I have been working on providing User Interface for Customizing Models
in openSCAD.
We have wrapped up work of implementing the major features of the
project a week ago and Now we have been working on testing the User
Interface by using the system as Normal User. So, that User Experience
could be improved and committing changes related to that.
Below are the two links that summarise the work that I have done till now:
https://amarjeetkapoor1.wordpress.com/2016/07/04/user-interface-for-customizing-models/
https://amarjeetkapoor1.wordpress.com/2016/07/18/user-interface-for-customizing-models-part-2/
Below are the link to binaries with my work and also GitHub link:
Window:
32 bit:
http://files.openscad.org/snapshots/OpenSCAD-2016.08.06-x86-32_gsoc2016-Installer.exe
64 bit:
http://files.openscad.org/snapshots/OpenSCAD-2016.08.06-x86-64_gsoc2016-Installer.exe
Zip files
http://files.openscad.org/snapshots/OpenSCAD-2016.08.06-x86-32_gsoc2016.zip
http://files.openscad.org/snapshots/OpenSCAD-2016.08.06-x86-64_gsoc2016.zip
Source Code:
https://github.com/openscad/openscad/tree/gsoc2016-refactored
Amarjeet Singh
https://github.com/amarjeetkapoor1
https://bitbucket.org/amarjeetkapoor
"The journey of a thousand commit begins with a single init"
Tried 64 bit version. Looks good but having usability problems when
writing code and using interaction Toolbar:
2.sometimes changing code has no effect on variables. I would expect
changing code value to override the Toolbar.
Very much looking forward to using this. Thanks
in openSCAD.
Window:
32 bit:
64 bit:
Zip files
Source Code:
Following is the link what I am planning to submit for my final submission
after discussion with my mentor.
Any suggestion related to improvement that can be made is welcomed?
https://github.com/openscad/openscad/pull/1751
Amarjeet Singh
The system crashed twice when I closed it without saving my editions.
2016-08-18 11:03 GMT-03:00 Amarjeet Kapoor amarjeet.kapoor1@gmail.com:
Amarjeet Singh
can we have another binary please
On 8/19/2016 2:03 AM, Amarjeet Kapoor wrote:
Following is the link what I am planning to submit for my final submission after discussion with my mentor.
Any suggestion related to improvement that can be made is welcomed?https://github.com/openscad/openscad/pull/1751
Amarjeet Singh
https://bitbucket.org/amarjeetkapoor"The journey of a thousand commit begins with a single init"
<pre wrap="">_______________________________________________ OpenSCAD mailing list <a class="moz-txt-link-abbreviated" href="mailto:Discuss@lists.openscad.org">Discuss@lists.openscad.org</a> <a class="moz-txt-link-freetext" href="http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org">http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org</a>No virus found in this message.
Checked by AVG - www.avg.com
Version: 2016.0.7752 / Virus Database: 4647/12831 - Release Date: 08/18/16
Could you elaborate?More details would be helpful.
Amarjeet Singh
When I closed the system without saving editions, the system asked for a
confirmation. When I choosed "discard", it seemed to close. A few moments
after that, Windows showed a warning it was trying to close the application
and issued a message that the application has crashed. I got this twice but
I couldn't reproduce it now.
2016-08-18 17:59 GMT-03:00 Amarjeet Kapoor amarjeet.kapoor1@gmail.com:
Amarjeet Singh
Regarding usability:
a. I would prefer the parameters appear in the same order they have in the
file; usually that is the logical order devised by the coder;
b. it would be nice to have the option to save the parameter settings in
the file as default values.
I have not understood the function of Preset.
2016-08-18 18:28 GMT-03:00 Ronaldo Persiano rcmpersiano@gmail.com:
Amarjeet Singh
Latest binaries with reset button :)
http://files.openscad.org/snapshots/OpenSCAD-2016.08.18-x86-64_gsoc2016-Installer.exe
http://files.openscad.org/snapshots/OpenSCAD-2016.08.18-gsoc2016.dmg
http://files.openscad.org/snapshots/OpenSCAD-2016.08.18-x86-32_gsoc2016-Installer.exe
http://files.openscad.org/snapshots/OpenSCAD-2016.08.18-x86-32_gsoc2016.zip
http://files.openscad.org/snapshots/OpenSCAD-2016.08.18-x86-64_gsoc2016.zip
Amarjeet Singh
Okay, I will try to make it like this.
b. it would be nice to have the option to save the parameter settings in the
It is used to save the parameter settings in JSON file and you can
then use it to apply to model again.
You can see the example in new binaries.
Steps:
Amarjeet Singh
