I'd love to have apps on iOS or Linux or Mac that can send
compute intensive jobs to cloud servers and get the results
back fast. Maybe 50 cores running would be nice.
Does this kind of service exist? If not, do you have any hints
on how to set it up? Maybe also have services for computing
signed distance surfaces like:
https://github.com/fogleman/sdf
Thoughts?
I haven't tried fogleman/sdf, but you are implying that mesh export is really slow in that program?
If so, you might consider trying my SDF modelling software, which is similar to fogleman's.
https://github.com/curv3d/curv
Mesh export to STL or OBJ is quite fast. I usually can export a few million triangles in a few seconds. This is due to optimization: the model is JIT compiled to optimized machine code, and mesh generation is multithreaded, so the more cores the better. I'm expecting another order of magnitude speedup once I figure out how to generate the mesh using a GPU.
Thoughts?
Presuming you want the full render (F6), No.
CGAL, the render library, is not currently multitasking.
From: Paul Haeberli [mailto:paulhaeberli@gmail.com]
Sent: Sat, 13 Nov 2021 15:04
Subject: [OpenSCAD] I'd like a OpenSCAD compute service running in the cloud. Is this already available?
Thoughts?
Doug -
Does your curv library support csg of .stl files and can it also radially
expand .stl
files?
Thoughts?
I understand that OpenSCAD and CGAL is not multi-threaded. I am just
talking about wanting could servers that I can send 100 or 200 .scad files
with .stl files and have them rapidly rendered to .stl. I'd like to
interactively vary complex geometry and see the results as fast as possible.
Thoughts?
<#m_-5079113334959692399_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Well, there is the thingiverse customizer, that's what got me into openscad
originally
Thoughts?
<#m_8195076772241545615_m_-5079113334959692399_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
I will take a look at thingiverse customizer - thanks for the pointer.
openscad originally
Thoughts?
<#m_6715680989615964290_m_8195076772241545615_m_-5079113334959692399_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
Anyone here running OpenSCAD on an M1, M1 Pro or M1 Max yet?
I have an Intel Mac Mini and the 2 pain points are F6 rendering and then moving around in a complicated rendered display.
Due to the non-multithreading, the gains might not be what I would hope, at least on the first item. Perhaps hoping for better not he second.
-Bob
Tucson AZ
Sorry, no, Curv doesn't read or process STL files. I recommend OpenSCAD for this. I intended to compare Curv to fogleman/sdf.
An SDF modeller like Curv has more powerful CSG operations: you can sculpt a curved surface using metaballs, or engrave a texture into a surface, or use exotic CSG ops like twist and bend.
Compared to other SDF modellers, Curv has fast mesh export, it models full colour objects (eg, marble or woodgrain), which you can 3D print at service provider like Shapeways. And it has a very responsive customizer which can update the model at 60 FPS while you drag a slider to tweak a parameter. But it is NOT a plugin replacement for OpenSCAD. It doesn't import 3D model files and it lacks some of OpenSCAD's primitives.
On Sat, Nov 13, 2021, at 5:26 PM, Paul Haeberli wrote:
Doug -
Does your curv library support csg of .stl files and can it also radially expand .stl
files?
__
Thoughts?
I've been running on a bottom of the line M1 Mac Mini for a few months now.
The released and dev snapshot of OpenSCAD are both 64-bit Intel, and
although I haven't rigorously measured, performance feels about the same as
it was on my previous bottom of the line Intel Mac Mini.
I haven't tried compiling OpenSCAD from source (I've never
installed Homebrew) but that's a good suggestion to get a significant speed
up.
PrusaSlicer is a universal app, so it's fast on Apple Silicon Macs.
-Bob
Tucson AZ
