I decided I wanted to play around with the source version again so that I
can see if I can add colors to the SVG output. After building clean with
the latest github source (master branch), BOSL2 gives me the following
warnings/errors:
WARNING: Ignoring unknown variable "$transform" in file
../../BOSL2/transforms.scad, line 1604
<1604,/home/ebo/.local/share/OpenSCAD/libraries/BOSL2/transforms.scad>
TRACE: assignment to "$transform" in file ../../BOSL2/transforms.scad, line
1604 <1604,/home/ebo/.local/share/OpenSCAD/libraries/BOSL2/transforms.scad>
TRACE: called by 'scale' in file Cable_Trace_Bracket_examples_3T.scad, line
39
<39,/home/ebo/.local/share/OpenSCAD/libraries/tabbed-box/examples/Cable_Trace_Bracket_examples_3T.scad>
Any idea how to fix this? I tried updating BOSL2 to the latest, and that
did not help. I'll also try building from one of the recient tagged
sources.
EBo --
By any chance did you “use <>" the BOSL2 library instead of “include <>”ing it?
-Revar
On Apr 18, 2025, at 11:59 PM, John David via Discuss <discuss@lists.openscad.org> wrote:
I decided I wanted to play around with the source version again so that I can see if I can add colors to the SVG output. After building clean with the latest github source (master branch), BOSL2 gives me the following warnings/errors:
WARNING: Ignoring unknown variable "$transform" in file ../../BOSL2/transforms.scad, line 1604
TRACE: assignment to "$transform" in file ../../BOSL2/transforms.scad, line 1604
TRACE: called by 'scale' in file Cable_Trace_Bracket_examples_3T.scad, line 39
Any idea how to fix this? I tried updating BOSL2 to the latest, and that did not help. I'll also try building from one of the recient tagged sources.
EBo --
Could be a BOSL2 bug. You have overlooked the cardinal rule of posting
about bugs which is to include a minimal code example that triggers the
problem.
On Sat, Apr 19, 2025 at 4:55 AM Revar Desmera via Discuss <
<>”ing it?
-Revar
warnings/errors:
http://1604,/home/ebo/.local/share/OpenSCAD/libraries/BOSL2/transforms.scad
line 1604
line 39
http://39,/home/ebo/.local/share/OpenSCAD/libraries/tabbed-box/examples/Cable_Trace_Bracket_examples_3T.scad
sources.
EBo --
