Hello, algorithmically inclined CAD people,
I find myself in need of a hook-and-groove system (to put a bottom or a
lid on a box). The problem is that the edge may (a) have less than 90°
(think "base of a pyramid") and (b) may need to be inset by some amount
(think "heavily mitered edges").
Is there code out there which does that? While I'm no stranger to 3-D
geometry math, re-inventing the wheel isn't my favorite pastime.
-- Matthias Urlichs
Try https://www.thingiverse.com/ it's like Google search for 3D
models and has some OpenScad
-- Matthias Urlichs
I've been using simple dovetail joints.
Tigers prowl and Dragons soar in my dreams...
Umm, well, for a somewhat-removeable lid (which doesn't slide off on its
own when mounted upside down – I need them for an enclose of a
ceiling/corner-mounted room monitor) these are probably not the right
choice. I'm looking for something that locks with a snap-in and doesn't
require tight tolerances.
Of course I know about Thingiverse, but I didn't find anything remotely
suitable.
-- Matthias Urlichs
You could give this a try. It's based on the pins from the gear-cube, but
I've reworked the design very heavily. It is written I. Openscad of course
https://www.thingiverse.com/thing:3218332
On Sat, 5 Oct 2019, 14:23 Matthias Urlichs via Discuss, <
suitable.
-- Matthias Urlichs
Some slanted finger joints, perhaps.
A sábado, 5/10/2019, 19:23, Matthias Urlichs via Discuss <
discuss@lists.openscad.org> escreveu:
suitable.
-- Matthias Urlichs
I'm not sure I understand the original poster's intention. I have recently
designed the following. Is this the idea? It is a box with a lid that
slides into place held in a triangular groove. (Unfortunately my
application had the object on the dashboard of my car which turns out to be
too hot for PLA.)
http://forum.openscad.org/file/t2477/boxpic.png
Call it "hooks and ridges" then, or "hooks and whatever a hook hooks
onto"; English is not my first language.
Anyway, I have coded (but not yet printed) up a preliminary version of
my idea, and parked it at Thingiverse. Heaps of interesting geometry
lessons here …
https://www.thingiverse.com/thing:3904636
-- Matthias Urlichs
'Clip'
