Troberg
Sat, Nov 14, 2020 7:35 PM
I have a problem. I have 2D objects, which might be concave, and which has
holes in them. These objects are pretty complex, done in several stages, and
the holes are made in a pretty early part of the process, and the holes may
(or may not) also affect the shape of the outline.
What I want is to get just the outer contour of the object, without the
holes contained fully within, to create masks for other stages in the
production.
If I knew the objects were convex, it wouldn't be a problem, then hull()
would work, but I cannot rely on them to be convex (in fact, they most
certainly aren't).
If the objects were simple, I could do it by union() with some "cover
objects", but they aren't.
If I could do the holes last, it would (partly, but not guaranteed) help,
but I can't as I have other later stages which requires them to be there.
Likewise, bouncing an offset out and back won't work, as it'll affect
corners.
So, any idea on how one could do an outline() module?
production.
certainly aren't).
corners.
WF
William F. Adams
Sat, Nov 14, 2020 7:49 PM
Position the object and then do projection()?
Troberg
Sat, Nov 14, 2020 9:06 PM
Wouldn't projection() just give me the same 2D object as I had, with the same
holes in it?
holes in it?
Sat, Nov 14, 2020 9:14 PM
I don't know if this would be practical for your situation, but BOSL2 has
some functions for doing boolean operations on 2d objects expressed as point
lists. I haven't really experimented with that code much, but I believe if
you were to construct your object with that code the final output would be
the outline you desire plus a list of (entirely internal and disjoint) holes
that need to be subtracted.
Simple example below shows some boolean operations to make a 2d object.
Full 2d object on the left, and then just the outline object on the right.
include<BOSL2/std.scad>
$fn=32;
obj1 = circle(5);
obj2 = apply(move([1,2]), circle(1));
obj3 = apply(move([2.5,-4]), square(3));
obj4 = apply(move([-3,-3.1]), circle(2));
obj5 = apply(move([-2,-2.5]), square(2));
obj = difference([ [obj1],[obj2], [obj3], [obj4], [obj5]]);
region(obj); // Display compound object
right(12)
polygon(obj[0]); // obj[0] is the desired outline
http://forum.openscad.org/file/t2477/geom.png
$fn=32;
obj1 = circle(5);
right(12)
<http://forum.openscad.org/file/t2477/geom.png>
Troberg
Sat, Nov 14, 2020 10:22 PM
point
lists.
Sorry, wouldn't be practical, I use a lot of offsets and stuff to get
rounded shapes, so it would be hard to get a point list.
> point
> lists.
Sat, Nov 14, 2020 10:40 PM
Not sure why this is a problem: an offset() function is available. (There
are also other ways to make rounded shapes that are more direct and more
flexible than offset.)
$fn=32;
obj1 = circle(5);
obj3 = offset(apply(move([2,-4]), square([2,3])), r=.5, closed=true);
obj5 = offset(apply(move([-2,-2.5]), square(2)),r=.5,closed=true);
right(12)
http://forum.openscad.org/file/t2477/geom2.png
point
lists.
$fn=32;
obj1 = circle(5);
right(12)
<http://forum.openscad.org/file/t2477/geom2.png>
>> point
>> lists.
> Discuss@.openscad
S
shadowwynd
Sun, Nov 15, 2020 1:00 AM
Normally, when I have this problem, I open the file in Inkscape, Ctrl+Shift+K
to break paths apart, then just grab the outside shape. But to do this in
OpenSCAD:
Here is a simple proof of concept using offset and no external libraries.
In this case there is an interplay between the $fn and the "interior"
variable; with $fn high (like 200) interior can be between 10 and 20 (on
this example) without the outline of the external shape varying. If $fn was
low... for example $fn=40, then you would start getting artifacts on some of
the outer curves. But this technique works well enough for certain shapes.
$fn=200;
interior = 20;
module shape()
// Make a Complex Shape
square (100);
translate ([50, 50, 0]) circle (10);
translate ([100, 100, 0]) circle (20);
translate ([30, 70, 0]) circle (20, $fn=3);
translate ([0, 0, 0]) circle (40);
translate ([80, -1, ]) square (20);
translate ([80, 80, 0]) circle (5)
translate ([85, 40, 0]) circle (10);
translate ([80,20,0]) circle (20);
//Create the Outline
color ("blue") offset(r=-interior) offset (r=interior) shape();
//Original Shape
color ("yellow") translate ([0, 0, 10]) shape();
OpenSCAD:
$fn=200;
interior = 20;
module shape()
square (100);
//Original Shape
Troberg
Sun, Nov 15, 2020 7:31 AM
(There
Well, it's not just offset(), consider it a big heap of operations, applied
in a specific order. For the purpose of this discussion, the holes may just
as well be random in shape and position.
Also, even if I could duplicate all the functionality of the ordinary
OpenSCAD syntax, I'd prefer not to. It's a huge code library, I don't want
to rewrite it too much, I still want to be able to use all the helper
modules I've written, so I'd prefer to, if at all possible, to work with
OpenSCAD, rather than against it.
> (There
Troberg
Sun, Nov 15, 2020 7:52 AM
Normally, when I have this problem, I export the file as DXF/SVG, open the
OpenSCAD:
was
of
shapes.
$fn=200;
interior = 20;
module shape()
square (100);
// Not perfect - uncomment the line below to break it
//translate ([80, 40,0]) square ([40, 10]);
//Original Shape
Yep, that's about as close as I got to a generic solution, but, in my case,
I have "dents" and holes ranging from 400 mm down to 11 mm, of various
shapes, so it's hard to find a setting which works for all.
> OpenSCAD:
> was
> of
> shapes.
> $fn=200;
> interior = 20;
> module shape()
> difference()
> square (100);
> //Original Shape
arnholm@arnholm.org
Sun, Nov 15, 2020 9:01 AM
has
stages, and
may
production.
> has
> stages, and
> may
> production.
I don't think there is an automatic way to do it in OpenSCAD, but
'fill2d' in AngelCAD does exactly this, it fills the holes in any 2d
shape.
https://arnholm.github.io/angelcad-docs/docs/classfill2d.html
