A warning too far?
Mon, Feb 4, 2019 8:23 PM
WARNING: length() parameter could not be converted, in file global.scad,
line 104
v = is_undef(len(d)) ? [0, 0, d] : d;
I think this is the standard OpenSCAD idiom to test if a parameter is a
vector or a scalar. Is there any other way to do it?
I think it is sufficient that taking the length of a scalar gives undef and
using undef other than in is_undef() gives a warning, so you can't do it
accidentally.
WARNING: length() parameter could not be converted, in file global.scad, line 104 v = is_undef(len(d)) ? [0, 0, d] : d; I think this is the standard OpenSCAD idiom to test if a parameter is a vector or a scalar. Is there any other way to do it? I think it is sufficient that taking the length of a scalar gives undef and using undef other than in is_undef() gives a warning, so you can't do it accidentally.
Doug Moen
Mon, Feb 4, 2019 8:37 PM
Well, there is also this feature request:
https://github.com/openscad/openscad/issues/1584
global.scad, line 104>
a vector or a scalar. Is there any other way to do it?>
can't do it accidentally.> _________________________________________________
Well, there is also this feature request: https://github.com/openscad/openscad/issues/1584 On Mon, Feb 4, 2019, at 12:23 PM, nop head wrote: > WARNING: length() parameter could not be converted, in file > global.scad, line 104> > v = is_undef(len(d)) ? [0, 0, d] : d; > > I think this is the standard OpenSCAD idiom to test if a parameter is > a vector or a scalar. Is there any other way to do it?> > I think it is sufficient that taking the length of a scalar gives > undef and using undef other than in is_undef() gives a warning, so you > can't do it accidentally.> _________________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org
Mon, Feb 4, 2019 11:08 PM
I don't get this warning. Further, I tend to write:
v = len(d)?d:[0,0,d];
I didn't even know that is_undef() exists.
I don't get this warning. Further, I tend to write: v = len(d)?d:[0,0,d]; I didn't even know that is_undef() exists. -- Sent from: http://forum.openscad.org/
Tue, Feb 5, 2019 12:19 AM
is_undef is very new but had to be added because using undef is now a
warning.
If is_list() is added then I could live with this warning, otherwise I
can't because it breaks my library. This is a bleeding edge version
https://circleci.com/gh/openscad/openscad/1482#artifacts from today, if
you use that you will get the warning.
The new warnings and errors are very welcome but I update frequently from
master and nearly every change means I have to change my code. In this case
I don't know any way to implement this without the wall of warnings. As I
said before though I don't think this one actually adds anything. Also it
mentions length() but it should be len().
I think people will get a big shock when they update because it will give a
wall of warnings for typical old code. For example I was relying on zero
size cylinders and cubes, etc. Now I have to conditionally remove them.
is_undef is very new but had to be added because using undef is now a warning. If is_list() is added then I could live with this warning, otherwise I can't because it breaks my library. This is a bleeding edge version <https://circleci.com/gh/openscad/openscad/1482#artifacts> from today, if you use that you will get the warning. The new warnings and errors are very welcome but I update frequently from master and nearly every change means I have to change my code. In this case I don't know any way to implement this without the wall of warnings. As I said before though I don't think this one actually adds anything. Also it mentions length() but it should be len(). I think people will get a big shock when they update because it will give a wall of warnings for typical old code. For example I was relying on zero size cylinders and cubes, etc. Now I have to conditionally remove them. On Mon, 4 Feb 2019 at 23:11, Parkinbot <rudolf@digitaldocument.de> wrote: > I don't get this warning. Further, I tend to write: > > v = len(d)?d:[0,0,d]; > > I didn't even know that is_undef() exists. > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Tue, Feb 5, 2019 1:42 AM
warning.
Hmm?
You mean you can't say
    radius = (r != undef ) ? r : d/2;
I have lots of instances of that pattern, mostly for supplying
calculated defaults.  (And note:  while some are defaults for module
parameters and so could maybe be handled using the built-in parameter
defaulting mechanism, others are for vectors with optional elements.)
On 2/4/2019 4:19 PM, nop head wrote: > is_undef is very new but had to be added because using undef is now a > warning. Hmm? You mean you can't say     radius = (r != undef ) ? r : d/2; ? I have lots of instances of that pattern, mostly for supplying calculated defaults.  (And note:  while some are defaults for module parameters and so could maybe be handled using the built-in parameter defaulting mechanism, others are for vectors with optional elements.)
MF
Michael Frey
Tue, Feb 5, 2019 6:09 AM
warning.
I will look into implementing it ones I am finished with
https://github.com/openscad/openscad/pull/2757
anything.
It is hard to foresee the consequences of warnings.
