Cross section view
ME
Mark Erbaugh
Tue, Nov 19, 2024 1:56 PM
Does OpenSCAD have a way to view a cross section of a model? I’m aware of the % (transparent) modifier, but I’m looking for a way to slice through a model on a given plane.
As I write this, I guess is would be possible to do a difference with a cuboid representing the cut-away part of the plane, but is there a better way?
Mark
Does OpenSCAD have a way to view a cross section of a model? I’m aware of the % (transparent) modifier, but I’m looking for a way to slice through a model on a given plane. As I write this, I guess is would be possible to do a difference with a cuboid representing the cut-away part of the plane, but is there a better way? Mark
DP
Dan Perry
Tue, Nov 19, 2024 2:24 PM
If you're open to using BOSL2 library:
https://github.com/BelfrySCAD/BOSL2/wiki/partitions.scad
Dan
On Tue, Nov 19, 2024 at 1:57 PM Mark Erbaugh via Discuss <
way?
Mark
If you're open to using BOSL2 library: https://github.com/BelfrySCAD/BOSL2/wiki/partitions.scad Dan On Tue, Nov 19, 2024 at 1:57 PM Mark Erbaugh via Discuss < discuss@lists.openscad.org> wrote: > Does OpenSCAD have a way to view a cross section of a model? I’m aware of > the % (transparent) modifier, but I’m looking for a way to slice through a > model on a given plane. > > As I write this, I guess is would be possible to do a difference with a > cuboid representing the cut-away part of the plane, but is there a better > way? > > Mark > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Tue, Nov 19, 2024 4:01 PM
There is no cross-section view.  You can use difference or intersection
to achieve the same effect.
Caution:  in perspective mode, the previewer doesn't like it when the
camera is inside negative space for a difference.  This is often a
problem when you're differencing away large cubes to do cut-aways.  This
program demonstrates the problem:
    sphere(10);
    cube(1000);
In perspective mode, rotate the view so that the camera is looking at
the sphere from the positive-XYZ octant; observe that the cut-away
portion is restored.
I thought there was a similar effect for intersection, but I'm not
duplicating it at the moment.
On 11/19/2024 5:56 AM, Mark Erbaugh via Discuss wrote: > Does OpenSCAD have a way to view a cross section of a model? I’m aware of the % (transparent) modifier, but I’m looking for a way to slice through a model on a given plane. > > As I write this, I guess is would be possible to do a difference with a cuboid representing the cut-away part of the plane, but is there a better way? > There is no cross-section view.  You can use difference or intersection to achieve the same effect. Caution:  in perspective mode, the previewer doesn't like it when the camera is inside negative space for a difference.  This is often a problem when you're differencing away large cubes to do cut-aways.  This program demonstrates the problem: difference() { sphere(10); cube(1000); } In perspective mode, rotate the view so that the camera is looking at the sphere from the positive-XYZ octant; observe that the cut-away portion is restored. I thought there was a similar effect for intersection, but I'm not duplicating it at the moment.
GS
Guenther Sohler
Tue, Nov 19, 2024 4:07 PM
What about just moving the desired x-section to XY plane and use
projection(cut=true) on that ?
Jordan Brown via Discuss discuss@lists.openscad.org schrieb am Di., 19.
Nov. 2024, 17:01:
sphere(10);
cube(1000);
restored.
