Recursive Binary Chop
G
GregL
Sat, May 15, 2021 5:09 PM
I had a complicated function to calculate an area according to its one
argument. The function was monotonic.
There was then a need to find the argument value which gave a specific area
  • an inverse function was created.
    Its arguments are the input value to be looked up
    lowest start value and its function
    highest start value and its function
    required accuracy
InvFF performs a binary chop until the upper and lower values are within the
required accuracy
// test out with a simple inverse sin
// sin(T) goes between 0 and 1 for angles 0 : 90
// if we give the recursive function a number 0 : 1, we want the angle 0 :
90
function FF(A) = sin(A);
function InvFF(Value,LowArg,LowValue,HighArg,HighValue,Accuracy)
=  let(MidArg = (HighArg + LowArg)/2)
abs(HighValue - LowValue)/(HighValue + LowValue) < 2*Accuracy
?  MidArg                                    // Stop here with best
answer
:  FF(MidArg) > Value
? InvFF(Value,LowArg,LowValue,MidArg,FF(MidArg),Accuracy)    // too
high
: InvFF(Value,MidArg,FF(MidArg),HighArg,HighValue,Accuracy);  // too
low
LowestValue    =  0;      // for this test
HighestValue    =  90;    // for this test
// lookup the angle which gives a sine of 0.5 - ie 30 degrees
echo(InvFF(0.5, LowestValue, FF(LowestValue), HighestValue,
FF(HighestValue), 0.00001));
returns
ECHO: 29.9999
I had a complicated function to calculate an area according to its one argument. The function was monotonic. There was then a need to find the argument value which gave a specific area - an inverse function was created. Its arguments are the input value to be looked up lowest start value and its function highest start value and its function required accuracy InvFF performs a binary chop until the upper and lower values are within the required accuracy //---------------------------------------------------------------------------------------- // test out with a simple inverse sin // sin(T) goes between 0 and 1 for angles 0 : 90 // if we give the recursive function a number 0 : 1, we want the angle 0 : 90 //------------------------------------------------------------------------------- function FF(A) = sin(A); //------------------------------------------------------------------------------- function InvFF(Value,LowArg,LowValue,HighArg,HighValue,Accuracy) = let(MidArg = (HighArg + LowArg)/2) abs(HighValue - LowValue)/(HighValue + LowValue) < 2*Accuracy ? MidArg // Stop here with best answer : FF(MidArg) > Value ? InvFF(Value,LowArg,LowValue,MidArg,FF(MidArg),Accuracy) // too high : InvFF(Value,MidArg,FF(MidArg),HighArg,HighValue,Accuracy); // too low //------------------------------------------------------------------------------ LowestValue = 0; // for this test HighestValue = 90; // for this test // lookup the angle which gives a sine of 0.5 - ie 30 degrees echo(InvFF(0.5, LowestValue, FF(LowestValue), HighestValue, FF(HighestValue), 0.00001)); returns ECHO: 29.9999 -- Sent from: http://forum.openscad.org/
Sat, May 15, 2021 7:36 PM
Nice!
required accuracy
90
answer
high
too low
returns
ECHO: 29.9999
at Nabble.com.
Nice! On Sat, May 15, 2021 at 12:10 PM GregL <greg@leonardresearch.co.uk> wrote: > I had a complicated function to calculate an area according to its one > argument. The function was monotonic. > There was then a need to find the argument value which gave a specific > area - an inverse function was created. > Its arguments are the input value to be looked up > lowest start value and its function > highest start value and its function > required accuracy > > InvFF performs a binary chop until the upper and lower values are within > the required accuracy > > > //---------------------------------------------------------------------------------------- > > // test out with a simple inverse sin > // sin(T) goes between 0 and 1 for angles 0 : 90 > // if we give the recursive function a number 0 : 1, we want the angle 0 : > 90 > //------------------------------------------------------------------------------- > > function FF(A) = sin(A); > //------------------------------------------------------------------------------- > > function InvFF(Value,LowArg,LowValue,HighArg,HighValue,Accuracy) > = let(MidArg = (HighArg + LowArg)/2) > abs(HighValue - LowValue)/(HighValue + LowValue) < 2*Accuracy > ? MidArg // Stop here with best > answer > : FF(MidArg) > Value > ? InvFF(Value,LowArg,LowValue,MidArg,FF(MidArg),Accuracy) // too > high > : InvFF(Value,MidArg,FF(MidArg),HighArg,HighValue,Accuracy); // > too low > //------------------------------------------------------------------------------ > > LowestValue = 0; // for this test > HighestValue = 90; // for this test > // lookup the angle which gives a sine of 0.5 - ie 30 degrees > echo(InvFF(0.5, LowestValue, FF(LowestValue), HighestValue, > FF(HighestValue), 0.00001)); > > returns > ECHO: 29.9999 > > > ------------------------------ > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Sat, May 15, 2021 8:02 PM
Yes, nice, I have written one or two binary chops to do things like space
two pulleys for a closed belt, which surprisingly has no algebraic formula,
like the circumference of an ellipse. But it was before function literals,
so not generic.
