Re: [OpenSCAD] Openscad commande line
K
kintel
Sat, Jan 23, 2016 5:30 PM
How did you install OpenSCAD? Note that the man page for systems like
MacPorts or Homebrew is linked to the package name, not the executable name.
View this message in context: http://forum.openscad.org/Openscad-commande-line-tp15805p15846.html
How did you install OpenSCAD? Note that the man page for systems like MacPorts or Homebrew is linked to the package name, not the executable name. -- View this message in context: http://forum.openscad.org/Openscad-commande-line-tp15805p15846.html Sent from the OpenSCAD mailing list archive at Nabble.com.
antaur
Sat, Jan 23, 2016 6:01 PM
i have installed openscad first with the sources, got a error in compiling
the sources with (parse error with BOOSTJOIN) so i have install openscad
with dmg file, but i want to use it in command line.
View this message in context: http://forum.openscad.org/Openscad-commande-line-tp15805p15847.html
i have installed openscad first with the sources, got a error in compiling the sources with (parse error with BOOSTJOIN) so i have install openscad with dmg file, but i want to use it in command line. -- View this message in context: http://forum.openscad.org/Openscad-commande-line-tp15805p15847.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Sat, Jan 23, 2016 6:31 PM
In that case, my first suggestion is the correct one.
> On Jan 23, 2016, at 13:01 PM, antaur <antoinekindt@hotmail.com> wrote: > > i have installed openscad first with the sources, got a error in compiling > the sources with (parse error with BOOSTJOIN) so i have install openscad > with dmg file, but i want to use it in command line. > In that case, my first suggestion is the correct one. -Marius
