ClikScad - create OpenSCAD models without all the typing
Fri, Oct 25, 2019 8:06 PM
Yes I appreciate one can use nesting to get around fact you can't get as
much on a screen as with text.
About 20 years ago I wrote a UML case tool that generated entire C++
applications from class diagrams and state charts. It enabled a C
programmer to write C++ without knowing the class syntax as all the code
fragments entered in the GUI were pretty much C but got woven into C++
classes and object could be instantiated with web forms generated from the
class.  All the diagrams were nested so you could drill down and pop up
again.
Now that I am retired I prefer a simpler life and text seems simpler and
quicker to me for OpenSCAD.
On Fri, 25 Oct 2019 at 20:50, Torsten Paul Torsten.Paul@gmx.de wrote:
On 25.10.19 15:50, nop head wrote:
The problem is it is too sparse because typically one
line of code becomes a box. So what happens to a design
that is 350 lines?
Not necessarily. Maybe a more sensible comparison would
be ICEStudio https://github.com/FPGAwars/icestudio which
can create blocks for whole Verilog modules.
Yes I appreciate one can use nesting to get around fact you can't get as much on a screen as with text. About 20 years ago I wrote a UML case tool that generated entire C++ applications from class diagrams and state charts. It enabled a C programmer to write C++ without knowing the class syntax as all the code fragments entered in the GUI were pretty much C but got woven into C++ classes and object could be instantiated with web forms generated from the class. All the diagrams were nested so you could drill down and pop up again. Now that I am retired I prefer a simpler life and text seems simpler and quicker to me for OpenSCAD. On Fri, 25 Oct 2019 at 20:50, Torsten Paul <Torsten.Paul@gmx.de> wrote: > On 25.10.19 15:50, nop head wrote: > > The problem is it is too sparse because typically one > > line of code becomes a box. So what happens to a design > > that is 350 lines? > > Not necessarily. Maybe a more sensible comparison would > be ICEStudio https://github.com/FPGAwars/icestudio which > can create blocks for whole Verilog modules. > > ciao, > Torsten. > > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Robin2
Fri, Oct 25, 2019 9:23 PM
I fully appreciate that and it is no part of my agenda to get you (or anyone
else who likes using text) to change.
But I would be interested to know if you think a simple GUI would be useful
for newbies?
...R
nophead wrote > Now that I am retired I prefer a simpler life and text seems simpler and > quicker to me for OpenSCAD. I fully appreciate that and it is no part of my agenda to get you (or anyone else who likes using text) to change. But I would be interested to know if you think a simple GUI would be useful for newbies? ...R -- Sent from: http://forum.openscad.org/
Fri, Oct 25, 2019 9:52 PM
Very hard for me to judge because I am such a long way from a newbie. I
think I started using OpenSCAD about 9 years ago and probably found it the
easiest language I have learnt, but I spent about 30 years as a
professional programmer and before that and was  making my own computers
and writing my own assemblers and compilers when I was a schoolkid and then
did a degree in computer engineering.
I don't think anybody who is a programmer would struggle to learn it and
they are the people it is aimed at. I can see a GUI could help somebody who
is not a programmer get started but are there many of those that would want
to use OpenSCAD? Why wouldn't they use Fusion360 or FreeCAD if they liked a
GUI based CAD?
I also felt the same about VHDL verses schematic entry for FPGA design. Yes
the schematic can be easier for a hardware designer but it is much quicker
to type HDL and not worry about laying out a schematic.
anyone
for newbies?
...R
Very hard for me to judge because I am such a long way from a newbie. I think I started using OpenSCAD about 9 years ago and probably found it the easiest language I have learnt, but I spent about 30 years as a professional programmer and before that and was making my own computers and writing my own assemblers and compilers when I was a schoolkid and then did a degree in computer engineering. I don't think anybody who is a programmer would struggle to learn it and they are the people it is aimed at. I can see a GUI could help somebody who is not a programmer get started but are there many of those that would want to use OpenSCAD? Why wouldn't they use Fusion360 or FreeCAD if they liked a GUI based CAD? I also felt the same about VHDL verses schematic entry for FPGA design. Yes the schematic can be easier for a hardware designer but it is much quicker to type HDL and not worry about laying out a schematic. On Fri, 25 Oct 2019 at 22:13, Robin2 <robin@nbleopard.com> wrote: > nophead wrote > > Now that I am retired I prefer a simpler life and text seems simpler and > > quicker to me for OpenSCAD. > > I fully appreciate that and it is no part of my agenda to get you (or > anyone > else who likes using text) to change. > > But I would be interested to know if you think a simple GUI would be useful > for newbies? > > ...R > > > > -- > Sent from: http://forum.openscad.org/ > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org >
Fri, Oct 25, 2019 10:18 PM
is aimed at.
But why would we need to put a big restriction on
that and tell everyone who does not want to be a
programmer to find something else?
Modern IDEs for programming languages have lots
of GUI support and that's great. OpenSCAD does
not have much of a GUI, but all those Dialogs are
created with a GUI designer. And in general I
would hate programming C++ via notepad.
I think OpenSCAD will never turn into a point and
click program like FreeCAD. But I don't see why
there should not be additional visualization and
editing possibilities.
OpenSCAD?
Looking at the number of external tools doing
exactly that, I suppose it's not just one or two.
