I am doing an "art" project for a friend, and the result contains
approximately 10,000 spheres using the default $fn. I can compute this
with F5 in about 2 minutes. When I try F6, after an hour or so,
OpenSCAD crashes when it reaches the limit of 32 GB of memory use.
What is the limitation on the size of a 3D model in OpenSCAD (counted in
triangles, I guess)? Any idea what else might cause me to use 32 GB of RAM?
Do you need an output STL with only one object in it? If not, use a dev
version and enable lazy union and you might be able to make this work. I
assume that the problem you're facing has to do with trying to compute the
unions of the facets on 10k spheres, which could mean conservatively a
billion tests for facet intersection.
RAM?
The number of faces, and thus the complexity of the model, is by default
dependent on the size of the spheres.
The default $fn is zero, which means to calculate it from $fs and $fa.
The default for $fs is 2, and the default for $fa is 12.
A circle will by default have at least 5 sides, and no more than 30,
depending on its size. A circle with radius less than about 1.6 will
have 5 sides.
A circle with radius larger than about 9.6 will have 30 sides.
I believe that spheres follow the same rule, with respect to the number
of sides around their equator. The square of the number of sides gives
a somewhat high approximation of the number of faces.
Default spheres range from 20 facets to 814 facets.