On Sat, 15 May 2021 at 20:36, Leonard Martin Struttmann <
Nice!
required accuracy
: 90
answer
too high
too low
returns
ECHO: 29.9999
at Nabble.com.
Yes, nice, I have written one or two binary chops to do things like space two pulleys for a closed belt, which surprisingly has no algebraic formula, like the circumference of an ellipse. But it was before function literals, so not generic. On Sat, 15 May 2021 at 20:36, Leonard Martin Struttmann < lenstruttmann@gmail.com> wrote: > Nice! > > On Sat, May 15, 2021 at 12:10 PM GregL <greg@leonardresearch.co.uk> wrote: > >> I had a complicated function to calculate an area according to its one >> argument. The function was monotonic. >> There was then a need to find the argument value which gave a specific >> area - an inverse function was created. >> Its arguments are the input value to be looked up >> lowest start value and its function >> highest start value and its function >> required accuracy >> >> InvFF performs a binary chop until the upper and lower values are within >> the required accuracy >> >> >> //---------------------------------------------------------------------------------------- >> >> // test out with a simple inverse sin >> // sin(T) goes between 0 and 1 for angles 0 : 90 >> // if we give the recursive function a number 0 : 1, we want the angle 0 >> : 90 >> //------------------------------------------------------------------------------- >> >> function FF(A) = sin(A); >> //------------------------------------------------------------------------------- >> >> function InvFF(Value,LowArg,LowValue,HighArg,HighValue,Accuracy) >> = let(MidArg = (HighArg + LowArg)/2) >> abs(HighValue - LowValue)/(HighValue + LowValue) < 2*Accuracy >> ? MidArg // Stop here with best >> answer >> : FF(MidArg) > Value >> ? InvFF(Value,LowArg,LowValue,MidArg,FF(MidArg),Accuracy) // >> too high >> : InvFF(Value,MidArg,FF(MidArg),HighArg,HighValue,Accuracy); // >> too low >> //------------------------------------------------------------------------------ >> >> LowestValue = 0; // for this test >> HighestValue = 90; // for this test >> // lookup the angle which gives a sine of 0.5 - ie 30 degrees >> echo(InvFF(0.5, LowestValue, FF(LowestValue), HighestValue, >> FF(HighestValue), 0.00001)); >> >> returns >> ECHO: 29.9999 >> >> >> ------------------------------ >> Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> >> at Nabble.com. >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
CA
craig and heather
Sat, May 15, 2021 8:51 PM
Could someone define what a binary chop is?
so not generic.
Nice!
required accuracy
: 90
answer
too high
too low
returns
ECHO: 29.9999
at Nabble.com.
Craig Lindley / Heather Hubbard
New Recordings are here http://craigandheather.net/spellbound.html
Personal Website is here http://craigandheather.net
Please call the Rockrimmon house. Our cell phones don't work at home.
Rockrimmon House: (719) 426-9873
Craig's Cell: (719) 502-7925
Heather's Cell: (719) 571-0944
If you’re one in a million, there are now more than seven thousand people
exactly like you.
