Does anyone know where customizer presets are stored?
Thanks,
Ken
I don't understand your question. What presets?
Kevin
Thanks,
Ken
Hi Ken,
When you talk about the customizer build in to the development snapshots
of openscad it self:
OpenSCAD takes the file name and replaces the .scad file ending with
.json and stores the presets it in that json file.
So: C:\user\myDesign.scad has its presets stored in C:\user\myDesign.json
It is the same with the examples that ship with openscad that have presets.
You can easily read the json with any text editor.
When you save your design with a different name (e.g.
d:\backup\test.scad), in theory it should also save the preset under the
new name (e.g. d:\backup\test.json),. (but I have not tested that in a
long time. It would be a bug if it does not, but things can break during
refactoring)
With kind regards,
Michael Frey
OK, thanks
On Wed, Nov 14, 2018 at 11:18 PM Michael Frey michael.frey@gmx.ch wrote:
Hi Ken,
OpenSCAD takes the file name and replaces the .scad file ending with .json
new name (e.g. d:\backup\test.json),. (but I have not tested that in a long
refactoring)
With kind regards,
Michael Frey
Also, you can save multiple settings / versions of settings under different
names --- I worked up the code for parsing this in lualatex/metapost if it
would help.
On Thu, Nov 15, 2018 at 8:51 AM Kevin Toppenberg kdtop3@gmail.com wrote:
OK, thanks
Hi Ken,
presets.
refactoring)
With kind regards,
Michael Frey
