W
wolf
Sat, Oct 24, 2015 3:37 AM
echo(2/0, atan(2/0), atan(90));
returns
ECHO: inf, 90, 89.3634
The proper response for a division by zero should be not-a-number (NaN),
since that division may result in any number. Consider sin(0)/0=0, which is
a valid expression since the limit for xapproaching zero exists.
atan(2/0) should result in undefined, and atan(90) should result in inf,
since the respective Taylor series does not converge and no value can be
computed.
By the way, is there a means to properly display a formula like
binom{limit}{x rightarrow 0} {sin( x)} over {x} = 0
when posting?
View this message in context: http://forum.openscad.org/Software-bug-tp14194.html
returns
computed.
when posting?
Sat, Oct 24, 2015 4:13 AM
The IEEE floating point standard says that 2/0 is inf, and that's the
standard we are following. While your argument for NaN is mathematically
correct, at least where real numbers or exact arithmetic is concerned,
floating point computation doesn't have the same behaviour as real number
arithmetic. For example, it has underflow, where a sufficiently small
positive result is represented by 0, and a sufficiently small negative
result is represented by -0, which is different from 0 in IEEE floats. So
the floating point number 0 sometimes represents a true 0, and it sometimes
represents a very small positive real number. So the IEEE float standards
committee decided to define 1/0 as inf and -1/0 as -inf, and this results
in useful behaviour, making it easier to write floating point code, in a
lot of cases. And yes, this is a compromise, since it's not the right
behaviour in all cases.
returns
computed.
when posting?
> returns
> computed.
> when posting?
Sat, Oct 24, 2015 11:55 AM
atan(90) is not infinite, it is close to 90 degrees as is the atan of any
large number. It approaches 90 asymptotically.
tan(90) is definitely infinite, so inf is correct.
echo(atan(tan(90))); gives 90 as it should.
Only 0/0 is undefined and that does give nan.
returns
is
computed.
when posting?
>> returns
>> is
>> computed.
>> when posting?
DB
don bright
Sat, Oct 24, 2015 9:29 PM
any large number. It approaches 90 asymptotically.
echo(atan(tan(90))); gives 90 as it should. Only 0/0 is undefined and
that does give nan.
mathematically correct, at least where real numbers or exact
arithmetic is concerned, floating point computation doesn't have the
same behaviour as real number arithmetic. For example, it has
underflow, where a sufficiently small positive result is represented
by 0, and a sufficiently small negative result is represented by -0,
which is different from 0 in IEEE floats. So the floating point
number 0 sometimes represents a true 0, and it sometimes represents a
results in useful behaviour, making it easier to write floating point
code, in a lot of cases. And yes, this is a compromise, since it's
not the right behaviour in all cases.
echo(2/0, atan(2/0), atan(90)); returns ECHO: inf, 90, 89.3634
(NaN), since that division may result in any number. Consider
sin(0)/0=0, which is a valid expression since the limit for
xapproaching zero exists. atan(2/0) should result in undefined, and
atan(90) should result in inf, since the respective Taylor series
does not converge and no value can be computed.
binom{limit}{x rightarrow 0} {sin( x)} over {x} = 0 when posting?
http://forum.openscad.org/Software-bug-tp14194.html Sent from the
OpenSCAD mailing list Discuss@lists.openscad.org
The manual has been updated.
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Mathematical_Functions#Infinitudes_and_NaNs
Interesting note.... OpenSCAD seems to return 'undef' for exp(2,1/0) but
it is probably intended to be returning NaN....
hmbright@fastmail.com
> that does give nan.
> _________________________________________________
Sat, Oct 24, 2015 9:39 PM
exp(x) is a function that takes exactly one argument. It's probably using
generic code to return undef if the number of arguments is incorrect. Which
is fine.
undef and NaN play exactly the same role in the language. Rather than
debate when to return undef and when to return nan in a bunch of different
cases, I'd rather just unify them into a single value.
returns
computed.
when posting?
is fine.
> returns
> computed.
> when posting?
> *_______________________________________________*
AP
Andrew Plumb
Sat, Oct 24, 2015 10:37 PM
If you were trying to test “2^(1/0)” then the function you want is pow(2,1/0).
echo( exp(1/0) );
-> inf
echo( pow(2,1/0) );
-> inf
Andrew.
On Oct 24, 2015, at 5:39 PM, doug moen doug@moens.org wrote:
exp(x) is a function that takes exactly one argument. It's probably using generic code to return undef if the number of arguments is incorrect. Which is fine.
undef and NaN play exactly the same role in the language. Rather than debate when to return undef and when to return nan in a bunch of different cases, I'd rather just unify them into a single value.
On 24 October 2015 at 17:29, don bright <hmbright@fastmail.com mailto:hmbright@fastmail.com> wrote:
https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Mathematical_Functions#Infinitudes_and_NaNs https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Mathematical_Functions#Infinitudes_and_NaNs
Interesting note.... OpenSCAD seems to return 'undef' for exp(2,1/0) but it is probably intended to be returning NaN....
atan(90) is not infinite, it is close to 90 degrees as is the atan of any large number. It approaches 90 asymptotically.
On 24 October 2015 at 05:13, doug moen <doug@moens.org mailto:doug@moens.org> wrote:
The IEEE floating point standard says that 2/0 is inf, and that's the standard we are following. While your argument for NaN is mathematically correct, at least where real numbers or exact arithmetic is concerned, floating point computation doesn't have the same behaviour as real number arithmetic. For example, it has underflow, where a sufficiently small positive result is represented by 0, and a sufficiently small negative result is represented by -0, which is different from 0 in IEEE floats. So the floating point number 0 sometimes represents a true 0, and it sometimes represents a very small positive real number. So the IEEE float standards committee decided to define 1/0 as inf and -1/0 as -inf, and this results in useful behaviour, making it easier to write floating point code, in a lot of cases. And yes, this is a compromise, since it's not the right behaviour in all cases.
