print_boolean(vec2_true); > > print_boolean(vec2_false); > > print_boolean(vec2_zero); > > print_boolean(vec2_number); > > print_boolean(vec2_negnumber); > > print_boolean(vec2_small); > > print_boolean(vec2_large); > > print_boolean(vec2_undef); > > print_boolean(vec2_inf); > > print_boolean(vec2_char); > > print_boolean(vec2_string); > > print_boolean(vec2_emptystring); > > > // echo -->> The boolean value of any (!) 2-dim vector is always true > regardeless of its value > > > // 3-dim vector > > > print_boolean(vec3_true); > > print_boolean(vec3_false); > > print_boolean(vec3_zero); > > print_boolean(vec3_number); > > print_boolean(vec3_negnumber); > > print_boolean(vec3_small); > > print_boolean(vec3_large); > > print_boolean(vec3_undef); > > print_boolean(vec3_inf); > > print_boolean(vec3_char); > > print_boolean(vec3_string); > > print_boolean(vec3_emptystring); > > > // echo -->> The boolean value of any (!) 3-dim vector is always true > regardeless of its value > > > > _____________________________________ > > > Output: > > _____________________________________ > > > ECHO: true, true > > ECHO: false, false > > ECHO: 0, false > > ECHO: 3, true > > ECHO: -3, true > > ECHO: 4.94066e-324, true > > ECHO: 1.79769e+308, true > > ECHO: undef, false > > ECHO: inf, true > > ECHO: "a", true > > ECHO: "TEXT", true > > ECHO: "", false > > ECHO: [true, true], true > > ECHO: [false, false], true > > ECHO: [0, 0], true > > ECHO: [3, 3], true > > ECHO: [-3, -3], true > > ECHO: [4.94066e-324, 4.94066e-324], true > > ECHO: [1.79769e+308, 1.79769e+308], true > > ECHO: [undef, undef], true > > ECHO: [inf, inf], true > > ECHO: ["a", "a"], true > > ECHO: ["TEXT", "TEXT"], true > > ECHO: ["", ""], true > > ECHO: [true, true, true], true > > ECHO: [false, false, false], true > > ECHO: [0, 0, 0], true > > ECHO: [3, 3, 3], true > > ECHO: [-3, -3, -3], true > > ECHO: [4.94066e-324, 4.94066e-324, 4.94066e-324], true > > ECHO: [1.79769e+308, 1.79769e+308, 1.79769e+308], true > > ECHO: [undef, undef, undef], true > > ECHO: [inf, inf, inf], true > > ECHO: ["a", "a", "a"], true > > ECHO: ["TEXT", "TEXT", "TEXT"], true > > ECHO: ["", "", ""], true > > > -- > stempeldergeschichte@googlemail.com <karsten@rohrbach.de> > > P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: > Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu > schreiben. > Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. > > P.S. In case my e-mail is shorter than you enjoy: > I am currently trying short replies instead of no replies at all. > Please let me know, if you like to read more. > > Enjoy! > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > >
Mon, Mar 16, 2015 10:00 PM
In my opinion, having ANYTHING fail silently is a real problem. This is
one reason why people have trouble "getting into" OpenSCAD: no hints as
to what they have done wrong.
list easier.
 syntax errors:
 // GPLv2
 // variables
 var_true=true;
 var_false=false;
 var_zero=0;
 var_number=3;
 var_negnumber=-3;
 var_inf=1/0;
 var_char="a";
 var_string="TEXT";
 var_emptystring="";
 // 2 dim-vectors
 // 3 dim-vectors
 // var
 // 2-dim vector
 // 3-dim vector
 Output:
 ECHO: true, true
 ECHO: false, false
 ECHO: 0, false
 ECHO: 3, true
 ECHO: -3, true
 ECHO: undef, false
 ECHO: inf, true
 ECHO: "a", true
 ECHO: "TEXT", true
 ECHO: "", false
 ECHO: [0, 0], true
 ECHO: [3, 3], true
 stempeldergeschichte@googlemail.com <mailto:karsten@rohrbach.de>
 zu schreiben.