Could someone define what a binary chop is? On Sat, May 15, 2021 at 2:04 PM nop head <nop.head@gmail.com> wrote: > Yes, nice, I have written one or two binary chops to do things like space > two pulleys for a closed belt, which surprisingly has no algebraic formula, > like the circumference of an ellipse. But it was before function literals, > so not generic. > > On Sat, 15 May 2021 at 20:36, Leonard Martin Struttmann < > lenstruttmann@gmail.com> wrote: > >> Nice! >> >> On Sat, May 15, 2021 at 12:10 PM GregL <greg@leonardresearch.co.uk> >> wrote: >> >>> I had a complicated function to calculate an area according to its one >>> argument. The function was monotonic. >>> There was then a need to find the argument value which gave a specific >>> area - an inverse function was created. >>> Its arguments are the input value to be looked up >>> lowest start value and its function >>> highest start value and its function >>> required accuracy >>> >>> InvFF performs a binary chop until the upper and lower values are within >>> the required accuracy >>> >>> >>> //---------------------------------------------------------------------------------------- >>> >>> // test out with a simple inverse sin >>> // sin(T) goes between 0 and 1 for angles 0 : 90 >>> // if we give the recursive function a number 0 : 1, we want the angle 0 >>> : 90 >>> //------------------------------------------------------------------------------- >>> >>> function FF(A) = sin(A); >>> //------------------------------------------------------------------------------- >>> >>> function InvFF(Value,LowArg,LowValue,HighArg,HighValue,Accuracy) >>> = let(MidArg = (HighArg + LowArg)/2) >>> abs(HighValue - LowValue)/(HighValue + LowValue) < 2*Accuracy >>> ? MidArg // Stop here with best >>> answer >>> : FF(MidArg) > Value >>> ? InvFF(Value,LowArg,LowValue,MidArg,FF(MidArg),Accuracy) // >>> too high >>> : InvFF(Value,MidArg,FF(MidArg),HighArg,HighValue,Accuracy); // >>> too low >>> //------------------------------------------------------------------------------ >>> >>> LowestValue = 0; // for this test >>> HighestValue = 90; // for this test >>> // lookup the angle which gives a sine of 0.5 - ie 30 degrees >>> echo(InvFF(0.5, LowestValue, FF(LowestValue), HighestValue, >>> FF(HighestValue), 0.00001)); >>> >>> returns >>> ECHO: 29.9999 >>> >>> >>> ------------------------------ >>> Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> >>> at Nabble.com. >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > -- Craig Lindley / Heather Hubbard New Recordings are here <http://craigandheather.net/spellbound.html> Personal Website is here <http://craigandheather.net> Please call the Rockrimmon house. Our cell phones don't work at home. Rockrimmon House: (719) 426-9873 Craig's Cell: (719) 502-7925 Heather's Cell: (719) 571-0944 If you’re one in a million, there are now more than seven thousand people exactly like you.
Sat, May 15, 2021 9:57 PM
You start with two extreme values that you assume to be either side of the
solution. Then you pick the midpoint and decide if the solution is between
the first point and the mid or the mid and the second, so you get a smaller
range for the solution and then recurse until the ends points are close
enough for your desired accuracy.
so not generic.
Nice!
required accuracy
0 : 90
best answer
too high
too low
returns
ECHO: 29.9999
exactly like you.
