On 7/28/25 10:33, Dylan via Discuss wrote:
I haven't had a chance to test out any of the approaches suggested
yet, but it certainly seems high on the list.
D
On 28/07/2025 14:38, Jon Bondy via Discuss wrote:
Glenn's PolyRound approach seemed simple and elegant to me. That
does not work for you?
On 7/28/2025 9:34 AM, Dylan via Discuss wrote:
If I need to do this, then I may as well model it directly in, for
example, Blender. The whole point of this exercise is to eliminate
the need to model each instrument individually, and instead simply
use measurements as input. How successful that end up being is a
matter for experiment and discovery...
D
I faced a similar problem in forming a buttress thread in linuxcnc, but
wanted the smooth 7 degree loaded face dead smooth, which in linuxcnc
would have doubled the size of the g-code I'd have to write. So I
cheated and made a wedge to mount the spindle motor at a 7 degree angle
so the whole load face of the tooth was cut by the side of a .250" DOC
1/16" RN tool. Dead smooth face of tooth on half the g-code. Sometimes
it pays to think outside that famous box. Then to make the half nuts on
a 3d printer, I just made a 7 point polygon for the faces in plastic..
With a coat of carnaba wax on the hard maple screw its amazingly
smooth. And capable of several tons of vice pressure.
Cheers, Gene Heskett, CET.
> D
>> Jon
>>> D
- Louis D. Brandeis