(which is why I try to not change how openscad behaves, except for
outputing the warning)
is_undef was/is added, when I added the warning for undefined special
variables.
(which is confusing concept in its own rights - a variable can be
undefined or be defined as undefined which is not the same thing when it
comes to warnings. But at the end of the day, it was/is about preventing
typos in variable names)
The warning for undefined parameters is helpful in the context for the
geometry functions or other functions used as parameters for other
functions.
Having to find what caused an undef can be very hard, as previously,
giving undef into a function lead to it silently accept the undef as a
parameter and silently returning undef. Combine that with how openSCAD
functions need to be written and can get messy, when you iterate over a
vector, to create an other vector to create a bar diagramm.
My bad. I will fix that.
That is a complicated balance act. For newcomers (and new designs), it
will be useful, as a lot of complicated symptoms now create clear
warnings, when you write the code.
or you disable "check the parameter range for builtin modules" in the
advanced tab.
I know that this is a double edged sword.
I knew that this one could be problematic, as I was writing code where
negative cube sizes not leading to geometry was both used for the design
to work and at the same time it was confusing that I wanted 10 x 10, but
only got 5x5, because of an incorrect offset.
Maybe zero sized cubes should be allowed, but that leads to the
discussion why cube([1,1,0]) is not a square, which leads to the
discussion why
    a=1;
    b=0;
    union(){
        cube([a,a,a]);
        cube([a,a,b]);
results in a mixed 2D/3D warning. Put that in a more complex bit of
code, and you realize that the geometry warnings to not output
linenumbers, letalone a filename.
With kind regards,
Michael Frey
On 05.02.19 01:19, nop head wrote: > is_undef is very new but had to be added because using undef is now a > warning. > > If is_list() is added then I could live with this warning, otherwise I > can't because it breaks my library. I will look into implementing it ones I am finished with https://github.com/openscad/openscad/pull/2757 > The new warnings and errors are very welcome but I update frequently > from master and nearly every change means I have to change my code. In > this case I don't know any way to implement this without the wall of > warnings. As I said before though I don't think this one actually adds > anything. It is hard to foresee the consequences of warnings. (which is why I try to not change how openscad behaves, except for outputing the warning) is_undef was/is added, when I added the warning for undefined special variables. (which is confusing concept in its own rights - a variable can be undefined or be defined as undefined which is not the same thing when it comes to warnings. But at the end of the day, it was/is about preventing typos in variable names) The warning for undefined parameters is helpful in the context for the geometry functions or other functions used as parameters for other functions. Having to find what caused an undef can be very hard, as previously, giving undef into a function lead to it silently accept the undef as a parameter and silently returning undef. Combine that with how openSCAD functions need to be written and can get messy, when you iterate over a vector, to create an other vector to create a bar diagramm. > Also it mentions length() but it should be len(). My bad. I will fix that. > I think people will get a big shock when they update because it will > give a wall of warnings for typical old code. That is a complicated balance act. For newcomers (and new designs), it will be useful, as a lot of complicated symptoms now create clear warnings, when you write the code. > For example I was relying on zero size cylinders and cubes, etc. Now I > have to conditionally remove them. or you disable "check the parameter range for builtin modules" in the advanced tab. I know that this is a double edged sword. I knew that this one could be problematic, as I was writing code where negative cube sizes not leading to geometry was both used for the design to work and at the same time it was confusing that I wanted 10 x 10, but only got 5x5, because of an incorrect offset. Maybe zero sized cubes should be allowed, but that leads to the discussion why cube([1,1,0]) is not a square, which leads to the discussion why     a=1;     b=0;     union(){         cube([a,a,a]);         cube([a,a,b]);     } results in a mixed 2D/3D warning. Put that in a more complex bit of code, and you realize that the geometry warnings to not output linenumbers, letalone a filename. With kind regards, Michael Frey
MF
Michael Frey
Tue, Feb 5, 2019 6:35 PM
defined with undef
    a = undef;
    echo(a);
ECHO: undef
is not the same as undefined:
    echo(b);
WARNING: Ignoring unknown variable 'b', in file ./, line 1.
ECHO: undef
The first case will not cause a warning.
The second case will. (but it would still function as normal)
I do not know which case you have.
Do give a better example:
    module  test (d=1,r=undef){         radius = (r != undef ) ? r :
d/2;         circle(radius);     }     test(r=5);     translate([10,0])
    test(d=5);
that is fine.
this is also fine:
module test (d=1,r=undef){ radius = !is_undef(r) ? r : d/2;
circle(radius); } test(r=5); translate([10,0]) test(d=5);
This now causes one warning:
module test (d=1){ radius = !is_undef(r) ? r : d/2; circle(radius); }
WARNING: variable r not specified as parameter, in file openscad, line 6
This now causes two warnings:
    module  test (d=1){         radius = (r != undef ) ? r : d/2;
test(d=5);
WARNING: Ignoring unknown variable 'r', in file ./, line 2.
note that all four examples create the same geometry.
