Tue, Jun 27, 2023 9:47 PM
Usually, when I do F5, something happens in the UI to show that the
process has started, even if it takes a few minutes to complete.
When I do F5 with the following code, nothing happens. The cursor does
not change from an arrow to an hourglass. Nothing shows up in the
Console. And this can be quite confusing.
This code completes F5 in about 58 seconds, but the first sign of life
occurs at around 55 seconds.
I installed the latest build of OpenSCAD and BOSL2.
inches = 25.4;
sl = 7 * inches;
sw = 2 * inches;
th = 2;
eps = 0.01;
tex = texture("rough", roughness = 0.5);
linear_sweep(regular_ngon(n=3, d = sw + 2th), h=sl);
translate([0, 0, -eps])
linear_sweep(regular_ngon(n=3, d = sw), texture=tex, h=sl +
2eps, tex_size=[10,10], style="min_edge");
inches = 25.4;
sl = 7 * inches;
sw = 2 * inches;
th = 2;
eps = 0.01;
linear_sweep(regular_ngon(n=3, d = sw + 2*th), h=sl);
2*eps, tex_size=[10,10], style="min_edge");
Tue, Jun 27, 2023 9:52 PM
I get "Loaded design..." when the preview computation starts, and then not
much until it finishes, which is after 10s for me. I think it's pretty
normal that "loaded design" is all I see to indicate a computation has
started.
inches = 25.4;
sl = 7 * inches;
sw = 2 * inches;
th = 2;
eps = 0.01;
started.
> include <BOSL2/std.scad>
> inches = 25.4;
> sl = 7 * inches;
> sw = 2 * inches;
> th = 2;
> eps = 0.01;
> difference() {
Tue, Jun 27, 2023 10:15 PM
Adrian:
I wonder how you can get that to finish in 10 seconds when I am running
on a Windows machine with 4 GHz processors. Puzzling.
I have been developing a 3D design for a few days, and only added the
code snippet when I discovered the "rough" texture (thank you very much,
BOSL2)! I can tell you that my development has slowed down to a crawl.
F5s that took under a second, now take 3-4 minutes. And nothing happens
at all until the last few seconds.
I added a render() just before the difference(), hoping that the
structure might be computed once and not re-calculated each time I hit
F5, but no joy at all.
Any thoughts about how to speed optimize this?
Thanks!
not much until it finishes, which is after 10s for me. I think it's
pretty normal that "loaded design" is all I see to indicate a
computation has started.
does
life
inches = 25.4;
sl = 7 * inches;
sw = 2 * inches;
th = 2;
eps = 0.01;
h=sl +
Adrian:
Thanks!
> does
> life
> inches = 25.4;
> sl = 7 * inches;
> sw = 2 * inches;
> th = 2;
> eps = 0.01;
> difference() {
> h=sl +
Tue, Jun 27, 2023 10:21 PM
BTW, the "Loaded design" message means that the file was loaded. It does
not occur at F5, but before. The first thing that appears on the
Console when you press F5 is "Parsing design (AST generation)"
does
life
inches = 25.4;
sl = 7 * inches;
sw = 2 * inches;
th = 2;
eps = 0.01;
h=sl +
> does
> life
> inches = 25.4;
> sl = 7 * inches;
> sw = 2 * inches;
> th = 2;
> eps = 0.01;
> difference() {
> h=sl +
Wed, Jun 28, 2023 2:02 AM
Something has changed with respect to how stuff is displayed on the
console. The output used to be displayed incrementally, as it happened,
and now it is all displayed on completion.
for (k=[1:10]) {
for (i=[1:1000], j=[1:1000]) {}
echo(k);
On 2021.01, that displays the numbers 1 through 10, about two per
second, for a total of 6 seconds.
On 2023.06.06, it pauses for about 10 seconds and displays all of it,
for a reported total of 10 seconds.
The slowdown is also of interest.
for (k=[1:10]) {
echo(k);
Wed, Jun 28, 2023 2:12 AM
I now have some ... simple? ... code that behaves erratically. I've
tried clearing the cache without making any headway. I am using the
most recent snapshot and BOSL2. At one point I thought it was the
render(), which I removed and achieved success, but the next time it
failed, so that was just random.
Perhaps the rough internal surface is sometimes generated so that the
difference() works and sometimes it fails. I do not know whether the
"rough" texture is computed differently each time, or is static; the
former could explain what I am seeing.
