I wonder if my performance issues relate to re-calculating an object
over-and-over again. I tried something like this
save = moduleX(x);
for (i := [1:10000])
translate(some function)
save;
that did not work syntactically, so I have to use
moduleX(x);
Should I enclose module(x) within render() to get
render(moduleX(x));
or define moduleX(x) as
moduleX(x)
render()
some code
The last case because render() is a module that causes its children's
geometry to be calculated by CGAL and cached.
Or you could do
render()
moduleX(x).
save = moduleX(x);
save;
moduleX(x);
render(moduleX(x));
moduleX(x)
render()
some code
