Gentlemen,
I searched for nc code verification and found nothing.
Has anyone developed this type of application on openSCAD?
thanks
Stuart
View this message in context: http://forum.openscad.org/nc-code-verification-tp11373.html
What does NC stand for?
http://www.acronymfinder.com/NC.html
Your abbreviation has 153 meanings
On 2-2-2015 5:45, stustev wrote:
Gentlemen,
thanks
Stuart
Numerical Control - a gcode program that openSCAM or some other nc cam
program would generate.
I would like to use openSCAD to machine the part virtually in the same
manner Vericut does - only with open source code.
thanks
Stuart
Gentlemen,
thanks
Stuart
Addressee is the intended audience.
If you are not the addressee then my consent is not given for you to read
this email furthermore it is my wish you would close this without saving or
reading, and cease and desist from saving or opening my private
correspondence.
Thank you for honoring my wish.
I have NCL by NCCS to do nc programming. It generates nc code like a lot of
other nc programming systems.
I have a verification package inside NCL but it uses the ncl program to
verify the motion around the model.
I want to use the nc code that is loaded into the machine (after the post
processor) to do the verification. That will eliminate any possible post
processor errors. I would also like to build the machine components,
fixture components and tooling components to allow the verification package
to check for interference between those components.
thanks
Stuart
thanks
Stuart
Gentlemen,
thanks
Stuart
correspondence.
correspondence.
OpenSCAD isn't a CAM program; it doesn't convert 3D models to tool
paths or generate g-code. It also doesn't read g-code, or any other nc
code variant.
On 1 February 2015 at 23:45, stustev stustev@gmail.com wrote:
Gentlemen,
thanks
Stuart
I am not asking to see if it generates a CAM program. My software does that.
I want to be able to use openSCAD to open a CAM program.
Read it line by line.
Use the read lines as input to openSCAD to remove material from a block or
model to simulate the machining process.
If no one has attempted this with openSCAD then I want to explore this
capability.
If someone has done this or is working on this then I want to contribute as
much as I can.
thanks
Stuart
code variant.
Gentlemen,
thanks
Stuart
correspondence.
Use the read lines as input to openSCAD to remove material from a block or model to simulate the machining process.
I would start by writing an nc code interpreter which converts each linear movement into an OpenSCAD primitive,
then generate an OpenSCAD file containing the block and all subtracted primitives.
This will likely be extremely slow, but it could be worth a shot.
Is there scripting capability in openSCAD to do this or would it be a
separate program outside?
Perl would be able to do this. There are other string manipulation scripts
also.
Thanks
Stuart
primitives.
Stuart,
Do you envision working 2.5D type toolpaths, 3D or 3D with tool axis varying?
Working up some code to generate OpenSCAD commands should be pretty
straightforward for 2.5D toolpaths. The 3D and tool axis stuff may be pushing
things a bit. Also, how many tool points do you envision processing at one time?
Phil(f) in WI
If no one has attempted this with openSCAD then I want to explore this capability.
If someone has done this or is working on this then I want to contribute as much
as I can.
thanks
Stuart
On Mon, Feb 2, 2015 at 5:22 PM, doug moen <doug@moens.org
code variant.
On 1 February 2015 at 23:45, stustev <stustev@gmail.com
<mailto:stustev@gmail.com>> wrote:
Gentlemen,
thanks
Stuart
If you are not the addressee then my consent is not given for you to read this
email furthermore it is my wish you would close this without saving or reading,
and cease and desist from saving or opening my private correspondence.
I need multiaxis verification.
It should not be much more difficult than two or three axis work. The cam
program gives the tool end point and tool axis. With the next point it is
easy to construct matrix to correctly postion the model of the tool for the
boolean removal.
Stuart,
varying?
pushing
time?
Phil(f) in WI
that.
or model
capability.
as much
as I can.
thanks
Stuart
On Mon, Feb 2, 2015 at 5:22 PM, doug moen <[hidden email]
<mailto:[hidden email]
nc
code variant.
On 1 February 2015 at 23:45, stustev <[hidden email]
Gentlemen,
thanks
Stuart
[hidden email]
http:///user/SendEmail.jtp?type=node&node=11382&i=4 <mailto:[hidden email]
http:///user/SendEmail.jtp?type=node&node=11382&i=5>
[hidden email] <http:///user/SendEmail.jtp?type=node&node=11382&i=6>
<mailto:[hidden email] http:///user/SendEmail.jtp?type=node&node=11382&i=7>
this
reading,
[hidden email] http:///user/SendEmail.jtp?type=node&node=11382&i=8
[hidden email] http:///user/SendEmail.jtp?type=node&node=11382&i=9
below:
http://forum.openscad.org/nc-code-verification-tp11373p11382.html
To unsubscribe from nc code verification, click here
http://forum.openscad.org/template/NamlServlet.jtp?macro=unsubscribe_by_code&node=11373&code=c3R1c3RldkBnbWFpbC5jb218MTEzNzN8LTEyODc0MzU0ODM=
NAML
View this message in context: http://forum.openscad.org/nc-code-verification-tp11373p11383.html
