accepted by the mailing list yet", so nobody gets it unless they look.
You need to subscribe to the mailing list
and CLICK THE LINK in the registration email.
stcisz wrote
I'm new to openSCAD and during "testing" it I got a mysterious error.
The code below can be previewed bat not render. The stl also can not be
save properly. Both parts can be rendered separably. Any hint, please.
Best regards,
Staszek
============================= code ================================
function square(x) = sqrt(1 - x * x);
rotate_extrude(angle=360,convexity=4, $fn=6)
polygon([[0,0],
[3.95, square(0.9)-0.5],
[3.9, square(0.8)-0.5],
[3.85, square(0.7)-0.5],
[3.8, square(0.6)-0.5],
[3.75, square(0.5)-0.5],
[3.7, square(0.4)-0.5],
[3.65, square(0.3)-0.5],
[3.6, square(0.2)-0.5],
[3.55, square(0.1)-0.5],
[3.5,0.5], [2.5,0.5], [2.5,0.8], [0,0.8]]);
rotate(30,[0,0,1]) cube([8,1.2, 2],true);
rotate(90,[0,0,1]) cube([8,1.2, 2], true);
rotate(150,[0,0,1]) cube([8,1.2, 2], true);
rotate_extrude(angle=360,convexity=3, $fn=6)
polygon([[3.5,0.5],
[3.45, square(0.9)],
[3.4, square(0.8)],
[3.35, square(0.7)],
[3.3, square(0.6)],
[3.25, square(0.5)],
[3.2, square(0.4)],
[3.15, square(0.3)],
[3.1, square(0.2)],
[3.05, square(0.1)],
[3.0, 1], [2.5,1],
[2.25, 3 - square(0.1) * 2],
[2.125, 3 - square(0.2) * 2],
[2.0, 3 - square(0.3) * 2],
[1.875, 3 - square(0.4) * 2],
[1.75, 3 - square(0.5) * 2],
[1.625, 3 - square(0.6) * 2],
[1.5, 3 - square(0.7) * 2],
[1.375, 3 - square(0.8) * 2],
[1.25, 3 - square(0.9) * 2],
[1.15, 3 - square(0.9) * 2],
[1.15, 0.5]
I think your 2nd poly is the problem:
http://forum.openscad.org/file/n20395/Problem-with-union-td20392.jpg
View this message in context: http://forum.openscad.org/Problem-with-union-tp20392p20395.html
Thank you. After correction everything works OK.
Best regards,
Staszek
View this message in context: http://forum.openscad.org/Problem-with-union-tp20392p20402.html
