I'm trying to do some morse code, but I'm struggling to work out the start
position of the 'dit' and the 'dah'... I think first, the code...
id=1;wt=1; // for a ring, don't worry about these
lu = 1; // letter unit. a dit is 1 unit wide, a dah is 3, and the gap
between them is 1.
module drawChar(s) {
echo("char: ", s);
pos = 0;
for(i = [0:len(s)-1]) {
inc = 0;
if(s[i] == ".") {
echo(s[i], "dit ",pos," ", inc);
translate([pos+lu/2,0,0]) cylinder(r=lu/2, h = (id+wt+2)/2);
inc = (1 + 1)lu;
} else if(s[i] == "-") {
echo(s[i], "dah ",pos," ", inc);
translate([pos,-lu/2,0]) cube([3lu,lu,(id+wt+2)/2]);
inc = (3+1)*lu;
pos = pos + inc; // the inc seems to have gone out of scope
drawChar("--.-"); // this is a 'q'
This is the output:
ECHO: "char: ", "--.-"
ECHO: "-", "dah ", 0, " ", 4
ECHO: ".", "dit ", 0, " ", 2
I have tried many ways to calculate 'pos' - the starting point of the
dit/dah. So the bit that's getting me is the way assignments seem to work -
basically pos always stays zero. Also at the point of echoing inc, I'm
expecting it to still be zero.
2 questions I suppose, a learning point for me, what's going on? and second,
how do I make it do what I want it to do?
I was thinking of some way to count the occurances of '.' and '-' in the
array as a function multiplying accordingly, but my brain melted a little -
it is early.
Any help much appreciated
Nigel
View this message in context: http://forum.openscad.org/Incrementing-a-variable-doesn-t-work-as-expected-tp12271.html
For info, here is my recursive position counter that fails:
function cpos(s, n) = cpos(s,n-1) + (n == -1) ? (0) : ( (s[n]==".") ? 2 :
4);
when I use it instead of pos in the x coordinate for example in the dit:
translate([cpos(s,i)+lu/2,0,0]) cylinder(r=lu/2, h = (id+wt+2)/2);
it says recursion detected. It's not lying but the manual says I can do
recursion with the trigraph stuff.
View this message in context: http://forum.openscad.org/Incrementing-a-variable-doesn-t-work-as-expected-tp12271p12272.html
You can't modify variables, so not only is inc out of scope but you can't
change the value of pos.
Recursion is the right way to do it but you have infinite recursion because
you unconditionally call cpos(s,n-1).
4);
Are ypu using a current version of OpenSCAD? The latest?
2015-04-01 9:44 GMT+02:00 nigeljohnson73 nigel@nigeljohnson.net:
4);
schreiben.
Enjoy!
Doh!!! yep.
I moved the conditional calling, but this is still not playing nicely:
function cpos(s, n) = (n == -1) ? (0) : ( cpos(s,n-1) + (s[n]==".") ? 2 : 4
echo ("--.-, 0: ", cpos("--.",0));
echo ("--.-, 1: ", cpos("--.",1));
echo ("--.-, 2: ", cpos("--.",2));
echo ("--.-, 3: ", cpos("--.",3));
ECHO: "--.-, 0: ", 4
ECHO: "--.-, 1: ", 4
ECHO: "--.-, 2: ", 4
ECHO: "--.-, 3: ", 4
I have also noticed a problem in that 0 should be 0 which I'll fix later,
but that aside, I would expect the following
ECHO: "--.-, 1: ", 8
ECHO: "--.-, 2: ", 10
ECHO: "--.-, 3: ", 14
View this message in context: http://forum.openscad.org/Incrementing-a-variable-doesn-t-work-as-expected-tp12271p12275.html
Sorry, yep, I'm using the latest release 2015.03 on both mac and windows
View this message in context: http://forum.openscad.org/Incrementing-a-variable-doesn-t-work-as-expected-tp12271p12276.html
You can not reassign variables. Variables in OpenSCAD are constants.
Please have a look at the manual:
http://en.wikibooks.org/wiki/OpenSCAD_User_Manual/The_OpenSCAD_Language#Variables
2015-04-01 10:50 GMT+02:00 Peter Falke stempeldergeschichte@googlemail.com
4);
schreiben.
Enjoy!
schreiben.
Enjoy!
Yep, I'm now using recursion to bypass that :) but it seems I'm a bit rusty
at that as well.
View this message in context: http://forum.openscad.org/Incrementing-a-variable-doesn-t-work-as-expected-tp12271p12278.html
This is the problem: this is the last definition for pos, so only this one
is used (pos=0 will be ignored).
And it is undefined, as when the left side is assigned the right side has
no meaning,yet. Its a recursion.
2015-04-01 10:54 GMT+02:00 Peter Falke stempeldergeschichte@googlemail.com
2015-04-01 10:50 GMT+02:00 Peter Falke <
stempeldergeschichte@googlemail.com>:
4);
schreiben.
Enjoy!
schreiben.
Enjoy!
schreiben.
Enjoy!
Yeah I'm not doing that any more because it doesn't work. I've moved to
recursion. Possibly an email lag?
This is what is now not working:
cpos("--.-",3) returns 4, instead of 14.
View this message in context: http://forum.openscad.org/Incrementing-a-variable-doesn-t-work-as-expected-tp12271p12280.html