You start with two extreme values that you assume to be either side of the solution. Then you pick the midpoint and decide if the solution is between the first point and the mid or the mid and the second, so you get a smaller range for the solution and then recurse until the ends points are close enough for your desired accuracy. On Sat, 15 May 2021 at 21:51, craig and heather <calhjh@gmail.com> wrote: > Could someone define what a binary chop is? > > On Sat, May 15, 2021 at 2:04 PM nop head <nop.head@gmail.com> wrote: > >> Yes, nice, I have written one or two binary chops to do things like space >> two pulleys for a closed belt, which surprisingly has no algebraic formula, >> like the circumference of an ellipse. But it was before function literals, >> so not generic. >> >> On Sat, 15 May 2021 at 20:36, Leonard Martin Struttmann < >> lenstruttmann@gmail.com> wrote: >> >>> Nice! >>> >>> On Sat, May 15, 2021 at 12:10 PM GregL <greg@leonardresearch.co.uk> >>> wrote: >>> >>>> I had a complicated function to calculate an area according to its one >>>> argument. The function was monotonic. >>>> There was then a need to find the argument value which gave a specific >>>> area - an inverse function was created. >>>> Its arguments are the input value to be looked up >>>> lowest start value and its function >>>> highest start value and its function >>>> required accuracy >>>> >>>> InvFF performs a binary chop until the upper and lower values are >>>> within the required accuracy >>>> >>>> >>>> //---------------------------------------------------------------------------------------- >>>> >>>> // test out with a simple inverse sin >>>> // sin(T) goes between 0 and 1 for angles 0 : 90 >>>> // if we give the recursive function a number 0 : 1, we want the angle >>>> 0 : 90 >>>> //------------------------------------------------------------------------------- >>>> >>>> function FF(A) = sin(A); >>>> //------------------------------------------------------------------------------- >>>> >>>> function InvFF(Value,LowArg,LowValue,HighArg,HighValue,Accuracy) >>>> = let(MidArg = (HighArg + LowArg)/2) >>>> abs(HighValue - LowValue)/(HighValue + LowValue) < 2*Accuracy >>>> ? MidArg // Stop here with >>>> best answer >>>> : FF(MidArg) > Value >>>> ? InvFF(Value,LowArg,LowValue,MidArg,FF(MidArg),Accuracy) // >>>> too high >>>> : InvFF(Value,MidArg,FF(MidArg),HighArg,HighValue,Accuracy); // >>>> too low >>>> //------------------------------------------------------------------------------ >>>> >>>> LowestValue = 0; // for this test >>>> HighestValue = 90; // for this test >>>> // lookup the angle which gives a sine of 0.5 - ie 30 degrees >>>> echo(InvFF(0.5, LowestValue, FF(LowestValue), HighestValue, >>>> FF(HighestValue), 0.00001)); >>>> >>>> returns >>>> ECHO: 29.9999 >>>> >>>> >>>> ------------------------------ >>>> Sent from the OpenSCAD mailing list archive >>>> <http://forum.openscad.org/> at Nabble.com. >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > > > -- > Craig Lindley / Heather Hubbard > > New Recordings are here <http://craigandheather.net/spellbound.html> > > Personal Website is here <http://craigandheather.net> > > Please call the Rockrimmon house. Our cell phones don't work at home. > Rockrimmon House: (719) 426-9873 > Craig's Cell: (719) 502-7925 > Heather's Cell: (719) 571-0944 > > If you’re one in a million, there are now more than seven thousand people > exactly like you. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
CA
craig and heather
Sat, May 15, 2021 10:12 PM
OK I've always called this a binary search. The term binary chop is new to
me. Thanks for enlightening me.
Nice!
required accuracy
0 : 90
best answer
too high
// too low
returns
ECHO: 29.9999
exactly like you.
exactly like you.
