I don't know where I had my mind. Offset would not preclude the difference
to get an outline. Sorry about that.
Em 14 de fev de 2018 5:08 PM, "Ronaldo Persiano" rcmpersiano@gmail.com
escreveu:
I have no way to test your code now but it seems the trouble is the
difference() inside magic_text. If your intention is to have an outline of
the symbol \ue625 it may be simpler to do an offset() of it instead of the
difference().
On Feb 14, 2018, at 2:20 PM, Ronaldo Persiano rcmpersiano@gmail.com wrote:
I don't know where I had my mind. Offset would not preclude the difference to get an outline. Sorry about that.
Otoh, offset may help clean up self-intersections.
This seems to do the trick:
offset(-0.1) text(text = "\ue625”, size = size, halign = "center”, valign = "center”, font="mana:style=Regular");
offset(-1) text(text = "\ue625”, size = size, halign = "center”, valign = "center”, font="mana:style=Regular");
In this case, you could also wrap the text in a module as it’s the exact same symbol instantiated twice.
Another trick:
You can "use <mana.ttf>” directly in the scad file. This allows you to distribute the ttf file with your OpenSCAD file and you won’t have to install the font system-wide.
