LenStruttmann
Sat, Apr 17, 2021 2:36 PM
Yet more newbie questions: I'm lovin' OpenSCAD and have progressed from
single parts, through simple assemblies, and now I am attempting a complex
assembly with multiple dependencies and I'm having trouble. So, I'm
stepping back to create an organized structure and a set of best practices.
I develop each part in its own file which contains the part's module,
dimensional constants, and functions for computed values. My top level
assembly file references all of the part files using include statements and
puts it all together.
- My first question is about include statements: How do I conditionally
"include" library files?
Each part and the assembly needs a common library, for example,
metric_screws.scad. As I develop each part, each part file needs to have a
"include <metric_screws.scad>;".
The top level assembly includes metric_screws.scad, which then gets included
again as each part file is included.
So, how do I avoid these multiple includes of the same librry from the
top-level assembly? Or, how do I conditionally execute include statements
in the part files?
- When would you use a "use" statement rather than an "include" statement?
Thanks
1. My first question is about include statements: How do I conditionally
in the part files?
2. When would you use a "use" statement rather than an "include" statement?
Thanks
Sat, Apr 17, 2021 2:46 PM
You can't conditionally include files so I do end up with the same file
included over and over again.
The best I can do is to only put constants I need to make global in my
include files and a use of a second file that has all the functions and
modules. Used files are cached and only parsed once. For example I have a
screws.scad that I include and it uses screw.scad.
included again as each part file is included.
in the part files?
statement?
Thanks
at Nabble.com.
> in the part files?
> statement?
> Thanks
> at Nabble.com.
AC
A. Craig West
Sat, Apr 17, 2021 2:58 PM
I usually split up constants into a screws.h which is included, and modules
in screws.scad which I 'use'
in the part files?
statement?
Thanks
at Nabble.com.
>> in the part files?
>> statement?
>> Thanks
>> at Nabble.com.
LenStruttmann
Sat, Apr 17, 2021 5:31 PM
But, then you are still including screws.h multiple times, right?
I'm kinda surprised that this isn't more of an issue.
Sat, Apr 17, 2021 5:41 PM
You can define the same function or module multiple times. Later definitions
replace earlier ones. So including the same file repeatedly doesn't break
anything. Even definitions of global constants are just replaced if they
happen in include files.
Be aware if you use "use" that any variable assignments at the top level
will be executed any time you call a function in your file, which can result
in huge slow downs if you call functions a lot and have something slow to
compute in those top level assignments.
> discuss-leave@.openscad
LenStruttmann
Sat, Apr 17, 2021 7:32 PM
/You can define the same function or module multiple times. Later
definitions replace earlier ones. So including the same file repeatedly
doesn't break anything. Even definitions of global constants are just
replaced if they happen in include files. /
That's good to know. I still find it odd. If my assembly and my parts all
include:
include <BOSL2/std.scad>;
include <BOSL2/metric_screws.scad>;
... it seems to me that there would be a performance hit to re-read those
files for each part. Then again, after the first file read the OS will have
all (or most) of the file contents cached. I suppose I'm just showing my
age, coming from a programming background where file reads were enormously
expensive. I guess that this behavior is not much different from a C
compiler including .h files.
/Be aware if you use "use" that any variable assignments at the top level
compute in those top level assignments./
Thanks! These are the types of performance hits I'd like to avoid.
include:
Sat, Apr 17, 2021 8:43 PM
To be clear I generally avoid including the same file twice in the same
scope but screws for example are included in most sub assemblies that are
themselves used, so they get included into multiple scopes as each used
file has its own variables.
The fact that variables are evaluated when a module of function in a used
file is called really slows down my builds and I think sets a finite limit
to the complexity of the design. I am struggling with my latest 3D printed.
I don't think I could model a car or an airliner in OpenSCAD. The time to
instantiate the variables would tend towards infinity. It already takes
minutes.
For most of my designs that only have one main file or perhaps two or three
it isn't a problem but when there are 30 files it gets very slow. I think
100 would be impossible, whereas a C++ program with 100 files in it is not
really a problem. There isn't really a limit because compile time is linear
with the number of files, whereas with OpenSCAD it increases exponentially.
On Sat, 17 Apr 2021 at 20:32, LenStruttmann LenStruttmann@gmail.com wrote:
*You can define the same function or module multiple times. Later
replaced if they happen in include files. *
all include:
have all (or most) of the file contents cached. I suppose I'm just showing
my age, coming from a programming background where file reads were
enormously expensive. I guess that this behavior is not much different
from a C compiler including .h files.
result in huge slow downs if you call functions a lot and have something
slow to compute in those top level assignments.
at Nabble.com.
minutes.
> all include:
> *Be aware if you use "use" that any variable assignments at the top level
> slow to compute in those top level assignments.*
> at Nabble.com.
LenStruttmann
Sat, Apr 17, 2021 9:48 PM
So, would a "best practice" be:
(1) Assuming that libraries are well-designed with a minimum number of
instantiated variables,
(2) Part files include any libraries they need, but never instantiate global
variables. Instead, they expose all values only via functions.
(3) The top level assembly only "use"s part files, accessing everything as a
module or a function.
Sat, Apr 17, 2021 9:59 PM
Yes but that would mean wrapping all my objects with functions.
The problem remains with complex machines that their used files need
variables to calculate positions, etc. If you wrap all those expressions in
functions you end up with an exploding tree of function calls.
global variables. Instead, they expose all values only via functions.
a module or a function.
at Nabble.com.
> at Nabble.com.
AC
A. Craig West
Sat, Apr 17, 2021 10:03 PM
In general, in files that I am using, I never define top level variables at
all, which works well with my general aversion to global variables. Pretty
much all variables are declared inside modules, except the $ variables,
which are special. Everything else is passed in as arguments. It seems to
help
as a module or a function.
at Nabble.com.
help
>> at Nabble.com.
