I am trying to halve an object imported from an STL file. However, it looks
funny when previewed. And an error appears in console after rendering.
violation! File:
/data/OpenSCAD/libraries-mingw64-master/mxe-w64/usr/x86_64-w64-mingw32.static/include/CGAL/Nef_3/SNC_decorator.h
Line: 377 Explanation: it is not possible to decide which one is a visible
facet (if any)
May I know the reason why? And how can this problem be solved.
Thanks.
http://forum.openscad.org/file/n17372/20160519_22.jpg
stand.zip http://forum.openscad.org/file/n17372/stand.zip
View this message in context: http://forum.openscad.org/Errors-when-operating-on-an-STL-file-tp17372.html
I searched the forum again and seemed to find something similar. Following
the suggestion to install netfabb and fiddle around, a self-intersection is
shown as below:
http://forum.openscad.org/file/n17373/20160520_23.jpg
However, the Basic version doesn't allow me to do anything to repair it
unless upgrading to the professional version. I tried opening it in
3D-builder and it didn't reveal any problem and thus nothing to repair. Is
there any other way to deal with this self intersection problem? And is it
this problem that is causing trouble when applying boolean operation on this
STL file in OpenSCAD?
Thanks.
View this message in context: http://forum.openscad.org/Errors-when-operating-on-an-STL-file-tp17372p17373.html
try the free online netfabb repair service:
https://modelrepair.azurewebsites.net
View this message in context: http://forum.openscad.org/Errors-when-operating-on-an-STL-file-tp17372p17375.html
There are some repair tools in the free version of Netfabb, google "netfabb
basic stl repair", and see one of the online tutorials, eg:
http://www.3dcreationlab.co.uk/news/fix-stl-files-for-3d-printer.php
Ian
View this message in context: http://forum.openscad.org/Errors-when-operating-on-an-STL-file-tp17372p17376.html
william wrote
And is it this problem that is causing trouble when applying boolean
operation on this STL file in OpenSCAD?
Yes, boolean uses CGAL which needs intact geometry.
View this message in context: http://forum.openscad.org/Errors-when-operating-on-an-STL-file-tp17372p17381.html
Thank you all!
And indeed. After fixing it using the free microsoft online repair service,
I can render it perfectly.
http://forum.openscad.org/file/n17382/20160521_110705_WILLIAM-LENOVO_William.jpg
However, there are still some missing faces under Preview as before (but
that's of little concern to me)
http://forum.openscad.org/file/n17382/20160521_11.jpg
The online tutorial looks helpful; I will study it carefully. After
googling with "netfabb basic stl repair", I found the netfabb cloud service.
Is it the same as the one offered by microsoft? ... as it says it "extends
the functionality of the free netfabb Studio Basic by some enhanced repair
capabilities otherwise only available in netfabb Studio Professional."
Thanks once again.
View this message in context: http://forum.openscad.org/Errors-when-operating-on-an-STL-file-tp17372p17382.html
The missing faces in preview are probable due to a missing convexity
parameter in the import statement.
View this message in context: http://forum.openscad.org/Errors-when-operating-on-an-STL-file-tp17372p17383.html
Thanks for the tip. Me lazy guy finally got to read the manual. And in the
import() section, convexity was explained clearly. I set it to 10 and the
preview is now flawless.
More questions. What is the default value for convexity? And why do I need
to tell OpenCSG what it is? (I know it may get a little technical)
And in that same section, my original question was also answered.
If you want to render the imported STL file later, you have to make sure
that the STL file is "clean". This means that the mesh has to be manifold
and should not contain holes nor self-intersections. If the STL is not
clean, you might get errors like:
or
(... looks like the CGAL error message I was getting)
In order to clean the STL file, you have the following options:
It mentions MeshLab but not the free online netfabb service. Worth taking
a look into MeshLab?
Thanks.
View this message in context: http://forum.openscad.org/Errors-when-operating-on-an-STL-file-tp17372p17392.html