On 23 October 2015 at 23:37, wolf <wv99999@gmail.com mailto:wv99999@gmail.com> wrote:
returns
computed.
when posting?
View this message in context: http://forum.openscad.org/Software-bug-tp14194.html http://forum.openscad.org/Software-bug-tp14194.html
echo( exp(1/0) );
-> inf
echo( pow(2,1/0) );
-> inf
Andrew.
> On 24 October 2015 at 17:29, don bright <hmbright@fastmail.com <mailto:hmbright@fastmail.com>> wrote:
> https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Mathematical_Functions#Infinitudes_and_NaNs <https://en.wikibooks.org/wiki/OpenSCAD_User_Manual/Mathematical_Functions#Infinitudes_and_NaNs>
>> On 24 October 2015 at 05:13, doug moen <doug@moens.org <mailto:doug@moens.org>> wrote:
>> On 23 October 2015 at 23:37, wolf <wv99999@gmail.com <mailto:wv99999@gmail.com>> wrote:
>> returns
>> computed.
>> when posting?
>> View this message in context: http://forum.openscad.org/Software-bug-tp14194.html <http://forum.openscad.org/Software-bug-tp14194.html>
>> Discuss@lists.openscad.org <mailto:Discuss@lists.openscad.org>
>> http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org <http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org>
Sun, Oct 25, 2015 12:08 AM
I am not sure undef and nan are the same. If I don't define x but use it
then it is undefined. x = 0/0 is different because x is defined but
mathematically not a number.
pow(2,1/0).
echo( exp(1/0) );
-> inf
echo( pow(2,1/0) );
-> inf
Andrew.
is fine.
returns
is
computed.
when posting?
> pow(2,1/0).
> echo( exp(1/0) );
> -> inf
> echo( pow(2,1/0) );
> -> inf
> Andrew.
> is fine.
>> returns
>> is
>> computed.
>> when posting?
Rob Ward
Sun, Oct 25, 2015 12:28 AM
Just to throw in a philosophical angle to another thread discussing how
to deal with the limits of trigonometric and arithmetic functions:
Mathematics (IMHO) in its purest form is values free, but as soon as it
is applied to the real world, there has to be some judgments applied, as
to when and how it is applied. Consequently any transition from the
theoretical (eg infinity) to get to a 3-D printed model that I can hold
in my hand (and not just in my head) is going to require many judgments
and compromises. OpenSCAD is a perfect example when applying pure
mathematical concepts to practically rendering 3-D objects on the
screen, and later into machinable shapes.
I am a retired Maths/Science/Technology teacher, and now I would just
HAVE to have openSCAD and a 3-D printer in my classroom (s). The
conversations in this forum are very helpful to my understanding of the
scope of openSCAD. The convergence of theoretical maths being applied
so directly to real world challenges, and at a level that people can
access relatively easily, is just a fantastic teaching learning
opportunity. The positive and constructive critique in this discussion
list of the openSCAD system encourages me to look forward to more
improvements in operation and documentation.
I no longer feel condemned to the daily paper's crossword or Sudoku
puzzle to keep my brain in trim. OpenSCAD is the perfect reply to the
often asked question in Mathematics classes "When are we ever going to
use this again Sir??" Thank you folks!
Rob Ward
Lake Tyers Beach, 3909
XP to XUbuntu - The journey, join me!
http://www.laketyersbeach.net.au/XP2XU.html
pow(2,1/0).
echo( exp(1/0) );
-> inf
echo( pow(2,1/0) );
-> inf
Andrew.
returns
not-a-number (NaN),
exists.
no value can be
computed.
formula like
when posting?
Nabble.com <http://Nabble.com>.
*Rob Ward*
Lake Tyers Beach Website <http://www.laketyersbeach.net.au>
<http://www.laketyersbeach.net.au/XP2XU.html>
> pow(2,1/0).
> echo( exp(1/0) );
> -> inf
> echo( pow(2,1/0) );
> -> inf
> Andrew.
>>> returns
>>> not-a-number (NaN),
>>> exists.
>>> no value can be
>>> computed.
>>> formula like
>>> when posting?
Sun, Oct 25, 2015 2:53 AM
nan and undef are both used as the return value from a function, when an
argument is passed that is outside the domain of the function. In this
context, they have the same meaning, but we aren't consistent about whether
we return nan or undef.
len(x) is only defined if x is a string or list, so len(42) == undef.
asin(x) is only defined if x is a number in the range [-1...+1].
asin(2) is nan, but asin("foo") is undef.
foo[i] is only defined if foo is a string or list, and i is an integer in
the range [0...len(foo)-1].
"abc"[0] == "a"
"abc"[42] == undef
pow(2,1/0).
echo( exp(1/0) );
-> inf
echo( pow(2,1/0) );
-> inf
Andrew.
is fine.
returns
is
computed.
when posting?
"abc"[0] == "a"
"abc"[42] == undef
>> pow(2,1/0).
>> echo( exp(1/0) );
>> -> inf
>> echo( pow(2,1/0) );
>> -> inf
>> Andrew.
>> is fine.
>>> returns
>>> is
>>> computed.
>>> when posting?
DB
don bright
Sun, Oct 25, 2015 3:01 AM
the test suite had a bug , was passing two variables to exp() i updated
the test suite
and atan(90) should result in inf, since the respective Taylor
series does not converge and no value can be computed.
the test suite
>> __
