avoiding invalid operations with boolean expression evalution order?
richalt2
Fri, Aug 23, 2019 6:16 PM
Do boolean expression have an evaluation order, and subexpresions which are
guaranteed to not be evaluated?  So what is the correct coding expression
for:
conditionA && conditionB && function_valid_only_if_A_andB()
Can I expect such a boolean to not call the function if conditionA or B is
false?
Must such be coded with if, or other method to insure the function is not
called unless proper?
Thanks!
Do boolean expression have an evaluation order, and subexpresions which are guaranteed to *not* be evaluated? So what is the correct coding expression for: conditionA && conditionB && function_valid_only_if_A_andB() Can I expect such a boolean to *not* call the function if conditionA or B is false? Must such be coded with if, or other method to insure the function is not called unless proper? Thanks! -- Sent from: http://forum.openscad.org/
Fri, Aug 23, 2019 7:52 PM
Yes the normal shortcut logic applies like in C.
On Fri, 23 Aug 2019 at 19:13, richalt2 via Discuss <
expression
for:
is
false?
Thanks!
Yes the normal shortcut logic applies like in C. On Fri, 23 Aug 2019 at 19:13, richalt2 via Discuss < discuss@lists.openscad.org> wrote: > Do boolean expression have an evaluation order, and subexpresions which are > guaranteed to *not* be evaluated? So what is the correct coding > expression > for: > conditionA && conditionB && function_valid_only_if_A_andB() > > Can I expect such a boolean to *not* call the function if conditionA or B > is > false? > Must such be coded with if, or other method to insure the function is not > called unless proper? > > Thanks! > > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