On 25.10.19 23:52, nop head wrote: > I don't think anybody who is a programmer would > struggle to learn it and they are the people it > is aimed at. But why would we need to put a big restriction on that and tell everyone who does not want to be a programmer to find something else? Modern IDEs for programming languages have lots of GUI support and that's great. OpenSCAD does not have much of a GUI, but all those Dialogs are created with a GUI designer. And in general I would hate programming C++ via notepad. I think OpenSCAD will never turn into a point and click program like FreeCAD. But I don't see why there should not be additional visualization and editing possibilities. > somebody who is not a programmer get started but > are there many of those that would want to use > OpenSCAD? Looking at the number of external tools doing exactly that, I suppose it's not just one or two. ciao, Torsten.
Fri, Oct 25, 2019 11:57 PM
useful for newbies?
The existence of BlocksCAD makes it clear that you're not the only one.
I'm entirely serious, though, when I ask:  what do you want that
BlocksCAD doesn't do?
(And sometimes the answer is that you want to reinvent the wheel, just
because you like the exercise.  That's OK, but it's best done as a
conscious decision.)
On 10/25/2019 2:23 PM, Robin2 wrote: > But I would be interested to know if you think a simple GUI would be > useful for newbies? The existence of BlocksCAD makes it clear that you're not the only one. I'm entirely serious, though, when I ask:  what do you want that BlocksCAD doesn't do? (And sometimes the answer is that you *want* to reinvent the wheel, just because you like the exercise.  That's OK, but it's best done as a conscious decision.)
G
gasstationwithoutpumps
Sat, Oct 26, 2019 6:01 AM
who
want
a
GUI based CAD?
That was precisely my question about the original proposal—OpenSCAD is
designed for programmers who can't (or don't want to) draw.  If someone
wants to draw, there are much better systems for their needs.  I have never
found graphical interfaces for programming languages very good for real
programs.  (OK, Scratch was fun for teaching 5th graders to program little
programs, but I wouldn't want to use it for anything big.)
Yes
I don't think that any of the FPGA developers use schematic entry any
more—the FPGAs have gotten too big.  Verilog seems to be the dominant tool,
with a lot of development work into higher-level RTL languages with Verilog
as the output.
gasstationwithoutpumps.wordpress.com
www.thingiverse.com/gasstationwithoutpumps/things
nophead wrote > I don't think anybody who is a programmer would struggle to learn it and > they are the people it is aimed at. I can see a GUI could help somebody > who > is not a programmer get started but are there many of those that would > want > to use OpenSCAD? Why wouldn't they use Fusion360 or FreeCAD if they liked > a > GUI based CAD? That was precisely my question about the original proposal—OpenSCAD is designed for programmers who can't (or don't want to) draw. If someone wants to draw, there are much better systems for their needs. I have never found graphical interfaces for programming languages very good for real programs. (OK, Scratch was fun for teaching 5th graders to program little programs, but I wouldn't want to use it for anything big.) > I also felt the same about VHDL verses schematic entry for FPGA design. > Yes > the schematic can be easier for a hardware designer but it is much quicker > to type HDL and not worry about laying out a schematic. I don't think that any of the FPGA developers use schematic entry any more—the FPGAs have gotten too big. Verilog seems to be the dominant tool, with a lot of development work into higher-level RTL languages with Verilog as the output. ----- gasstationwithoutpumps.wordpress.com www.thingiverse.com/gasstationwithoutpumps/things -- Sent from: http://forum.openscad.org/
Robin2
Sat, Oct 26, 2019 7:17 AM
You are quite correct when you guess that my project started as an "I thnk I
can do that" exercise.
Personally I don't like the Blockscad system (it is the same as MIT
AppInventor) and I'm not sure why. Maybe it is that it is too fussy - the
snazzy graphics are getting in the way.
...R
JordanBrown wrote > I'm entirely serious, though, when I ask:  what do you want that > BlocksCAD doesn't do? You are quite correct when you guess that my project started as an "I thnk I can do that" exercise. Personally I don't like the Blockscad system (it is the same as MIT AppInventor) and I'm not sure why. Maybe it is that it is too fussy - the snazzy graphics are getting in the way. ...R -- Sent from: http://forum.openscad.org/
W
WillAdams
Sun, Oct 27, 2019 1:59 PM
Tried this but got:
This site can’t be reached
localhost refused to connect.
Search Google for localhost 8085
ERR_CONNECTION_REFUSED
Tried this but got: This site can’t be reached localhost refused to connect. Search Google for localhost 8085 ERR_CONNECTION_REFUSED -- Sent from: http://forum.openscad.org/
Robin2
Sun, Oct 27, 2019 2:43 PM
What operating system and browser are you using?
Did you see any message in the Terminal window?
...R
OpenSCAD mailing list-2 wrote > This site can’t be reached > localhost refused to connect. > Search Google for localhost 8085 > ERR_CONNECTION_REFUSED What operating system and browser are you using? Did you see any message in the Terminal window? ...R -- Sent from: http://forum.openscad.org/
W
WillAdams
Sun, Oct 27, 2019 3:10 PM
My apologies.
I am using Windows 10 (build 1703) with Google Chrome
No message or warning from Python (I started it by double-clicking on
clikscad.py since Python isn't in my path).
My apologies. I am using Windows 10 (build 1703) with Google Chrome No message or warning from Python (I started it by double-clicking on clikscad.py since Python isn't in my path). William -- Sent from: http://forum.openscad.org/
