I wrote some code to generate a polygon, it generates these two lists
point = [[-36.6025, 136.603], [-136.603, 36.6025], [-100, -100], [36.6025,
-136.603], [136.603, -36.6025], [100, 100], [-60, 60], [-81.9615, -21.9615],
[-21.9615, -81.9615], [60, -60], [81.9615, 21.9615], [21.9615, 81.9615]]
path = [0, 6, 1, 7, 2, 8, 3, 9, 4, 10, 5, 11]
but for some reason, when I try
polygon(points=point, paths=path)
nothing is displayed. Could someone take a look at the lists and tell my why
they don't work?
View this message in context: http://forum.openscad.org/Help-with-polygon-function-tp12453.html
Path is a vector-of-index-vectors, not a vector-of-indices. You need to wrap it in a second set of ‘[]’:
—snip--
[-21.9615, -81.9615], [60, -60], [81.9615, 21.9615], [21.9615, 81.9615]];
path = [[0, 6, 1, 7, 2, 8, 3, 9, 4, 10, 5, 11]];
polygon(points=point, paths=path);
—end-snip--
Andrew.
they don't work?
Renaming path to paths = [[ ... ]] or doing polygon(points=point,
paths=[path]); makes the code more logical.
Similarly point should be points.
View this message in context: http://forum.openscad.org/Help-with-polygon-function-tp12453p12455.html