OK I've always called this a binary search. The term binary chop is new to me. Thanks for enlightening me. On Sat, May 15, 2021 at 3:58 PM nop head <nop.head@gmail.com> wrote: > You start with two extreme values that you assume to be either side of the > solution. Then you pick the midpoint and decide if the solution is between > the first point and the mid or the mid and the second, so you get a smaller > range for the solution and then recurse until the ends points are close > enough for your desired accuracy. > > On Sat, 15 May 2021 at 21:51, craig and heather <calhjh@gmail.com> wrote: > >> Could someone define what a binary chop is? >> >> On Sat, May 15, 2021 at 2:04 PM nop head <nop.head@gmail.com> wrote: >> >>> Yes, nice, I have written one or two binary chops to do things like >>> space two pulleys for a closed belt, which surprisingly has no >>> algebraic formula, like the circumference of an ellipse. But it was before >>> function literals, so not generic. >>> >>> On Sat, 15 May 2021 at 20:36, Leonard Martin Struttmann < >>> lenstruttmann@gmail.com> wrote: >>> >>>> Nice! >>>> >>>> On Sat, May 15, 2021 at 12:10 PM GregL <greg@leonardresearch.co.uk> >>>> wrote: >>>> >>>>> I had a complicated function to calculate an area according to its one >>>>> argument. The function was monotonic. >>>>> There was then a need to find the argument value which gave a specific >>>>> area - an inverse function was created. >>>>> Its arguments are the input value to be looked up >>>>> lowest start value and its function >>>>> highest start value and its function >>>>> required accuracy >>>>> >>>>> InvFF performs a binary chop until the upper and lower values are >>>>> within the required accuracy >>>>> >>>>> >>>>> //---------------------------------------------------------------------------------------- >>>>> >>>>> // test out with a simple inverse sin >>>>> // sin(T) goes between 0 and 1 for angles 0 : 90 >>>>> // if we give the recursive function a number 0 : 1, we want the angle >>>>> 0 : 90 >>>>> //------------------------------------------------------------------------------- >>>>> >>>>> function FF(A) = sin(A); >>>>> //------------------------------------------------------------------------------- >>>>> >>>>> function InvFF(Value,LowArg,LowValue,HighArg,HighValue,Accuracy) >>>>> = let(MidArg = (HighArg + LowArg)/2) >>>>> abs(HighValue - LowValue)/(HighValue + LowValue) < 2*Accuracy >>>>> ? MidArg // Stop here with >>>>> best answer >>>>> : FF(MidArg) > Value >>>>> ? InvFF(Value,LowArg,LowValue,MidArg,FF(MidArg),Accuracy) // >>>>> too high >>>>> : InvFF(Value,MidArg,FF(MidArg),HighArg,HighValue,Accuracy); >>>>> // too low >>>>> //------------------------------------------------------------------------------ >>>>> >>>>> LowestValue = 0; // for this test >>>>> HighestValue = 90; // for this test >>>>> // lookup the angle which gives a sine of 0.5 - ie 30 degrees >>>>> echo(InvFF(0.5, LowestValue, FF(LowestValue), HighestValue, >>>>> FF(HighestValue), 0.00001)); >>>>> >>>>> returns >>>>> ECHO: 29.9999 >>>>> >>>>> >>>>> ------------------------------ >>>>> Sent from the OpenSCAD mailing list archive >>>>> <http://forum.openscad.org/> at Nabble.com. >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>>> >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >> >> >> -- >> Craig Lindley / Heather Hubbard >> >> New Recordings are here <http://craigandheather.net/spellbound.html> >> >> Personal Website is here <http://craigandheather.net> >> >> Please call the Rockrimmon house. Our cell phones don't work at home. >> Rockrimmon House: (719) 426-9873 >> Craig's Cell: (719) 502-7925 >> Heather's Cell: (719) 571-0944 >> >> If you’re one in a million, there are now more than seven thousand people >> exactly like you. >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org > -- Craig Lindley / Heather Hubbard New Recordings are here <http://craigandheather.net/spellbound.html> Personal Website is here <http://craigandheather.net> Please call the Rockrimmon house. Our cell phones don't work at home. Rockrimmon House: (719) 426-9873 Craig's Cell: (719) 502-7925 Heather's Cell: (719) 571-0944 If you’re one in a million, there are now more than seven thousand people exactly like you.
Sat, May 15, 2021 11:28 PM
I think the standard name for this algorithm in the context of root finding
is Bisection.  I've never heard "binary chop" before and "binary search" to
me refers to searching a sorted list, not root finding.
https://en.wikipedia.org/wiki/Bisection_method
The spacing for two pulleys seems like a problem that does have a closed
form solution.  I worked out math to make models like the one below with
varying radii at each end and separation and it was all simple trig.
http://forum.openscad.org/file/t2477/belt.png
nop.head@
between
smaller
calhjh@
nop.head@
before
lenstruttmann@
Nice!
greg@.co
one
specific
required accuracy
angle
0 : 90
best answer
too high
// too low
returns
ECHO: 29.9999
discuss-leave@.openscad
people
exactly like you.
exactly like you.
