Design/Reload and Preview
Fri, Jul 29, 2016 7:08 AM
Is F4 meant to /only/ reload if the source file has changed, as it  does now?
If there are unsaved changes in the editor, but source unchaned, should it
do like File/reload and ask if you want to reload and lose changes?
Now if the file has not changed it does not reload and does not compile;
should it compile anyway?
(I don't normally use F4, but had a new keyboard with intermittent faulty Fn
keys so wasn't sure what was happening or supposed to)
View this message in context: http://forum.openscad.org/Design-Reload-and-Preview-tp18006.html
Is F4 meant to /only/ reload if the source file has changed, as it does now? If there are unsaved changes in the editor, but source unchaned, should it do like File/reload and ask if you want to reload and lose changes? Now if the file has not changed it does not reload and does not compile; should it compile anyway? (I don't normally use F4, but had a new keyboard with intermittent faulty Fn keys so wasn't sure what was happening or supposed to) ----- Admin - PM me if you need anything, or if I've done something stupid... Unless specifically shown otherwise above, my contribution is in the Public Domain; to the extent possible under law, I have waived all copyright and related or neighbouring rights to this work. Obviously inclusion of works of previous authors is not included in the above. The TPP is no simple “trade agreement.” Fight it! http://www.ourfairdeal.org/ time is running out! -- View this message in context: http://forum.openscad.org/Design-Reload-and-Preview-tp18006.html Sent from the OpenSCAD mailing list archive at Nabble.com.
