Re: [OpenSCAD] STL Exports: Many need repair and I can't tell why
jpmendes
Sun, Mar 13, 2016 9:03 PM
Not necessarily. It is common OpenSCAD models to have to be repaired before
slicing them.
You may try repairing with the free MeshLab, or online using the Netfab
online service:
https://modelrepair.azurewebsites.net/
Usually it works.
On the other hand if you need to render and export an union of previously
generated STLs with malformations, usually that will not be so simple and I
can't help you, maybe someone in the forum with wider experience can.
jpmendes
View this message in context: http://forum.openscad.org/STL-Exports-Many-need-repair-and-I-can-t-tell-why-tp16463p16469.html
Not necessarily. It is common OpenSCAD models to have to be repaired before slicing them. You may try repairing with the free MeshLab, or online using the Netfab online service: https://modelrepair.azurewebsites.net/ <https://modelrepair.azurewebsites.net/> Usually it works. On the other hand if you need to render and export an union of previously generated STLs with malformations, usually that will not be so simple and I can't help you, maybe someone in the forum with wider experience can. jpmendes -- View this message in context: http://forum.openscad.org/STL-Exports-Many-need-repair-and-I-can-t-tell-why-tp16463p16469.html Sent from the OpenSCAD mailing list archive at Nabble.com.
