trouble making a round flange with holes in
Wed, Mar 22, 2017 4:25 PM
Btw, this is a very useful operator, which I use everyday. In my shortcuts
library I implemented it like this:
module rotN(r=10, N=4, offs=0, M=undef) for(i=[0:(M?M-1:N-1)])
rotate([0,0,offs+i*360/N])  translate([r,0,0]) children();
// Examples
color("green") rotN(40,12) cylinder(r=4, h=10);
color("red") rotN(30,12,M=6) cylinder(r=4, h=10);
color("blue") rotN(20,12,120, 6) cylinder(r=4, h=10);
View this message in context: http://forum.openscad.org/trouble-making-a-round-flange-with-holes-in-tp20961p20992.html
Btw, this is a very useful operator, which I use everyday. In my shortcuts library I implemented it like this: > module rotN(r=10, N=4, offs=0, M=undef) for(i=[0:(M?M-1:N-1)]) > rotate([0,0,offs+i*360/N]) translate([r,0,0]) children(); > > // Examples > color("green") rotN(40,12) cylinder(r=4, h=10); > color("red") rotN(30,12,M=6) cylinder(r=4, h=10); > color("blue") rotN(20,12,120, 6) cylinder(r=4, h=10); -- View this message in context: http://forum.openscad.org/trouble-making-a-round-flange-with-holes-in-tp20961p20992.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Mar 22, 2017 5:09 PM
Cool. My version is called rep_rotate(count) shape (rep == repeat).
module rep_rotate(count)
for (i=[0:count-1])
rotate(i*360/count)
color("green")
rep_rotate(12) translate([40,0,0]) cylinder(r=4, h=10);
I'm not saying this is a better interface, I just think it's interesting
that a lot of people have come up with the same abstraction, and I like to
see how other people use OpenSCAD. Now that I've seen these other modules,
I might add a radius to mine.
// Examples
Cool. My version is called `rep_rotate(count) shape` (rep == repeat). module rep_rotate(count) for (i=[0:count-1]) rotate(i*360/count) children(); color("green") rep_rotate(12) translate([40,0,0]) cylinder(r=4, h=10); I'm not saying this is a better interface, I just think it's interesting that a lot of people have come up with the same abstraction, and I like to see how other people use OpenSCAD. Now that I've seen these other modules, I might add a radius to mine. On 22 March 2017 at 12:25, Parkinbot <rudolf@parkinbot.com> wrote: > Btw, this is a very useful operator, which I use everyday. In my shortcuts > library I implemented it like this: > > > > module rotN(r=10, N=4, offs=0, M=undef) for(i=[0:(M?M-1:N-1)]) > > rotate([0,0,offs+i*360/N]) translate([r,0,0]) children(); > > > > // Examples > > color("green") rotN(40,12) cylinder(r=4, h=10); > > color("red") rotN(30,12,M=6) cylinder(r=4, h=10); > > color("blue") rotN(20,12,120, 6) cylinder(r=4, h=10); > > > > > > -- > View this message in context: http://forum.openscad.org/ > trouble-making-a-round-flange-with-holes-in-tp20961p20992.html > Sent from the OpenSCAD mailing list archive at Nabble.com. > > _______________________________________________ > OpenSCAD mailing list > Discuss@lists.openscad.org > http://lists.openscad.org/mailman/listinfo/discuss_lists.openscad.org > > >
Ronaldo
Wed, Mar 22, 2017 7:15 PM
Nice. My trouble with that kind of function and operators is that the more
flexible they are the more parameter names I have to memorize when I need
them. Yes, I always may consult the code but that is their burden.
