JW
Joe Weinpert
Thu, May 5, 2022 6:49 PM
Is there a function that returns the minimum or maximum value within an
array of points?
Say there is an array of 200 points [[X,Y,Z],[X,Y,Z], ...] to make a path.
How could I get the minimum value of X or Y or Z from the array? How about
the maximum value?
array of points?
the maximum value?
Thu, May 5, 2022 7:00 PM
There is no native function for that. The native min() and max() functions
operate only on list of numbers. You should extract the appropriate
component of the points before calling any of them using list comprehension.
Em qui., 5 de mai. de 2022 15:50, Joe Weinpert joe.weinpert@gmail.com
escreveu:
array of points?
path. How could I get the minimum value of X or Y or Z from the array?
How about the maximum value?
Em qui., 5 de mai. de 2022 15:50, Joe Weinpert <joe.weinpert@gmail.com>
escreveu:
> array of points?
JG
Jonathan Gilbert
Thu, May 5, 2022 7:02 PM
I suppose you could do something akin to:
max( [for (p=path) p.x] );
or
min( [for (p=path) p.y] );
...adjusted, as needed (above completely untested).
array of points?
or
> array of points?
- Jon Gilbert
jong@jong.org / jgilbertsjc@gmail.com
Thu, May 5, 2022 7:51 PM
The BOSL2 function pointlist_bounds will do it.
On Thu, May 5, 2022 at 2:50 PM Joe Weinpert joe.weinpert@gmail.com wrote:
Is there a function that returns the minimum or maximum value within an array of points?
Say there is an array of 200 points [[X,Y,Z],[X,Y,Z], ...] to make a path. How could I get the minimum value of X or Y or Z from the array? How about the maximum value?
JW
Joe Weinpert
Thu, May 5, 2022 8:05 PM
Thanks. What you suggested worked perfectly.
minX = min([ for( i = shapeOuter ) i.x ]);
minY = min([ for( i = shapeOuter ) i.y ]);
echo( minX = minX );
echo( minY = minY );
or
array of points?
> or
>> array of points?
> - Jon Gilbert
BR
Bob Roos
Thu, May 5, 2022 8:08 PM
Hi Adrian,
yep. In vectors.scad
// Function: pointlist_bounds()
// Usage:
// pt_pair = pointlist_bounds(pts);
// Topics: Geometry, Bounding Boxes, Bounds
// Description:
// Finds the bounds containing all the points in pts which can be a list of points in any dimension.
// Returns a list of two items: a list of the minimums and a list of the maximums. For example, with
// 3d points [[MINX, MINY, MINZ], [MAXX, MAXY, MAXZ]]
// Arguments:
// pts = List of points.
Hi Adrian,
// Usage:
// Description:
// Finds the bounds containing all the points in `pts` which can be a list of points in any dimension.
// 3d points `[[MINX, MINY, MINZ], [MAXX, MAXY, MAXZ]]`
// Arguments:
have Fun,
Bob mailto:roosbob@wybatap.com
JW
Joe Weinpert
Thu, May 5, 2022 8:15 PM
Like the other suggestion from Jon Gilbert, this works perfectly, too.
Thanks. I spent some time earlier trying to find a function within BOSL2,
but there was so much to look through I posted the question and got two
great answers.
bounds = pointlist_bounds( shapeOuter );
echo( bounds = bounds );
ECHO: bounds = [[40.221, 6.25542], [106.812, 65.8355]]
great answers.
> array of points?
Thu, May 5, 2022 8:33 PM
If you have suggestions for how the BOSL2 docs can be improved so you
can find stuff you can also make a github issue for that. :) There
are some search features to search the docs. Some of the complex
functions have had doc clarifications driven by user feedback.
On Thu, May 5, 2022 at 4:15 PM Joe Weinpert joe.weinpert@gmail.com wrote:
Like the other suggestion from Jon Gilbert, this works perfectly, too. Thanks. I spent some time earlier trying to find a function within BOSL2, but there was so much to look through I posted the question and got two great answers.
JW
Joe Weinpert
Thu, May 5, 2022 8:58 PM
Reading the docs (and I do that a lot) tells me I am not geeky enough to
know the true purpose of this function or that function. I can understand
a lot, but not understand just as much. I do know that there are a yuuuge
number of functions making this a yuuuuuge library. In fact, when I
started using OpenSCAD a couple of months ago to help with things I could
not do with TinkerCAD, I almost it tossed it out ... until tripping across
BOSL which made OpenSCAD much easier and clearer to use.
great answers.
> great answers.
> an array of points?
Fri, May 6, 2022 12:51 AM
x_min=min(points*[1,0,0])
y_min=min(points*[0,1,0])
z_min=min(points*[0,0,1])
and similarly max should be faster I suppose
array of points?
> array of points?
