First my apologies for replying with a massive wall of copied text the
other day.
I will be more careful or go quiet.
By the way, is everyone aware of the new discussion feature that has been
added to github?
It needs to be turned on on a project. I turned it on for PathBuilder.
Check it out.
https://github.com/dinther/pathbuilder/discussions
So Pathbuilder. Totally changed. It is now capable to take normal svg path
strings as well as work with module commands and it spits out a 2D point
list when you use path strings. Although, I haven't quite finished the
implementation of the arc command because rotated ellipse curves are
kicking my ass.
Yes, I had seen the GitHub discussions elsewhere.
It is on my list to play with.
If it looks OK, I want to have some debate in the development community regarding the right place to host it (ie repository).
From: Paul van Dinther [mailto:vandinther@gmail.com]
Sent: Sun, 26 Sep 2021 12:03
Subject: [OpenSCAD] Pathbuilder 0.8 has been uploaded.
First my apologies for replying with a massive wall of copied text the other day.
By the way, is everyone aware of the new discussion feature that has been added to github?
It needs to be turned on on a project. I turned it on for PathBuilder. Check it out.
So Pathbuilder. Totally changed. It is now capable to take normal svg path strings as well as work with module commands and it spits out a 2D point list when you use path strings. Although, I haven't quite finished the implementation of the arc command because rotated ellipse curves are kicking my ass.
a big Thank you!
It opens the open svg world into the Open-SCAD world. I am delighted!
Am So., 26. Sept. 2021 um 04:03 Uhr schrieb Paul van Dinther <
vandinther@gmail.com>:
other day.
added to github?
Check it out.
kicking my ass.
What licence does this have?
On Sun, 26 Sept 2021 at 11:24, dpa sc@pankd.de wrote:
a big Thank you!
other day.
added to github?
Check it out.
kicking my ass.