I think the standard name for this algorithm in the context of root finding is Bisection. I've never heard "binary chop" before and "binary search" to me refers to searching a sorted list, not root finding. https://en.wikipedia.org/wiki/Bisection_method The spacing for two pulleys seems like a problem that does have a closed form solution. I worked out math to make models like the one below with varying radii at each end and separation and it was all simple trig. <http://forum.openscad.org/file/t2477/belt.png> CraigLindley wrote > OK I've always called this a binary search. The term binary chop is new to > me. Thanks for enlightening me. > > On Sat, May 15, 2021 at 3:58 PM nop head &lt; > nop.head@ > &gt; wrote: > >> You start with two extreme values that you assume to be either side of >> the >> solution. Then you pick the midpoint and decide if the solution is >> between >> the first point and the mid or the mid and the second, so you get a >> smaller >> range for the solution and then recurse until the ends points are close >> enough for your desired accuracy. >> >> On Sat, 15 May 2021 at 21:51, craig and heather &lt; > calhjh@ > &gt; wrote: >> >>> Could someone define what a binary chop is? >>> >>> On Sat, May 15, 2021 at 2:04 PM nop head &lt; > nop.head@ > &gt; wrote: >>> >>>> Yes, nice, I have written one or two binary chops to do things like >>>> space two pulleys for a closed belt, which surprisingly has no >>>> algebraic formula, like the circumference of an ellipse. But it was >>>> before >>>> function literals, so not generic. >>>> >>>> On Sat, 15 May 2021 at 20:36, Leonard Martin Struttmann < >>>> > lenstruttmann@ >> wrote: >>>> >>>>> Nice! >>>>> >>>>> On Sat, May 15, 2021 at 12:10 PM GregL &lt; > greg@.co > &gt; >>>>> wrote: >>>>> >>>>>> I had a complicated function to calculate an area according to its >>>>>> one >>>>>> argument. The function was monotonic. >>>>>> There was then a need to find the argument value which gave a >>>>>> specific >>>>>> area - an inverse function was created. >>>>>> Its arguments are the input value to be looked up >>>>>> lowest start value and its function >>>>>> highest start value and its function >>>>>> required accuracy >>>>>> >>>>>> InvFF performs a binary chop until the upper and lower values are >>>>>> within the required accuracy >>>>>> >>>>>> >>>>>> //---------------------------------------------------------------------------------------- >>>>>> >>>>>> // test out with a simple inverse sin >>>>>> // sin(T) goes between 0 and 1 for angles 0 : 90 >>>>>> // if we give the recursive function a number 0 : 1, we want the >>>>>> angle >>>>>> 0 : 90 >>>>>> //------------------------------------------------------------------------------- >>>>>> >>>>>> function FF(A) = sin(A); >>>>>> //------------------------------------------------------------------------------- >>>>>> >>>>>> function InvFF(Value,LowArg,LowValue,HighArg,HighValue,Accuracy) >>>>>> = let(MidArg = (HighArg + LowArg)/2) >>>>>> abs(HighValue - LowValue)/(HighValue + LowValue) < 2*Accuracy >>>>>> ? MidArg // Stop here with >>>>>> best answer >>>>>> : FF(MidArg) > Value >>>>>> ? InvFF(Value,LowArg,LowValue,MidArg,FF(MidArg),Accuracy) >>>>>> // >>>>>> too high >>>>>> : InvFF(Value,MidArg,FF(MidArg),HighArg,HighValue,Accuracy); >>>>>> // too low >>>>>> //------------------------------------------------------------------------------ >>>>>> >>>>>> LowestValue = 0; // for this test >>>>>> HighestValue = 90; // for this test >>>>>> // lookup the angle which gives a sine of 0.5 - ie 30 degrees >>>>>> echo(InvFF(0.5, LowestValue, FF(LowestValue), HighestValue, >>>>>> FF(HighestValue), 0.00001)); >>>>>> >>>>>> returns >>>>>> ECHO: 29.9999 >>>>>> >>>>>> >>>>>> ------------------------------ >>>>>> Sent from the OpenSCAD mailing list archive >>>>>> &lt;http://forum.openscad.org/&gt; at Nabble.com. >>>>>> _______________________________________________ >>>>>> OpenSCAD mailing list >>>>>> To unsubscribe send an email to > discuss-leave@.openscad >>>>>> >>>>> _______________________________________________ >>>>> OpenSCAD mailing list >>>>> To unsubscribe send an email to > discuss-leave@.openscad >>>>> >>>> _______________________________________________ >>>> OpenSCAD mailing list >>>> To unsubscribe send an email to > discuss-leave@.openscad >>>> >>> >>> >>> -- >>> Craig Lindley / Heather Hubbard >>> >>> New Recordings are here >>> &lt;http://craigandheather.net/spellbound.html&gt; >>> >>> Personal Website is here &lt;http://craigandheather.net&gt; >>> >>> Please call the Rockrimmon house. Our cell phones don't work at home. >>> Rockrimmon House: (719) 426-9873 >>> Craig's Cell: (719) 502-7925 >>> Heather's Cell: (719) 571-0944 >>> >>> If you’re one in a million, there are now more than seven thousand >>> people >>> exactly like you. >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to > discuss-leave@.openscad >>> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to > discuss-leave@.openscad >> > > > -- > Craig Lindley / Heather Hubbard > > New Recordings are here &lt;http://craigandheather.net/spellbound.html&gt; > > Personal Website is here &lt;http://craigandheather.net&gt; > > Please call the Rockrimmon house. Our cell phones don't work at home. > Rockrimmon House: (719) 426-9873 > Craig's Cell: (719) 502-7925 > Heather's Cell: (719) 571-0944 > > If you’re one in a million, there are now more than seven thousand people > exactly like you. > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to > discuss-leave@.openscad -- Sent from: http://forum.openscad.org/
CH
Colin Hercus
Mon, May 17, 2021 1:53 PM
Binary chop can work for this but Newton Raphson should do it in less
iterations  https://en.wikipedia.org/wiki/Newton%27s_method
required accuracy
90
answer
high
too low
returns
ECHO: 29.9999
at Nabble.com.
