Not sure how to make the shape() function do the "obvious" thing.
use <sweep.scad>
function f(t) = [
(t / 1.5 + 0.5) * 10 * cos(1.5 * 360 * t),
(t / 1.5 + 0.5) * 10 * sin(1.5 * 360 * t),
100 * (1 - t)
function shape() =
for (a = [0:15])
(a%2 == 0) ? [5sin(a * 45/2), 5sin(a * 45/2] : [10sin(a *
45/2), 10sin(a * 45/2];
[ 0, 10],
[ 0, 10],
[10, 10],
[10, 0]
[-10, -1],
[-10, 6],
[ -7, 6],
[ -7, 1],
[ 7, 1],
[ 7, 6],
[ 10, 6],
[ 10, -1]];
step = 0.005;
path = [for (t=[0:step:1-step]) f(t)];
path_transforms = construct_transform_path(path);
sweep(shape(), path_transforms);
Um, why not explain what you are trying to do?
While I'm motivated to help, I'm not going to reverse engineer the
code trying to guess what the target is...
I was trying to get the loop to emit a series of 16 [x,y] positions to
create the shape. The details of exactly which points are where is
probably irrelevant.
Does that help?
Checked by AVG - www.avg.com
Version: 2016.0.7294 / Virus Database: 4483/11165 - Release Date: 12/12/15
Like so for an ellipse?:
function shape() = [ for (a = [0 : 35]) [ 5 * sin(a * 10), 8 * cos(a * 10) ] ];
// easy way to test just the shape :-)
polygon(shape());
Or to show the separate things going on in more detail:
function x(a) = (10 + sin(a * 10)) * sin(a);
function y(a) = (10 + sin(a * 10)) * cos(a);
function point(a) = [ x(a), y(a) ];
function shape() = [ for (a = [0 : 359]) point(a) ];
polygon(shape());
Thanks. Those examples helped a lot in getting the syntax tweaked!
polygon(shape());
polygon(shape());