Any other thoughts? I have no idea whether this is reproducible or not
// when I F6 this code, sometimes I get
// - a solid bar with a triangular cross section
// - a hollow bar with a triangular cross section and a "rough" interior
finish
// - the error message "ERROR: The given mesh is not closed! Unable to
convert to CGAL_Nef_Polyhedron."
inches = 25.4;
eps = 0.01;
th = 2;
sl = 7 * inches;
sw = 1.8 * inches;
// render()
linear_sweep(regular_ngon(n=3, d = sw + 4*th), h=sl,
convexity = 10);
translate([0, 0, -1])
// Pick a smooth interior (next line) or a rough interior (line after
that) by commenting one line out
// linear_sweep(regular_ngon(n=3, d = sw),
h=sl + 2, tex_size=[10,10], style="min_edge", convexity = 10);
happened, and now it is all displayed on completion.
for (k=[1:10]) {
echo(k);
finish
inches = 25.4;
eps = 0.01;
th = 2;
sl = 7 * inches;
sw = 1.8 * inches;
// render()
convexity = 10);
> for (k=[1:10]) {
> echo(k);
Wed, Jun 28, 2023 2:20 AM
I don't have anything useful to say about that; it seems like a Revar /
Adrian question.
But it seems separate from the issue where you don't get incremental
output as the program runs.
Adrian question.
Wed, Jun 28, 2023 2:31 AM
On Jun 27, 2023, at 3:15 PM, jon jon@jonbondy.com wrote:
I have been developing a 3D design for a few days, and only added the code snippet when I discovered the "rough" texture (thank you very much, BOSL2)! I can tell you that my development has slowed down to a crawl. F5s that took under a second, now take 3-4 minutes. And nothing happens at all until the last few seconds.
I added a render() just before the difference(), hoping that the structure might be computed once and not re-calculated each time I hit F5, but no joy at all.
Several things of note here.
- You can avoid using textures during preview, if you do something like:
tex = $preview? [[0]] : texture("rough", roughness=0.5);
On my laptop an F-5 of this code takes just 7.7s. Are you running out of memory, maybe?
This code appears to expose a BOSL2 texturing bug where it's using reversed faces. This probably won't work until we can fix this.
1. You can avoid using textures during preview, if you do something like:
2. On my laptop an F-5 of this code takes just 7.7s. Are you running out of memory, maybe?
3. This code appears to expose a BOSL2 texturing bug where it's using reversed faces. This probably won't work until we can fix this.
Wed, Jun 28, 2023 2:35 AM
Actually, even faster texture-less previews can be done with:
tex = $preview? undef : texture("rough", roughness=0.5);
-Revar
-Revar
Wed, Jun 28, 2023 4:15 AM
Texture face reversal bug has just been fixed. Please download the latest BOSL2 code.
- Revar
On Jun 27, 2023, at 7:12 PM, jon jon@jonbondy.com wrote:
I now have some ... simple? ... code that behaves erratically. I've tried clearing the cache without making any headway. I am using the most recent snapshot and BOSL2. At one point I thought it was the render(), which I removed and achieved success, but the next time it failed, so that was just random.
Perhaps the rough internal surface is sometimes generated so that the difference() works and sometimes it fails. I do not know whether the "rough" texture is computed differently each time, or is static; the former could explain what I am seeing.
// - a hollow bar with a triangular cross section and a "rough" interior finish
// - the error message "ERROR: The given mesh is not closed! Unable to convert to CGAL_Nef_Polyhedron."
inches = 25.4;
eps = 0.01;
th = 2;
sl = 7 * inches;
sw = 1.8 * inches;
// render()
linear_sweep(regular_ngon(n=3, d = sw + 4*th), h=sl, convexity = 10);
// Pick a smooth interior (next line) or a rough interior (line after that) by commenting one line out
// linear_sweep(regular_ngon(n=3, d = sw), h=sl + 2, tex_size=[10,10], style="min_edge", convexity = 10);
linear_sweep(regular_ngon(n=3, d = sw), texture=tex, h=sl + 2, tex_size=[10,10], style="min_edge", convexity = 10);
Something has changed with respect to how stuff is displayed on the console. The output used to be displayed incrementally, as it happened, and now it is all displayed on completion.
for (k=[1:10]) {
echo(k);
On 2021.01, that displays the numbers 1 through 10, about two per second, for a total of 6 seconds.
On 2023.06.06, it pauses for about 10 seconds and displays all of it, for a reported total of 10 seconds.
- Revar
> Jon
> inches = 25.4;
> eps = 0.01;
> th = 2;
> sl = 7 * inches;
> sw = 1.8 * inches;
> // render()
> difference() {
>> for (k=[1:10]) {
>> echo(k);