Binary chop can work for this but Newton Raphson should do it in less iterations https://en.wikipedia.org/wiki/Newton%27s_method On Sun, May 16, 2021 at 1:09 AM GregL <greg@leonardresearch.co.uk> wrote: > I had a complicated function to calculate an area according to its one > argument. The function was monotonic. > There was then a need to find the argument value which gave a specific > area - an inverse function was created. > Its arguments are the input value to be looked up > lowest start value and its function > highest start value and its function > required accuracy > > InvFF performs a binary chop until the upper and lower values are within > the required accuracy > > > //---------------------------------------------------------------------------------------- > > // test out with a simple inverse sin > // sin(T) goes between 0 and 1 for angles 0 : 90 > // if we give the recursive function a number 0 : 1, we want the angle 0 : > 90 > //------------------------------------------------------------------------------- > > function FF(A) = sin(A); > //------------------------------------------------------------------------------- > > function InvFF(Value,LowArg,LowValue,HighArg,HighValue,Accuracy) > = let(MidArg = (HighArg + LowArg)/2) > abs(HighValue - LowValue)/(HighValue + LowValue) < 2*Accuracy > ? MidArg // Stop here with best > answer > : FF(MidArg) > Value > ? InvFF(Value,LowArg,LowValue,MidArg,FF(MidArg),Accuracy) // too > high > : InvFF(Value,MidArg,FF(MidArg),HighArg,HighValue,Accuracy); // > too low > //------------------------------------------------------------------------------ > > LowestValue = 0; // for this test > HighestValue = 90; // for this test > // lookup the angle which gives a sine of 0.5 - ie 30 degrees > echo(InvFF(0.5, LowestValue, FF(LowestValue), HighestValue, > FF(HighestValue), 0.00001)); > > returns > ECHO: 29.9999 > > > ------------------------------ > Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> > at Nabble.com. > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Mon, May 17, 2021 2:27 PM
But you need the derivative of the function for Newton Raphson.
required accuracy
: 90
answer
too high
too low
returns
ECHO: 29.9999
at Nabble.com.
