Sorry title should be intersection broken in preview.
On 26 December 2016 at 13:01, nop head nop.head@gmail.com wrote:
A slightly modified version of Jon's code doesn't preview correctly with
OpenSCAD 2016,10,4
le = 10; // length
d1 = 25; // diameter of top
d2 = 35; // diameter of bottom
d = -8; // delta to drop center of bottom
$fn = 100;
z_offset = -6;
module shape() {
translate([0, 0, z_offset])
intersection(c) {
rotate([0, 90, 0])
#cylinder(h = le, d = d1, center = true);
translate([0, 0, d])
rotate([0, 90, 0])
cylinder(h = le + 2, d = d2, center = true);
//intersection() {
translate([10, 0, 0])
cylinder(h = 100, d = 30);
translate([-10, 0, 0])
echo(version());
shape();
F6 gives the correct shape but F5 doesn't unless the extra intersection is
enabled. Also the first cylinder should be highlighted but the difference
gets highlighted instead. Are these known bugs or should I open an issue?
That might be the same issue as reported in
https://github.com/openscad/openscad/issues/1803
Looks like it is because moving the difference to the end of the
intersection gives the correct preview.
