running OpenSCAD from Windows 10 batch file
Wed, May 17, 2017 2:56 PM
I am trying to create a series of STL files from one SCAD file under
Windows.  When I open the SCAD files and press F5, all is well.  If I
try the same thing using a batch file, I get "Parser error in line 197:
syntax error" (the last line in the file), which is not helpful.
Any thoughts about how to approach this?
Thanks!
I am trying to create a series of STL files from one SCAD file under Windows. When I open the SCAD files and press F5, all is well. If I try the same thing using a batch file, I get "Parser error in line 197: syntax error" (the last line in the file), which is not helpful. Any thoughts about how to approach this? Thanks! Jon
Wed, May 17, 2017 3:36 PM
Are you passing any -D parameters? They get added to the end of the main
file and parsed, so if they are not in the right format you get a syntax
error IIRC one line after the last line.
Thanks!
Are you passing any -D parameters? They get added to the end of the main file and parsed, so if they are not in the right format you get a syntax error IIRC one line after the last line. On 17 May 2017 at 15:56, jon <jon@jonbondy.com> wrote: > I am trying to create a series of STL files from one SCAD file under > Windows. When I open the SCAD files and press F5, all is well. If I try > the same thing using a batch file, I get "Parser error in line 197: syntax > error" (the last line in the file), which is not helpful. > > Any thoughts about how to approach this? > > Thanks! > > Jon > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
IO
Ian Oliver
Wed, May 17, 2017 3:57 PM
Windows.
As nop says, probably your -D syntax and most likely escaping of quotes.
BTW, I've installed gnu make for Windows and am using a makefile to
create about 20 stls from around 10 scad files and it works well. I'm
happy to share my makefile syntax but it's nothing complex.
BTW, I find builds are faster on Linux and don't bring the machine to
its knees in the same way. I have no idea why.
On 2017-05-17 15:56, jon wrote: > I am trying to create a series of STL files from one SCAD file under > Windows. As nop says, probably your -D syntax and most likely escaping of quotes. BTW, I've installed gnu make for Windows and am using a makefile to create about 20 stls from around 10 scad files and it works well. I'm happy to share my makefile syntax but it's nothing complex. BTW, I find builds are faster on Linux and don't bring the machine to its knees in the same way. I have no idea why.
