When a warning appears on the output pane, there is another message that pops
up at the top of the preview window. Is there a way to generate text in the
output pane such that I can get such a message at the top of the preview
window?
View this message in context: http://forum.openscad.org/Generating-my-own-warnings-tp20114.html
that pops up at the top of the preview window. Is there a way to
generate text in the output pane such that I can get such a message
at the top of the preview window?
I don't think that's possible. Right now the ECHO: prefix prevents
that. The dev snapshot will show the popup when assert() fails.
How does OpenSCAD determine what is a Warning and what is not? Does it look
for a new line? Colour? Particular tag?
View this message in context: http://forum.openscad.org/Generating-my-own-warnings-tp20114p20127.html
The message has WARNING: or ERROR: at the beginning.
Then this outputs the message.
void MainWindow::consoleOutput(const QString &msg)
QString qmsg;
if (msg.startsWith("WARNING:") || msg.startsWith("DEPRECATED:")) {
this->compileWarnings++;
qmsg = "<html>" + QT_HTML_ESCAPE(QString(msg)) + "</html>\n";
} else if (msg.startsWith("ERROR:")) {
this->compileErrors++;
else {
qmsg = msg;
QTextCursor c = this->console->textCursor();
c.movePosition(QTextCursor::End);
this->console->setTextCursor(c);
this->console->append(qmsg);
if (this->procevents) QApplication::processEvents();
After compile this does the message at the top:
void MainWindow::updateCompileResult()
if ((compileErrors == 0) && (compileWarnings == 0)) {
frameCompileResult->hide();
return;
Settings::Settings *s = Settings::Settings::inst();
if (!s->get(Settings::Settings::showWarningsIn3dView).toBool()) {
return;
QString msg;
if (compileErrors > 0) {
if (fileName.isEmpty()) {
msg = QString(_("Compile error."));
} else {
QFileInfo fileInfo(fileName);
msg = QString(_("Error while compiling '%1'.")).arg(fileInfo.fileName());
toolButtonCompileResultIcon->setIcon(QIcon(QString::fromUtf8(":/icons/information-icons-error.png")));
} else {
const char *fmt = ngettext("Compilation generated %1 warning.",
"Compilation generated %1 warnings.", compileWarnings);
msg = QString(fmt).arg(compileWarnings);
toolButtonCompileResultIcon->setIcon(QIcon(QString::fromUtf8(":/icons/information-icons-warning.png")));
QFontMetrics fm(labelCompileResultMessage->font());
int sizeIcon = std::max(12, std::min(32, fm.height()));
int sizeClose = std::max(10, std::min(32, fm.height()) - 4);
toolButtonCompileResultIcon->setIconSize(QSize(sizeIcon, sizeIcon));
toolButtonCompileResultClose->setIconSize(QSize(sizeClose, sizeClose));
msg += _(" For details see console window <\"#console\"> .");
labelCompileResultMessage->setText(msg);
frameCompileResult->show();
Both bits of code are here:
https://github.com/openscad/openscad/blob/1fd9f05b441e85d5f827ce96154ce79ca334ce32/src/mainwin.cc
View this message in context: http://forum.openscad.org/Generating-my-own-warnings-tp20114p20128.html
Beginning of what? How is the console output broken up? Is it a line? Some
arbitrary thing such that echo() cannot cause this to work? Why doesn't this
show up as a warning?
echo(str(chr(13),"WARNING: blah"));
View this message in context: http://forum.openscad.org/Generating-my-own-warnings-tp20114p20129.html
Beginning of what?
The error message in the application. eg
if (steps >= 10000) {
PRINTB("WARNING: Bad range parameter in for statement: too many elements
(%lu).", steps);
Some arbitrary thing such that echo() cannot cause this to work?
Correct, as tp3 mentioned above, "I don't think that's possible. Right now
that."
Why doesn't this show up as a warning?
Because it is the string 'ECHO: <cr>"
WARNING: blah" '
It begins with "ECHO:"
View this message in context: http://forum.openscad.org/Generating-my-own-warnings-tp20114p20130.html
Note that you can use HTML to highlight echo() output, see HTML references in
the wiki
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Other_Language_Features#Echo_Statements
View this message in context: http://forum.openscad.org/Generating-my-own-warnings-tp20114p20131.html
Thanks Michael. I do realize I can do my own highlighting. However, I would
like to make it such that if I have an issue, that it is visible at the top
of the GUI, making it immediately visible to the user in case it gets
scrolled off screen.
View this message in context: http://forum.openscad.org/Generating-my-own-warnings-tp20114p20151.html
You could stick a big 'ERROR' in the middle of the preview, using
color("magenta") %text("ERROR!",size=50);
That would be noticeable.
View this message in context: http://forum.openscad.org/Generating-my-own-warnings-tp20114p20153.html
I agree - this is what I prefer to do in the thingiverse customiser.
So when a parameter creates a weird result I can test for - I print a
warning as text in the scene.
E.g. if an angle results in self intersecting geometery...
View this message in context: http://forum.openscad.org/Generating-my-own-warnings-tp20114p20156.html