What about just moving the desired x-section to XY plane and use projection(cut=true) on that ? Jordan Brown via Discuss <discuss@lists.openscad.org> schrieb am Di., 19. Nov. 2024, 17:01: > On 11/19/2024 5:56 AM, Mark Erbaugh via Discuss wrote: > > Does OpenSCAD have a way to view a cross section of a model? I’m aware of the % (transparent) modifier, but I’m looking for a way to slice through a model on a given plane. > > As I write this, I guess is would be possible to do a difference with a cuboid representing the cut-away part of the plane, but is there a better way? > > > > There is no cross-section view. You can use difference or intersection to > achieve the same effect. > > Caution: in perspective mode, the previewer doesn't like it when the > camera is inside negative space for a difference. This is often a problem > when you're differencing away large cubes to do cut-aways. This program > demonstrates the problem: > > difference() { > sphere(10); > cube(1000); > } > > In perspective mode, rotate the view so that the camera is looking at the > sphere from the positive-XYZ octant; observe that the cut-away portion is > restored. > > I thought there was a similar effect for intersection, but I'm not > duplicating it at the moment. > > > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org >
Tue, Nov 19, 2024 4:12 PM
Indeed, if what you want is a cross-section rather than a cut-away, that
will work.  Loses color, unfortunately.
On 11/19/2024 8:07 AM, Guenther Sohler wrote: > > What about just moving the desired x-section to XY plane and use > > projection(cut=true) on that ? > Indeed, if what you want is a cross-section rather than a cut-away, that will work.  Loses color, unfortunately.
Tue, Nov 19, 2024 5:21 PM
there a better way?
Yeah. That's what I always do.
**  'a' for accelleration.
On Tue, Nov 19, 2024 at 08:56:43AM -0500, Mark Erbaugh via Discuss wrote: > As I write this, I guess is would be possible to do a difference > with a cuboid representing the cut-away part of the plane, but is > there a better way? Yeah. That's what I always do. Roger. -- ** R.E.Wolff@BitWizard.nl ** https://www.BitWizard.nl/ ** +31-15-2049110 ** ** Delftechpark 11 2628 XJ Delft, The Netherlands. KVK: 27239233 ** f equals m times a. When your f is steady, and your m is going down your a** is going up. -- Chris Hadfield about flying up the space shuttle. ** 'a' for accelleration.
BC
Bob Carlson
Fri, Nov 22, 2024 12:04 AM
This is my !start here.scad file. I now start every project with this construction. I can add a cross section in any part of my project in a few seconds. I use my own crossSection() module, but the BOSL2 equivalents could also be used with a little modification. My crossSection code is in my library, but I show it below. The include also includes BOSL2 so a single include from my lib is sufficient for most things. Obviously I add various calls to “assembly" as I build.
include <BClib/common.4.scad>
showX = false;
ex = 0;
doCrossSection = "none"; // ["none", "x", "y", "z", "-x", "-y", "-z", "polar"]
radius = 0;
phi = 0;
theta = 0;
module Customizer_Limit () {}  // This actually works
CS();
module CS() {
if (doCrossSection == "none") {
d = echo("none");
assembly();
} else if (doCrossSection == "polar") {
d = echo("polar");
crossSection(r = radius, theta = theta, phi = phi)
assembly();
} else {
d = echo(doCrossSection);
crossSection(view = doCrossSection, r = radius)
assembly();
module assembly() {
if (showX) {
sphere(50);
From my library:
crossSection(view = "x", r, theta, phi, right, fwd, up)
r    - distance from origin
theta - angle of rotation in XY from +X counter clockwise
phi  - Angle from +Z, 0 == straight up
module crossSection(view = "", right = 0, fwd = 0, up = 0, r = 0, theta = -1000, phi = -1000) {
if (_Help(view)) {
echo("view  - axis to view from, or alternately, to remove");
echo("r    - distance from origin");
echo("theta - angle of rotation in XY from +X counter clockwise");