 Enjoy!
Checked by AVG - www.avg.com http://www.avg.com
Version: 2015.0.5751 / Virus Database: 4306/9317 - Release Date: 03/16/15
In my opinion, having ANYTHING fail silently is a real problem. This is one reason why people have trouble "getting into" OpenSCAD: no hints as to what they have done wrong. On 3/16/2015 5:57 PM, nop head wrote: > Only the first one could be called a syntax error. Other languages > allow trailing comma for lists sometimes as it makes extending the > list easier. > > The rest are valid syntax but wrong argument type. > > On 16 March 2015 at 21:44, Peter Falke > <stempeldergeschichte@googlemail.com > <mailto:stempeldergeschichte@googlemail.com>> wrote: > > I'm very much worried by the way OpenSCAD treats what I call > syntax errors: > / > / > square([2,3,]); //works like square([2,3]); > > > translate(1)circle();// translate() fails silently > > > square([10,10,10]); // fails silently > > > > To remedy this I would like to initiate a discussion of what > should be the expected behavior, what should lead to an error, and > what should lead to a warning. > > > To facilitate this discussion, I wrote a small program that, as a > test case, lists all possible values a variable could take on. > > It than calls the module print_boolean() for all values which > echos their value and its Boolean value. > > This program could then be used as a template for testing other > calls (e.g. sphere(value);). > > > Please have a look at it: Are there any other values that would be > important to include as test cases? > > > _____________________________________ > > // > ----------------------------------------------------------------------- > > // > > // syntax_boolean_v0 > > // > > // List all possible values of vaiables to later > > // use them as a template to define and test the syntax > > // of (internal) module calls. > > // This is shown here for the boolean value, as an example. > > // > > // GPLv2 > > // (c) 2015 TakeItAndRun > > // > > // > ----------------------------------------------------------------------- > > > // variables > > > var_true=true; > > var_false=false; > > var_zero=0; > > var_number=3; > > var_negnumber=-3; > > var_small=0.494066e-323; > > var_large=1.7976931348623158080999999e+308*1; > > var_undef=true*true; > > var_inf=1/0; > > var_char="a"; > > var_string="TEXT"; > > var_emptystring=""; > > > // 2 dim-vectors > > > vec2_true=vec2(var_true); > > vec2_false=vec2(var_false); > > vec2_zero=vec2(var_zero); > > vec2_number=vec2(var_number); > > vec2_negnumber=vec2(var_negnumber); > > vec2_small=vec2(var_small); > > vec2_large=vec2(var_large); > > vec2_undef=vec2(var_undef); > > vec2_inf=vec2(var_inf); > > vec2_char=vec2(var_char); > > vec2_string=vec2(var_string); > > vec2_emptystring=vec2(var_emptystring); > > > // 3 dim-vectors > > > vec3_true=vec3(var_true); > > vec3_false=vec3(var_false); > > vec3_zero=vec3(var_zero); > > vec3_number=vec3(var_number); > > vec3_negnumber=vec3(var_negnumber); > > vec3_small=vec3(var_small); > > vec3_large=vec3(var_large); > > vec3_undef=vec3(var_undef); > > vec3_inf=vec3(var_inf); > > vec3_char=vec3(var_char); > > vec3_string=vec3(var_string); > > vec3_emptystring=vec3(var_emptystring); > > > // generate vectors from variables > > > function vec2(var)=[var,var]; > > function vec3(var)=[var,var,var]; > > > // print the value and the boolean value of it > > > module print_boolean(var){ > > echo(var,var?true:false); > > } > > > // var > > > print_boolean(var_true); > > print_boolean(var_false); > > print_boolean(var_zero); > > print_boolean(var_number); > > print_boolean(var_negnumber); > > print_boolean(var_small); > > print_boolean(var_large); > > print_boolean(var_undef); > > print_boolean(var_inf); > > print_boolean(var_char); > > print_boolean(var_string); > > print_boolean(var_emptystring); > > > // echo -->> The boolean value of false, zero, undef, and empty > string gives false, everything else gives true > > > // 2-dim vector > > > print_boolean(vec2_true); > > print_boolean(vec2_false); > > print_boolean(vec2_zero); > > print_boolean(vec2_number); > > print_boolean(vec2_negnumber); > > print_boolean(vec2_small); > > print_boolean(vec2_large); > > print_boolean(vec2_undef); > > print_boolean(vec2_inf); > > print_boolean(vec2_char); > > print_boolean(vec2_string); > > print_boolean(vec2_emptystring); > > > // echo -->> The boolean value of any (!) 2-dim vector is always > true regardeless of its value > > > // 3-dim vector > > > print_boolean(vec3_true); > > print_boolean(vec3_false); > > print_boolean(vec3_zero); > > print_boolean(vec3_number); > > print_boolean(vec3_negnumber); > > print_boolean(vec3_small); > > print_boolean(vec3_large); > > print_boolean(vec3_undef); > > print_boolean(vec3_inf); > > print_boolean(vec3_char); > > print_boolean(vec3_string); > > print_boolean(vec3_emptystring); > > > // echo -->> The boolean value of any (!) 3-dim vector is always > true regardeless of its value > > > > _____________________________________ > > > Output: > > _____________________________________ > > > ECHO: true, true > > ECHO: false, false > > ECHO: 0, false > > ECHO: 3, true > > ECHO: -3, true > > ECHO: 4.94066e-324, true > > ECHO: 1.79769e+308, true > > ECHO: undef, false > > ECHO: inf, true > > ECHO: "a", true > > ECHO: "TEXT", true > > ECHO: "", false > > ECHO: [true, true], true > > ECHO: [false, false], true > > ECHO: [0, 0], true > > ECHO: [3, 3], true > > ECHO: [-3, -3], true > > ECHO: [4.94066e-324, 4.94066e-324], true > > ECHO: [1.79769e+308, 1.79769e+308], true > > ECHO: [undef, undef], true > > ECHO: [inf, inf], true > > ECHO: ["a", "a"], true > > ECHO: ["TEXT", "TEXT"], true > > ECHO: ["", ""], true > > ECHO: [true, true, true], true > > ECHO: [false, false, false], true > > ECHO: [0, 0, 0], true > > ECHO: [3, 3, 3], true > > ECHO: [-3, -3, -3], true > > ECHO: [4.94066e-324, 4.94066e-324, 4.94066e-324], true > > ECHO: [1.79769e+308, 1.79769e+308, 1.79769e+308], true > > ECHO: [undef, undef, undef], true > > ECHO: [inf, inf, inf], true > > ECHO: ["a", "a", "a"], true > > ECHO: ["TEXT", "TEXT", "TEXT"], true > > ECHO: ["", "", ""], true > > > > -- > stempeldergeschichte@googlemail.com <mailto:karsten@rohrbach.de> > > P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: > Ich probiere gerade aus kurze Antworten statt gar keine Antworten > zu schreiben. > Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. > > P.S. In case my e-mail is shorter than you enjoy: > I am currently trying short replies instead of no replies at all. > Please let me know, if you like to read more. > > Enjoy! > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org> > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > > No virus found in this message. > Checked by AVG - www.avg.com <http://www.avg.com> > Version: 2015.0.5751 / Virus Database: 4306/9317 - Release Date: 03/16/15 >
PF
Peter Falke
Mon, Mar 16, 2015 10:05 PM
So in the case of Boolean value:
Is there any use case for the Boolean of a vector?
Could the attempt of getting the Boolean of a vector lead to a WARNING:
wrong argument type ?
