If I remove the "*" near the end of the code, I see this:
ERROR: Assertion '(norm(v) > EPSILON)' failed: "3D path contains
collinear points"
I'm not sure what I am doing wrong. The stroke() looks good to me.
eps = 0.01;
slop = 0.2;
$fa = 3;
$fs = 0.2;
inches = 25.4;
hr = 20; // handle radius
ht = 128;
function pos(i) =
let(a = i)
let(x = ((i <= 90) || (i >= 270)) ? abs(hrsin(i)) : hr)
let(z = i)
3x,
0,
0.5 * z * ht/180
spiral = [ for (i=[0:1:360]) pos(i) ];
stroke(spiral);
* path_sweep(circle(r = 5), spiral, method="natural");
path_merge_collinear(spiral)
Dan
On Sun, Jan 25, 2026 at 3:54 PM Jon Bondy via Discuss <
ERROR: Assertion '(norm(v) > EPSILON)' failed: "3D path contains collinear
points"
eps = 0.01;
slop = 0.2;
$fa = 3;
$fs = 0.2;
inches = 25.4;
ht = 128;
function pos(i) =
let(a = i)
let(z = i)
3x,
0,
0.5 * z * ht/180
stroke(spiral);
Virus-free.www.avg.com
<#m_-6223194079730663306_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
You have a ton of samples along the straight section of your path. This is
inefficient (why calculate them) but will still work for some calculations,
like for example path_sweep with the default "incremental" method. The
"natural" method cannot handle collinear points because the computed
derivatives are zero for that method, so you either need to be smarter
about making your curve and don't make all those collinear points, or
follow the suggestion already posted and remove them afterward.
On Sun, Jan 25, 2026 at 10:54 AM Jon Bondy via Discuss <
points"
eps = 0.01;
slop = 0.2;
$fa = 3;
$fs = 0.2;
inches = 25.4;
ht = 128;
function pos(i) =
let(a = i)
let(z = i)
3x,
0,
0.5 * z * ht/180
stroke(spiral);
<#m_-6689552198615250626_DAB4FAD8-2DD7-40BB-A1B8-4E2AA1F9FDF2>