This are not really good examples to show what is_undef() is mend for.
On 05.02.19 02:42, Jordan Brown wrote: > > You mean you can't say > >     radius = (r != undef ) ? r : d/2; > > ? > defined with undef     a = undef;     echo(a); ECHO: undef is not the same as undefined:     echo(b); WARNING: Ignoring unknown variable 'b', in file ./, line 1. ECHO: undef The first case will not cause a warning. The second case will. (but it would still function as normal) I do not know which case you have. ---------------------- Do give a better example:     module  test (d=1,r=undef){         radius = (r != undef ) ? r : d/2;         circle(radius);     }     test(r=5);     translate([10,0])     test(d=5); that is fine. ----------------- this is also fine: module test (d=1,r=undef){ radius = !is_undef(r) ? r : d/2; circle(radius); } test(r=5); translate([10,0]) test(d=5); ----------------- This now causes one warning: module test (d=1){ radius = !is_undef(r) ? r : d/2; circle(radius); } test(r=5); translate([10,0]) test(d=5); WARNING: variable r not specified as parameter, in file openscad, line 6 ----------------- This now causes two warnings:     module  test (d=1){         radius = (r != undef ) ? r : d/2;         circle(radius);     }     test(r=5);     translate([10,0])     test(d=5); WARNING: variable r not specified as parameter, in file openscad, line 6 WARNING: Ignoring unknown variable 'r', in file ./, line 2. ----------------- note that all four examples create the same geometry. This are not really good examples to show what is_undef() is mend for.
MF
Michael Frey
Tue, Feb 5, 2019 9:42 PM
On 04.02.19 21:37, Doug Moen wrote: > Well, there is also this feature request: > https://github.com/openscad/openscad/issues/1584 here is the work in progress: https://github.com/openscad/openscad/pull/2762 https://github.com/openscad/openscad/pull/2761
Wed, Feb 6, 2019 2:20 AM
        circle(radius);
    test(r=5);
    translate([10,0])
    test(d=5);
that is fine.
Good. I could work with that. My variant is a little different; I don't
include the explicit defaulting to undef:
module test(r, d) {
	radius = (r != undef) ? r : d/2;
	circle(radius);
The intent is that you have to supply r or d. You could supply both, but
then d would be ignored. (And I suppose if I was being obsessive, I'd
have an assert to catch that.)  I can add an explicit "=undef" if I need to.
Not that anybody cares, but here's some of my source to produce a
segment of a circle https://en.wikipedia.org/wiki/Circular_segment
given some set of its parameters...
//             __E__
//       A-------D-------B
//      |        C        |
//          '-._____.-'
// r = CE, radius
// r1 = CD, distance from center to chord
// r2 = DE, distance from chord to circle
// c = AB, chord length
// arc = arc AEB, distance along arc
// angle = angle ACB
// I believe that given any two of those,
// you can get the rest.  However, I've
// only derived a few of the functions.
function _radius(r, r1, r2, c, arc, angle) =
    r != undef ? r :
    r1 != undef && r2 != undef ? r1+r2 :
    r2 != undef && c != undef ? c*c/(8*r2) + r2/2 :
    undef;
function _radius2(r, r1, r2, c, arc, angle) =
    r2 != undef ? r2 :
    r != undef && r1 != undef ? r - r1 :
    undef;
function _radius1(r, r1, r2, c, arc, angle) =
    r1 != undef ? r1 :
    r != undef && r2 != undef ? r - r2 :
    r2 != undef && c != undef ? c*c/(8*r2) - r2/2 :
    undef;
function _angle(r, r1, r2, c, arc, angle) =
    angle != undef ? angle :
    r1 != undef && c != undef ? 2*atan2(c/2, r1) :
    r2 != undef && c != undef ? 2*atan2(c/2, c*c/(8*r2) - r2/2) :
    undef;
module segment(r, r1, r2, c, arc, angle) {
    _r = _radius(r=r, r1=r1, r2=r2, c=c, arc=arc, angle=angle);
    _r1 = _radius1(r=_r, r1=r1, r2=r2, c=c, arc=arc, angle=angle);
        translate([0, -_r1]) circle(_r);
        translate([-_r, 0]) square(_r*2);
I don't use the same variable names that the Wikipedia article uses,
because I did the trig myself.  My trig was rusty so it was a lot of
work, but it beat my previous scheme of setting a tape measure to a
guestimated radius and swinging it to see if it matched the real-world
curve.
