Just testing my new Windows 10 pro (on a HP laptop with IntelĀ® Core(TM)
i5-6200U Processor 2.3 GHz) using the following simple code:
difference() // or use intersection()
cube([4,4,4]);
sphere(2);
and found that
(1) at some angles it shows only the intact cube;
(2) at some angles it shows only the intact sphere (or intact negative
sphere if using difference() )
(3) at all other angles there's nothing in the preview;
So if I use the mouse to move it around, roughly about 80% of the time it
shows nothing, 10% cube and 10% sphere (or negative sphere).
Also found that:
So somehow this Win 10 pro causes difference()/interaction() to behave
abnormally in preview.
$ Runsun Pan, PhD
$ libs:
doctest ,
faces ( git ),
offline doc ( git ),
runscad.py( 1 , 2 , git );
$ tips:
hash( 1 , 2 ),
sweep ,
var( 1 , 2 ),
lerp ,
animGif ,
precision( 1 , 2 )
View this message in context: http://forum.openscad.org/Difference-intersection-object-disappears-at-preview-in-Windows-10-tp15113.html
This seems to be the same or similar issue as posted by hamster earlier:
Preview not working with Intel GPUs (was: 2015.03 preview not working)
http://forum.openscad.org/Preview-not-working-with-Intel-GPUs-was-2015-03-preview-not-working-td12101.html
And his solution:
Both versions work correctly on Intel graphics if I check the box "force
Goldfeather" in preferences.
works in my case.
$ Runsun Pan, PhD
$ libs:
doctest ,
faces ( git ),
$ tips:
hash( 1 , 2 ),
sweep ,
var( 1 , 2 ),
lerp ,
animGif ,
precision( 1 , 2 )
View this message in context: http://forum.openscad.org/Difference-intersection-object-disappears-at-preview-in-Windows-10-tp15113p15114.html
For the record, the graphic driver is Inter(R) HD Graphics 520, version
10.18.15.4256, dated 7/17/2015.
$ Runsun Pan, PhD
$ libs:
doctest ,
faces ( git ),
$ tips:
hash( 1 , 2 ),
sweep ,
var( 1 , 2 ),
lerp ,
animGif ,
precision( 1 , 2 )
View this message in context: http://forum.openscad.org/Difference-intersection-object-disappears-at-preview-in-Windows-10-tp15113p15115.html
So far there appears to be NO win10 drivers for the IntelHD graphics cards
that work without "Goldfeather" option.
Not required for Nvidia drivers.
View this message in context: http://forum.openscad.org/Difference-intersection-object-disappears-at-preview-in-Windows-10-tp15113p15119.html
I know - we really need a Windows developer with access with such a system.
It could be buggy drivers, but I feel that Intel should have gotten their GPU drivers under control by now.
In another project I'm working on, the OpenGL support for IntelHD is missing
for line widths in outline mode and dot width for dots. Having to use
spheres instead.
I think the Intel HD drivers are just subpar. We will have to wait for them
to improve. I don't think its a coding issue on OpenSCAD side. It just
doesn't work.
View this message in context: http://forum.openscad.org/Difference-intersection-object-disappears-at-preview-in-Windows-10-tp15113p15123.html