echo("phi  - Angle from +Z, 0 == straight up");
//d = echo("crossSection ", view, r, theta, phi);
th = theta > -360 && theta < 360 ? theta
  : view == "x" ? 0
  : view == "y" ? 90
  : view == "z" ? 0
  : view == "-x" ? 180
  : view == "-y" ? -90
  : view == "-z" ? 0
  : 0;
ph = phi >= 0 && phi <= 180 ? phi
  : view == "x" ? 90
  : view == "y" ? 90
  : view == "z" ? 0
  : view == "-x" ? 90
  : view == "-y" ? 90
  : view == "-z" ? 180
  : 90;
m = r     != 0 ? r
  : right != 0 ? right
  : fwd   != 0 ? -fwd
  : up    != 0 ? up
  : 0;
//d0 = echo("crossSection ", m, th, ph);
    moveSP(r = m, theta = th, phi = ph)
    zrot(th)
    yrot(ph)
    cube(1000, anchor = BOTTOM);
moveSP(r, theta, phi)
Move Spherical
theta - angle of rotation in XY from +X couter clockwise
module moveSP(r, theta, phi) {
move(spherical_to_xyz(r, theta, phi)) children();
On Nov 19, 2024, at 06:56, Mark Erbaugh via Discuss discuss@lists.openscad.org wrote:
Mark
This is my !start here.scad file. I now start every project with this construction. I can add a cross section in any part of my project in a few seconds. I use my own crossSection() module, but the BOSL2 equivalents could also be used with a little modification. My crossSection code is in my library, but I show it below. The include also includes BOSL2 so a single include from my lib is sufficient for most things. Obviously I add various calls to “assembly" as I build. include <BClib/common.4.scad> showX = false; ex = 0; doCrossSection = "none"; // ["none", "x", "y", "z", "-x", "-y", "-z", "polar"] radius = 0; phi = 0; theta = 0; module __Customizer_Limit__ () {} // This actually works CS(); module CS() { if (doCrossSection == "none") { d = echo("none"); assembly(); } else if (doCrossSection == "polar") { d = echo("polar"); crossSection(r = radius, theta = theta, phi = phi) assembly(); } else { d = echo(doCrossSection); crossSection(view = doCrossSection, r = radius) assembly(); } } module assembly() { if (showX) { sphere(50); } } From my library: /* crossSection(view = "x", r, theta, phi, right, fwd, up) r - distance from origin theta - angle of rotation in XY from +X counter clockwise phi - Angle from +Z, 0 == straight up */ module crossSection(view = "", right = 0, fwd = 0, up = 0, r = 0, theta = -1000, phi = -1000) { if (_Help(view)) { echo("view - axis to view from, or alternately, to remove"); echo("r - distance from origin"); echo("theta - angle of rotation in XY from +X counter clockwise"); echo("phi - Angle from +Z, 0 == straight up"); } //d = echo("crossSection ", view, r, theta, phi); th = theta > -360 && theta < 360 ? theta : view == "x" ? 0 : view == "y" ? 90 : view == "z" ? 0 : view == "-x" ? 180 : view == "-y" ? -90 : view == "-z" ? 0 : 0; ph = phi >= 0 && phi <= 180 ? phi : view == "x" ? 90 : view == "y" ? 90 : view == "z" ? 0 : view == "-x" ? 90 : view == "-y" ? 90 : view == "-z" ? 180 : 90; m = r != 0 ? r : right != 0 ? right : fwd != 0 ? -fwd : up != 0 ? up : 0; //d0 = echo("crossSection ", m, th, ph); difference() { union() { children(); } moveSP(r = m, theta = th, phi = ph) zrot(th) yrot(ph) cube(1000, anchor = BOTTOM); } } /* moveSP(r, theta, phi) Move Spherical r - distance from origin theta - angle of rotation in XY from +X couter clockwise phi - Angle from +Z, 0 == straight up */ module moveSP(r, theta, phi) { move(spherical_to_xyz(r, theta, phi)) children(); } > On Nov 19, 2024, at 06:56, Mark Erbaugh via Discuss <discuss@lists.openscad.org> wrote: > > Does OpenSCAD have a way to view a cross section of a model? I’m aware of the % (transparent) modifier, but I’m looking for a way to slice through a model on a given plane. > > As I write this, I guess is would be possible to do a difference with a cuboid representing the cut-away part of the plane, but is there a better way? > > Mark > _______________________________________________ > OpenSCAD mailing list > To unsubscribe send an email to discuss-leave@lists.openscad.org
