Fri, Jun 19, 2020 12:30 PM
function test() =
echo($fn=$fn, $fa=$fa, $fs=$fs)
[[0,0],[1,0],[1,1],[0,1]];
A=test();
polygon(test(),$fa=0.1,$fs=0.1);
c=test($fa=0.1,$fs=0.1);
d=test($fa=0.1,$fs=0.1);
Output is:
ECHO: $fn = 0, $fa = 12, $fs = 2 // starting value
ECHO: $fn = 0, $fa = 0.1, $fs = 0.1 // correct
ECHO: $fn = 0, $fa = 12, $fs = 0.1 // wrong
If I delete one the last line then I get this:
and if I delete one more last line I get this:
If I set $fa only without also setting $fs then it works correctly. What's
going on here?
function test() =
A=test();
Output is:
going on here?
Fri, Jun 19, 2020 12:39 PM
I think the expressions are all evaluated and the expression version of
echo before any modules are instantiated. The last echo is always the one
in the polygon call.
On Fri, 19 Jun 2020 at 13:31, adrianv avm4@cornell.edu wrote:
function test() =
A=test();
Output is:
going on here?
On Fri, 19 Jun 2020 at 13:31, adrianv <avm4@cornell.edu> wrote:
> function test() =
> A=test();
> Output is:
> going on here?
Fri, Jun 19, 2020 3:24 PM
of echo before any modules are instantiated. The last echo is always
the one in the polygon call.
Yes. And that one gets the default values. The values passed to
polygon() apply to polygon(), not to the functions elsewhere in its
arguments.
This is made clearer by putting a label on each call to test():
function test(s) =
echo(s,$fn=$fn, $fa=$fa, $fs=$fs)
A=test("A");
polygon(test("B"),$fa=0.1,$fs=0.1);
c=test("C",$fa=0.1,$fs=0.1);
d=test("D",$fa=0.1,$fs=0.1);
where the output is
ECHO: "A", $fn = 0, $fa = 12, $fs = 2
ECHO: "C", $fn = 0, $fa = 0.1, $fs = 0.1
ECHO: "D", $fn = 0, $fa = 0.1, $fs = 0.1
ECHO: "B", $fn = 0, $fa = 12, $fs = 0.1
The order of execution in OpenSCAD is ... interesting. Try to predict
what this will output... (actual output below)
echo("main 1");
a = echo("main 2");
module foo() {
b = echo("foo 3");
echo("foo 1");
children(2);
children(1);
children(2);
echo("foo 2");
c = echo("foo 4");
foo() {
d = echo("foo child assign 1");
echo("child 0");
echo("child 1");
echo("child 2");
e = echo("foo child assign 2");
echo("main 3");
b = echo("main 4");
Give up on trying to figure it out? Don't have an OpenSCAD handy to
try? Here it is:
ECHO: "main 2"
ECHO: "main 4"
ECHO: "main 1"
ECHO: "foo child assign 1"
ECHO: "foo child assign 2"
ECHO: "foo 3"
ECHO: "foo 4"
ECHO: "foo 1"
ECHO: "child 2"
ECHO: "child 1"
ECHO: "child 2"
ECHO: "foo 2"
ECHO: "main 3"
I think the rules are:
- Do all of the assignments in the current block.
- For each module invocation
o Do all of the assignments in the invocation's child block.
o Do all of the assignments in the module.
o Execute each of the module invocations in module.
+ Execute modules from the invocation's child block when
children() is executed.
arguments.
function test(s) =
A=test("A");
where the output is
echo("main 1");
a = echo("main 2");
module foo() {
b = echo("foo 3");
echo("foo 1");
children(2);
children(1);
children(2);
echo("foo 2");
c = echo("foo 4");
foo() {
echo("child 0");
echo("child 1");
echo("child 2");
echo("main 3");
b = echo("main 4");
try? Here it is:
ECHO: "main 2"
ECHO: "main 4"
ECHO: "main 1"
ECHO: "foo 3"
ECHO: "foo 4"
ECHO: "foo 1"
ECHO: "child 2"
ECHO: "child 1"
ECHO: "child 2"
ECHO: "foo 2"
ECHO: "main 3"
* Do all of the assignments in the current block.
* For each module invocation
Fri, Jun 19, 2020 8:20 PM
This is the thing I was confused about and then trying to clarify with
echos...which apparently just added another layer of confusion. But your
explanation doesn't seem to be right. Also look closely at the "B" output.
It's the case where polygon() wraps the call to test, and in fact $fs does
propagate, but $fa does not.
My actual code looks like this:
polygon(round_corners(shape, radius = radii),$fn=64);
The round_corners call uses $fn, $fa and $fs. When written as above the
rounded corners seem rounded as expected. In other words, $fn=64 is
passed into round_corners, both verified by echo and also by observing the
corners I get. If I change it to:
polygon(round_corners(shape, radius = radii));
then $fn prints as zero and I get very visibly different corners. So the
$fn value is definitely propagating into round_corners.
I'm now unable to reproduce the problem I had earlier where $fn propagated
but $fs and $fa did not. I'm also not getting the result below where the
"B" case is weird. I'm getting both $fa and $fs propagating into test() in
that case.
I have to admit that I almost always write functions rather than modules in
OpenSCAD, and functions execute in order. I've found that modules will
invalidate my error handling because of running stuff out of order. Though
maybe this has been improved in a recent release? (I'm running 2019.05.)
It's the case where polygon() wraps the call to test, and in fact $fs *does*
rounded corners seem rounded as expected. In other words, $fn=64 *is*
that case.
Fri, Jun 19, 2020 8:36 PM
You are passing $fn to polygon, so I have no idea why it affects
round_corners, that would seem like a bug to me.
I would try let($fn = 64) polygon(round_corners(shape, radius = radii)); if
I didn't want to change $fn at the current scope.
output.
does
in
that case.
> output.
> *does*
> in
> that case.
Fri, Jun 19, 2020 8:51 PM
I actually have no problem writing polygon(round_corners(shape, radius=radii,
$fn=64)) instead if that's what I need to do. I wonder if there's some
weird indeterminate scoping going on.
if
> if
AC
A. Craig West
Fri, Jun 19, 2020 9:00 PM
I suspect the argument list to the function is being considered to be
within the scope of the function when passing $ variables. Its not an
unreasonable interpretation
radius=radii,
if
> radius=radii,
> > if
Fri, Jun 19, 2020 9:06 PM
I thought of a use case that would rely on this behavior. But if this is the
situation...why is the passing inconsistent?
Fri, Jun 19, 2020 9:24 PM
Ooh, yeah. I hadn't noticed that. It doesn't make any sense to me.
Can you give examples of error handling that doesn't work right?
Yeah, but that doesn't explain why $fs gets set but $fa does not.
My gut reaction is that the arguments shouldn't be able to interact with
one another, but as I think about it more I'm not sure. $ variables are
kind of sort of global-ish, so maybe if you set them then they might
affect "peer" expressions, depend on the order of evaluation. But I
think it would be cleaner if they did not interact.
HL
Hans L
Sat, Jun 20, 2020 11:43 PM
The answer is actually very simple.
Function or module arguments are not guaranteed to be evaluated in any
particular order
You write: polygon(test(),$fa=0.1,$fs=0.1);
But, you seem to be expecting test() to be evaluated after assignment of
$fa and $fs, which to me is more bizarre than if they were actually done in
order.
The solution is to not write code where any one argument is dependent on
another from the same call being assigned first, and you'll not have any
problems.
particular order
But, you seem to be expecting test() to be evaluated *after* assignment of
order.
problems.