But you need the derivative of the function for Newton Raphson. On Mon, 17 May 2021 at 14:54, Colin Hercus <colinhercus@gmail.com> wrote: > Binary chop can work for this but Newton Raphson should do it in less > iterations https://en.wikipedia.org/wiki/Newton%27s_method > > On Sun, May 16, 2021 at 1:09 AM GregL <greg@leonardresearch.co.uk> wrote: > >> I had a complicated function to calculate an area according to its one >> argument. The function was monotonic. >> There was then a need to find the argument value which gave a specific >> area - an inverse function was created. >> Its arguments are the input value to be looked up >> lowest start value and its function >> highest start value and its function >> required accuracy >> >> InvFF performs a binary chop until the upper and lower values are within >> the required accuracy >> >> >> //---------------------------------------------------------------------------------------- >> >> // test out with a simple inverse sin >> // sin(T) goes between 0 and 1 for angles 0 : 90 >> // if we give the recursive function a number 0 : 1, we want the angle 0 >> : 90 >> //------------------------------------------------------------------------------- >> >> function FF(A) = sin(A); >> //------------------------------------------------------------------------------- >> >> function InvFF(Value,LowArg,LowValue,HighArg,HighValue,Accuracy) >> = let(MidArg = (HighArg + LowArg)/2) >> abs(HighValue - LowValue)/(HighValue + LowValue) < 2*Accuracy >> ? MidArg // Stop here with best >> answer >> : FF(MidArg) > Value >> ? InvFF(Value,LowArg,LowValue,MidArg,FF(MidArg),Accuracy) // >> too high >> : InvFF(Value,MidArg,FF(MidArg),HighArg,HighValue,Accuracy); // >> too low >> //------------------------------------------------------------------------------ >> >> LowestValue = 0; // for this test >> HighestValue = 90; // for this test >> // lookup the angle which gives a sine of 0.5 - ie 30 degrees >> echo(InvFF(0.5, LowestValue, FF(LowestValue), HighestValue, >> FF(HighestValue), 0.00001)); >> >> returns >> ECHO: 29.9999 >> >> >> ------------------------------ >> Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> >> at Nabble.com. >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
CH
Colin Hercus
Mon, May 17, 2021 2:33 PM
You don't. You work out the slope from your two initial values.
required accuracy
: 90
answer
too high
too low
returns
ECHO: 29.9999
at Nabble.com.
You don't. You work out the slope from your two initial values. On Mon, May 17, 2021 at 10:27 PM nop head <nop.head@gmail.com> wrote: > But you need the derivative of the function for Newton Raphson. > > On Mon, 17 May 2021 at 14:54, Colin Hercus <colinhercus@gmail.com> wrote: > >> Binary chop can work for this but Newton Raphson should do it in less >> iterations https://en.wikipedia.org/wiki/Newton%27s_method >> >> On Sun, May 16, 2021 at 1:09 AM GregL <greg@leonardresearch.co.uk> wrote: >> >>> I had a complicated function to calculate an area according to its one >>> argument. The function was monotonic. >>> There was then a need to find the argument value which gave a specific >>> area - an inverse function was created. >>> Its arguments are the input value to be looked up >>> lowest start value and its function >>> highest start value and its function >>> required accuracy >>> >>> InvFF performs a binary chop until the upper and lower values are within >>> the required accuracy >>> >>> >>> //---------------------------------------------------------------------------------------- >>> >>> // test out with a simple inverse sin >>> // sin(T) goes between 0 and 1 for angles 0 : 90 >>> // if we give the recursive function a number 0 : 1, we want the angle 0 >>> : 90 >>> //------------------------------------------------------------------------------- >>> >>> function FF(A) = sin(A); >>> //------------------------------------------------------------------------------- >>> >>> function InvFF(Value,LowArg,LowValue,HighArg,HighValue,Accuracy) >>> = let(MidArg = (HighArg + LowArg)/2) >>> abs(HighValue - LowValue)/(HighValue + LowValue) < 2*Accuracy >>> ? MidArg // Stop here with best >>> answer >>> : FF(MidArg) > Value >>> ? InvFF(Value,LowArg,LowValue,MidArg,FF(MidArg),Accuracy) // >>> too high >>> : InvFF(Value,MidArg,FF(MidArg),HighArg,HighValue,Accuracy); // >>> too low >>> //------------------------------------------------------------------------------ >>> >>> LowestValue = 0; // for this test >>> HighestValue = 90; // for this test >>> // lookup the angle which gives a sine of 0.5 - ie 30 degrees >>> echo(InvFF(0.5, LowestValue, FF(LowestValue), HighestValue, >>> FF(HighestValue), 0.00001)); >>> >>> returns >>> ECHO: 29.9999 >>> >>> >>> ------------------------------ >>> Sent from the OpenSCAD mailing list archive <http://forum.openscad.org/> >>> at Nabble.com. >>> _______________________________________________ >>> OpenSCAD mailing list >>> To unsubscribe send an email to discuss-leave@lists.openscad.org >>> >> _______________________________________________ >> OpenSCAD mailing list >> To unsubscribe send an email to discuss-leave@lists.openscad.org >> > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
