In your case pre-rendering the basic shape should solve your problem.
In some cases for speed reasons you may have to save some rendered modules
as .stl's and then import them to continue the work. If the saved stl's are
well formed you may still execute boolean operarations with them, however
sometimes is not possible.
jpmendes
View this message in context: http://forum.openscad.org/reusing-unions-objects-tp16464p16470.html
jpmendes