On 2/5/2019 10:35 AM, Michael Frey wrote: > > Do give a better example: > >     module  test (d=1,r=undef){ >         radius = (r != undef ) ? r : d/2; >         circle(radius); >     } > >     test(r=5); >     translate([10,0]) >     test(d=5); > > that is fine. > Good. I could work with that. My variant is a little different; I don't include the explicit defaulting to undef: module test(r, d) { radius = (r != undef) ? r : d/2; circle(radius); } The intent is that you have to supply r or d. You could supply both, but then d would be ignored. (And I suppose if I was being obsessive, I'd have an assert to catch that.)  I can add an explicit "=undef" if I need to. Not that anybody cares, but here's some of my source to produce a segment of a circle <https://en.wikipedia.org/wiki/Circular_segment> given some set of its parameters... // __E__ // .-' | '-. // .' | '. // A-------D-------B // ; | ; // | C | // : ; // \ / // '. .' // '-._____.-' // // r = CE, radius // r1 = CD, distance from center to chord // r2 = DE, distance from chord to circle // c = AB, chord length // arc = arc AEB, distance along arc // angle = angle ACB // // I believe that given any two of those, // you can get the rest. However, I've // only derived a few of the functions. // function _radius(r, r1, r2, c, arc, angle) = r != undef ? r : r1 != undef && r2 != undef ? r1+r2 : r2 != undef && c != undef ? c*c/(8*r2) + r2/2 : undef; function _radius2(r, r1, r2, c, arc, angle) = r2 != undef ? r2 : r != undef && r1 != undef ? r - r1 : undef; function _radius1(r, r1, r2, c, arc, angle) = r1 != undef ? r1 : r != undef && r2 != undef ? r - r2 : r2 != undef && c != undef ? c*c/(8*r2) - r2/2 : undef; function _angle(r, r1, r2, c, arc, angle) = angle != undef ? angle : r1 != undef && c != undef ? 2*atan2(c/2, r1) : r2 != undef && c != undef ? 2*atan2(c/2, c*c/(8*r2) - r2/2) : undef; module segment(r, r1, r2, c, arc, angle) { _r = _radius(r=r, r1=r1, r2=r2, c=c, arc=arc, angle=angle); _r1 = _radius1(r=_r, r1=r1, r2=r2, c=c, arc=arc, angle=angle); intersection() { translate([0, -_r1]) circle(_r); translate([-_r, 0]) square(_r*2); } } I don't use the same variable names that the Wikipedia article uses, because I did the trig myself.  My trig was rusty so it was a lot of work, but it beat my previous scheme of setting a tape measure to a guestimated radius and swinging it to see if it matched the real-world curve.
MF
Michael Frey
Wed, Feb 6, 2019 5:39 AM
 module test(r, d) {
 	circle(radius);
Just tested, that is also still fine.
If I remember correctly, the Ignoring Unknow Variable Warning for normal
variables also exists/existed in OpenSCAD 2015.
New is, that special variables now also cause the "Ignoring Unknow
Variable":
    https://github.com/openscad/openscad/issues/2468
    https://github.com/openscad/openscad/pull/2524
Some people relayed on that inconstancy and used undefined special
variables.
That is where is_undef came from:
    https://github.com/openscad/openscad/pull/2535
Very specific workaround for a very specific issue, but is_undef can
also be used for other purposes.
Special Variables still have a few inconsistency compared to normal
variables.
Looks interesting and well done.
Given that I am lazy, I usually tend to use a circle and difference,
which always gets messy, as I hand juggle variables.
wit kind regards,
Michael Frey
On 06.02.19 03:20, Jordan Brown wrote: > > Good. I could work with that. My variant is a little different; I > don't include the explicit defaulting to undef: > > module test(r, d) { > radius = (r != undef) ? r : d/2; > circle(radius); > } > Just tested, that is also still fine. If I remember correctly, the Ignoring Unknow Variable Warning for normal variables also exists/existed in OpenSCAD 2015. New is, that special variables now also cause the "Ignoring Unknow Variable":     https://github.com/openscad/openscad/issues/2468     https://github.com/openscad/openscad/pull/2524 Some people relayed on that inconstancy and used undefined special variables. That is where is_undef came from:     https://github.com/openscad/openscad/pull/2535 Very specific workaround for a very specific issue, but is_undef can also be used for other purposes. Special Variables still have a few inconsistency compared to normal variables. > Not that anybody cares, but here's some of my source to produce a > segment of a circle <https://en.wikipedia.org/wiki/Circular_segment> > given some set of its parameters... Looks interesting and well done. Given that I am lazy, I usually tend to use a circle and difference, which always gets messy, as I hand juggle variables. wit kind regards, Michael Frey