2015-03-16 22:57 GMT+01:00 nop head nop.head@gmail.com:
errors:
to a warning.
// GPLv2
// variables
var_true=true;
var_false=false;
var_zero=0;
var_number=3;
var_negnumber=-3;
var_inf=1/0;
var_char="a";
var_string="TEXT";
var_emptystring="";
// 2 dim-vectors
// 3 dim-vectors
// var
// 2-dim vector
// 3-dim vector
Output:
ECHO: true, true
ECHO: false, false
ECHO: 0, false
ECHO: 3, true
ECHO: -3, true
ECHO: undef, false
ECHO: inf, true
ECHO: "a", true
ECHO: "TEXT", true
ECHO: "", false
ECHO: [0, 0], true
ECHO: [3, 3], true
schreiben.
Enjoy!
schreiben.
Enjoy!
So in the case of Boolean value: Is there any use case for the Boolean of a vector? Could the attempt of getting the Boolean of a vector lead to a WARNING: wrong argument type ? 2015-03-16 22:57 GMT+01:00 nop head <nop.head@gmail.com>: > Only the first one could be called a syntax error. Other languages allow > trailing comma for lists sometimes as it makes extending the list easier. > > The rest are valid syntax but wrong argument type. > > On 16 March 2015 at 21:44, Peter Falke < > stempeldergeschichte@googlemail.com> wrote: > >> I'm very much worried by the way OpenSCAD treats what I call syntax >> errors: >> >> >> square([2,3,]); //works like square([2,3]); >> >> >> translate(1)circle();// translate() fails silently >> >> >> square([10,10,10]); // fails silently >> >> >> >> To remedy this I would like to initiate a discussion of what should be >> the expected behavior, what should lead to an error, and what should lead >> to a warning. >> >> >> To facilitate this discussion, I wrote a small program that, as a test >> case, lists all possible values a variable could take on. >> >> It than calls the module print_boolean() for all values which echos their >> value and its Boolean value. >> >> This program could then be used as a template for testing other calls >> (e.g. sphere(value);). >> >> >> Please have a look at it: Are there any other values that would be >> important to include as test cases? >> >> >> _____________________________________ >> >> // ----------------------------------------------------------------------- >> >> // >> >> // syntax_boolean_v0 >> >> // >> >> // List all possible values of vaiables to later >> >> // use them as a template to define and test the syntax >> >> // of (internal) module calls. >> >> // This is shown here for the boolean value, as an example. >> >> // >> >> // GPLv2 >> >> // (c) 2015 TakeItAndRun >> >> // >> >> // ----------------------------------------------------------------------- >> >> >> // variables >> >> >> var_true=true; >> >> var_false=false; >> >> var_zero=0; >> >> var_number=3; >> >> var_negnumber=-3; >> >> var_small=0.494066e-323; >> >> var_large=1.7976931348623158080999999e+308*1; >> >> var_undef=true*true; >> >> var_inf=1/0; >> >> var_char="a"; >> >> var_string="TEXT"; >> >> var_emptystring=""; >> >> >> // 2 dim-vectors >> >> >> vec2_true=vec2(var_true); >> >> vec2_false=vec2(var_false); >> >> vec2_zero=vec2(var_zero); >> >> vec2_number=vec2(var_number); >> >> vec2_negnumber=vec2(var_negnumber); >> >> vec2_small=vec2(var_small); >> >> vec2_large=vec2(var_large); >> >> vec2_undef=vec2(var_undef); >> >> vec2_inf=vec2(var_inf); >> >> vec2_char=vec2(var_char); >> >> vec2_string=vec2(var_string); >> >> vec2_emptystring=vec2(var_emptystring); >> >> >> // 3 dim-vectors >> >> >> vec3_true=vec3(var_true); >> >> vec3_false=vec3(var_false); >> >> vec3_zero=vec3(var_zero); >> >> vec3_number=vec3(var_number); >> >> vec3_negnumber=vec3(var_negnumber); >> >> vec3_small=vec3(var_small); >> >> vec3_large=vec3(var_large); >> >> vec3_undef=vec3(var_undef); >> >> vec3_inf=vec3(var_inf); >> >> vec3_char=vec3(var_char); >> >> vec3_string=vec3(var_string); >> >> vec3_emptystring=vec3(var_emptystring); >> >> >> // generate vectors from variables >> >> >> function vec2(var)=[var,var]; >> >> function vec3(var)=[var,var,var]; >> >> >> // print the value and the boolean value of it >> >> >> module print_boolean(var){ >> >> echo(var,var?true:false); >> >> } >> >> >> // var >> >> >> print_boolean(var_true); >> >> print_boolean(var_false); >> >> print_boolean(var_zero); >> >> print_boolean(var_number); >> >> print_boolean(var_negnumber); >> >> print_boolean(var_small); >> >> print_boolean(var_large); >> >> print_boolean(var_undef); >> >> print_boolean(var_inf); >> >> print_boolean(var_char); >> >> print_boolean(var_string); >> >> print_boolean(var_emptystring); >> >> >> // echo -->> The boolean value of false, zero, undef, and empty string >> gives false, everything else gives true >> >> >> // 2-dim vector >> >> >> print_boolean(vec2_true); >> >> print_boolean(vec2_false); >> >> print_boolean(vec2_zero); >> >> print_boolean(vec2_number); >> >> print_boolean(vec2_negnumber); >> >> print_boolean(vec2_small); >> >> print_boolean(vec2_large); >> >> print_boolean(vec2_undef); >> >> print_boolean(vec2_inf); >> >> print_boolean(vec2_char); >> >> print_boolean(vec2_string); >> >> print_boolean(vec2_emptystring); >> >> >> // echo -->> The boolean value of any (!) 2-dim vector is always true >> regardeless of its value >> >> >> // 3-dim vector >> >> >> print_boolean(vec3_true); >> >> print_boolean(vec3_false); >> >> print_boolean(vec3_zero); >> >> print_boolean(vec3_number); >> >> print_boolean(vec3_negnumber); >> >> print_boolean(vec3_small); >> >> print_boolean(vec3_large); >> >> print_boolean(vec3_undef); >> >> print_boolean(vec3_inf); >> >> print_boolean(vec3_char); >> >> print_boolean(vec3_string); >> >> print_boolean(vec3_emptystring); >> >> >> // echo -->> The boolean value of any (!) 3-dim vector is always true >> regardeless of its value >> >> >> >> _____________________________________ >> >> >> Output: >> >> _____________________________________ >> >> >> ECHO: true, true >> >> ECHO: false, false >> >> ECHO: 0, false >> >> ECHO: 3, true >> >> ECHO: -3, true >> >> ECHO: 4.94066e-324, true >> >> ECHO: 1.79769e+308, true >> >> ECHO: undef, false >> >> ECHO: inf, true >> >> ECHO: "a", true >> >> ECHO: "TEXT", true >> >> ECHO: "", false >> >> ECHO: [true, true], true >> >> ECHO: [false, false], true >> >> ECHO: [0, 0], true >> >> ECHO: [3, 3], true >> >> ECHO: [-3, -3], true >> >> ECHO: [4.94066e-324, 4.94066e-324], true >> >> ECHO: [1.79769e+308, 1.79769e+308], true >> >> ECHO: [undef, undef], true >> >> ECHO: [inf, inf], true >> >> ECHO: ["a", "a"], true >> >> ECHO: ["TEXT", "TEXT"], true >> >> ECHO: ["", ""], true >> >> ECHO: [true, true, true], true >> >> ECHO: [false, false, false], true >> >> ECHO: [0, 0, 0], true >> >> ECHO: [3, 3, 3], true >> >> ECHO: [-3, -3, -3], true >> >> ECHO: [4.94066e-324, 4.94066e-324, 4.94066e-324], true >> >> ECHO: [1.79769e+308, 1.79769e+308, 1.79769e+308], true >> >> ECHO: [undef, undef, undef], true >> >> ECHO: [inf, inf, inf], true >> >> ECHO: ["a", "a", "a"], true >> >> ECHO: ["TEXT", "TEXT", "TEXT"], true >> >> ECHO: ["", "", ""], true >> >> >> -- >> stempeldergeschichte@googlemail.com <karsten@rohrbach.de> >> >> P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: >> Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu >> schreiben. >> Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. >> >> P.S. In case my e-mail is shorter than you enjoy: >> I am currently trying short replies instead of no replies at all. >> Please let me know, if you like to read more. >> >> Enjoy! >> >> _______________________________________________ >> OpenSCAD mailing list >> Discuss@lists.openscad.org >> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >> >> > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > -- stempeldergeschichte@googlemail.com <karsten@rohrbach.de> P.S. Falls meine E-Mail kürzer ausfällt als Dir angenehm ist: Ich probiere gerade aus kurze Antworten statt gar keine Antworten zu schreiben. Wenn Du gerne mehr lesen möchtest, dann lass es mich bitte wissen. P.S. In case my e-mail is shorter than you enjoy: I am currently trying short replies instead of no replies at all. Please let me know, if you like to read more. Enjoy!
Tue, Mar 17, 2015 12:15 AM
+1 from my earlier learning experience, this was one of the most frustrating
bits.
However it should be a Warning (or an option) not a fail.
With the new alert at the view window it will stand out.
View this message in context: http://forum.openscad.org/treatment-of-syntax-errors-in-OpenSCAD-tp12060p12067.html
jon_bondy wrote > In my opinion, having ANYTHING fail silently is a real problem. This is > one reason why people have trouble "getting into" OpenSCAD: no hints as > to what they have done wrong. +1 from my earlier learning experience, this was one of the most frustrating bits. However it should be a Warning (or an option) not a fail. With the new alert at the view window it will stand out. ----- Unless specifically shown otherwise above, my contribution is in the Public Domain; To the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. This work is published globally via the internet. :) Inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ -- View this message in context: http://forum.openscad.org/treatment-of-syntax-errors-in-OpenSCAD-tp12060p12067.html Sent from the OpenSCAD mailing list archive at Nabble.com.
PF
Peter Falke
Tue, Mar 17, 2015 5:00 PM
I cleaned up my code a bit: organized the corner cases in a vector, so that
you can easily loop over them.
Presently the Boolean value of a vector is always (!) true.
Is taking the Boolean of a vector a wrong argument error (or warning) or is
there a use case anyone could think about?
Would it make sense to logical or all elements of the vector and use this
at its Boolean value?
What could one do with this?
I cleaned up my code a bit: organized the corner cases in a vector, so that you can easily loop over them. Presently the Boolean value of a vector is always (!) true. Is taking the Boolean of a vector a wrong argument error (or warning) or is there a use case anyone could think about? Would it make sense to logical or all elements of the vector and use this at its Boolean value? What could one do with this?
C
clothbot
Tue, Mar 17, 2015 7:22 PM
Try this:
vec_empty=[];
print_boolean(vec_empty);
I get 'false'.
If a vector is not-empty it's not-false=true.
Andrew.
View this message in context: http://forum.openscad.org/treatment-of-syntax-errors-in-OpenSCAD-tp12060p12071.html
Try this: vec_empty=[]; print_boolean(vec_empty); I get 'false'. If a vector is not-empty it's not-false=true. Andrew. -- View this message in context: http://forum.openscad.org/treatment-of-syntax-errors-in-OpenSCAD-tp12060p12071.html Sent from the OpenSCAD mailing list archive at Nabble.com.
