Greetings all;
I have another of my wild hair ideas, and want to make a bearing seat
that will hold a 4" diameter plastic bearing nominally 9/32" out of
round. IOW, how do I nake a true, mathematically accurate eccentric in
openscad?
Thanks everybody.
-Ed Howdershelt (Author)
Can you give a bit more detail?
What hapens when you use scaling?
Do you have any code to show?
On 2021-04-27 9:50 p.m., Gene Heskett wrote:
Greetings all;
openscad?
Thanks everybody.
Cheers, Gene Heskett
Ron Wheeler
Artifact Software
438-345-3369
If it is an eccentric you want, as used in, say, Stephenson's valve
gear, then in your example, it will have a throw of 9/16 inch. so, make
a vertical stubby cylinder to hold your bearing (if you need to insert
the bearing) and translate it 9/32 inch in the x direction, say. The
centre that you need for the axle/whatever will be at the origin, so put
the axle there.
On 28/04/2021 02:50, Gene Heskett wrote:
Greetings all;
openscad?
Thanks everybody.
