Hi, and thank you already for thinking about helping. I need it!
This is a sculpture by Antoine Pevsner, that I've been trying to recreate.
http://forum.openscad.org/file/n20461/IMG_3113.jpg
A little inspiration (mostly perspiration) got me [x,y,z] coordinates for
the end points of each of the straight lines. So I have an array with all
the coordinates of the endpoints and here's what I've done:
Place spheres at the ends of a line.
Hull() them to make that line.
Place spheres at the ends of the next line.
Hull() them to make that next line.
Put n spheres at regular intervals along each line.
Hull() three at a time to make thick triangular faces to fill in the space
between the skew lines.
Repeat with the second line and the third line.
And so on.
So admittedly it's a ton of lines and hull() ing to do, and I'm not
surprised that it takes a while given my slow computer, but I'm hoping
someone can say something like, "Erik worked on this three years ago, ask
him," or, "try switching this with that or looping this other way." I'm
improving the code kind of steadily, but when I have to wait three hours for
the lowest of the lowest quality renderings, I lose a little steam. When
it's done rendering, I get some steam back because the thing just looks so
cool.
http://forum.openscad.org/file/n20461/pevsner2.jpg
The only other idea I had was to individually crop and individually rotate
individually twisted linearly extruded rectangles, but that math was scary
to me compared to the nice loop I've got I've got below.
I set up the code below to handle two lines and do it with fairly good
looks. If you have a minute to render it and think about how you'd do it
that might be faster or more efficient, I'd truly appreciate any feedback.
It takes about 45 seconds to render on my laptop (Lenovo Thinkpad X201T,
dual i7). It's no speed demon and doesn't have anything really special.
Thanks if you feel like helping! Drew
//beginning of abridged code
module web(p1,p2,p3,p4,slabs){
$fn=8;
hull(){
translate(p1) //places spheres at line
sphere(.2); //ends to be hulled
translate(p2)
sphere(.2);}
hull(){
translate(p3) //places spheres at line
translate(p4)
sphere(.2);}
/* This next loop places smaller spheres at even intervals along each line.
It hulls three spheres (two from one side and one from the other) to create
a triangular face, and then it hulls two from the other side and one from
this side, etc, and works its way up the gap.*/
for (n=[1:1:slabs]){
hull(){
translate([p1[0]+(n-1)(p2[0]-p1[0])/slabs,p1[1]+(n-1)(p2[1]-p1[1])/slabs,p1[2]+(n-1)*(p2[2]-p1[2])/slabs])
sphere(.1);
translate([p3[0]+(n-1)(p4[0]-p3[0])/slabs,p3[1]+(n-1)(p4[1]-p3[1])/slabs,p3[2]+(n-1)*(p4[2]-p3[2])/slabs])
sphere(.1);
translate([p3[0]+n*(p4[0]-p3[0])/slabs,p3[1]+n*(p4[1]-p3[1])/slabs,p3[2]+n*(p4[2]-p3[2])/slabs])
sphere(.1);}
hull(){
sphere(.1);
translate([p1[0]+n*(p2[0]-p1[0])/slabs,p1[1]+n*(p2[1]-p1[1])/slabs,p1[2]+n*(p2[2]-p1[2])/slabs])
sphere(.1);
sphere(.1);}}}
web(p1=[0,0,0],p2=[-2,3,10],p3=[3,3,-5],p4=[12,0,12],slabs=32);
View this message in context: http://forum.openscad.org/alternative-to-hull-tp20461.html
I would follow a very different path: polyhedron. However, it is very hard
to sew all faces of a polyhedron. So I would use something like Parkinbot's
sweep (see http://www.thingiverse.com/thing:900137). You will have to
compute points but the render will be very quick.
Em 16 de fev de 2017 01:35, "dkesler" dkesler@newarka.edu escreveu:
And so on.
for
cool.
$fn=8;
hull(){
translate(p2)
sphere(.2);}
hull(){
translate(p4)
sphere(.2);}
hull(){
sphere(.1);
sphere(.1);
sphere(.1);}
hull(){
sphere(.1);
sphere(.1);
sphere(.1);}}}
Thanks Ronaldo,
I've been working on using polyhedron, but it's taking me a while since two polyhedra can't share an edge! So I'm using all kinds of cross products to push the edges apart.
I looked at sweep. I'll try that if I'm not good enough with the polyhedra math. Rendering sure is fast, though, so thanks a lot!
-Drew
On Feb 15, 2017, at 11:47 PM, Ronaldo [via OpenSCAD] ml-node+s1091067n20462h78@n5.nabble.com wrote:
I would follow a very different path: polyhedron. However, it is very hard to sew all faces of a polyhedron. So I would use something like Parkinbot's sweep (see http://www.thingiverse.com/thing:900137). You will have to compute points but the render will be very quick.
Em 16 de fev de 2017 01:35, "dkesler" <[hidden email]> escreveu:
And so on.
cool.
$fn=8;
hull(){
translate(p2)
sphere(.2);}
hull(){
translate(p4)
sphere(.2);}
hull(){
sphere(.1);
sphere(.1);
sphere(.1);}
hull(){
sphere(.1);
sphere(.1);
sphere(.1);}}}
[hidden email]
[hidden email]
If you reply to this email, your message will be added to the discussion below:
http://forum.openscad.org/alternative-to-hull-tp20461p20462.html
To unsubscribe from alternative to hull?, click here.
NAML
View this message in context: http://forum.openscad.org/alternative-to-hull-tp20461p20470.html