View this message in context: http://forum.openscad.org/trouble-making-a-round-flange-with-holes-in-tp20961p20994.html
Parkinbot wrote > Btw, this is a very useful operator, which I use everyday. In my shortcuts > library I implemented it like this: Nice. My trouble with that kind of function and operators is that the more flexible they are the more parameter names I have to memorize when I need them. Yes, I always may consult the code but that is their burden. -- View this message in context: http://forum.openscad.org/trouble-making-a-round-flange-with-holes-in-tp20961p20994.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Mar 22, 2017 10:24 PM
That is why I implement a help() module in every library. For shortcuts.scad
you get the output:
ECHO: "
shortcuts.scad
help(): shows this help
help_shortcuts(): shows this help
show_examples(): shows some examples
place_in_rect(): places children objects in grid
Transformations:
transform : T(x=0, y=0, z=0), Tx(x=0) , Ty(y=0), Tz(z=0)
rotate : R(x=0, y=0, z=0), Rx(x=0) , Ry(y=0), Rz(z=0)
scale : S(x=1, y=1, z=1), Sx(x=1) , Sy(y=1), Sz(z=1)
Logical
difference : D()
union : U()
intersection : I()
Useful
N instances around circle : rotN(r=10, N=4, offs=0, M=undef)
range function [0:1:N] : Rg(N)
color : C(r,b,g,t) or C(string,t)
Primitives
circle : Ci(r=10, d=undef)
circle_half : CiH(r=10, w=0, d=undef)
circle_segment : CiS(r=10, w1=0, w2=90, d=undef)
square : Sq(x=10, y=undef, center=true))
cylinder : Cy(r=10, h=1, center=true, r1=undef, r2=undef, d=undef)
cylinder_half : CyH(r=10, w=0, d=undef)
cylinder_segment: CyS(r=10, h=1, w1=0, w2=90,center=true, d=undef)
cylinder_segment: Pie(r=10, h=1, w1=0, w2=90,center=true, d=undef)
cube : Cu(x=10, y=undef, z=undef, center=true)
ring : Ri(R=10, r=5, h=1, center=true, D=undef, d=undef)
ring_half : RiH(R=10, r=5, h=1, w=0 center=true, D=undef, d=undef)
ring_segment : RiS(R=10, r=5, h=1, w1=0, w2=90, center=true, D=undef,
d=undef)
sphere: Sp(r=10))
sphere_half: SpH(r=10, w1 = 0, w2 = 0)
torus: To(torus(R=10, r=1, w1=0, w2=360)
View this message in context: http://forum.openscad.org/trouble-making-a-round-flange-with-holes-in-tp20961p20995.html
Ronaldo wrote > Nice. My trouble with that kind of function and operators is that the more > flexible they are the more parameter names I have to memorize when I need > them. Yes, I always may consult the code but that is their burden. That is why I implement a help() module in every library. For shortcuts.scad you get the output: > ECHO: " * > shortcuts.scad * > help(): shows this help > help_shortcuts(): shows this help > show_examples(): shows some examples > place_in_rect(): places children objects in grid * > Transformations: * > transform : T(x=0, y=0, z=0), Tx(x=0) , Ty(y=0), Tz(z=0) > rotate : R(x=0, y=0, z=0), Rx(x=0) , Ry(y=0), Rz(z=0) > scale : S(x=1, y=1, z=1), Sx(x=1) , Sy(y=1), Sz(z=1) > Logical > difference : D() > union : U() > intersection : I() * > Useful * > N instances around circle : rotN(r=10, N=4, offs=0, M=undef) > range function [0:1:N] : Rg(N) > color : C(r,b,g,t) or C(string,t) * > Primitives * > circle : Ci(r=10, d=undef) > circle_half : CiH(r=10, w=0, d=undef) > circle_segment : CiS(r=10, w1=0, w2=90, d=undef) > square : Sq(x=10, y=undef, center=true)) > cylinder : Cy(r=10, h=1, center=true, r1=undef, r2=undef, d=undef) > cylinder_half : CyH(r=10, w=0, d=undef) > cylinder_segment: CyS(r=10, h=1, w1=0, w2=90,center=true, d=undef) > cylinder_segment: Pie(r=10, h=1, w1=0, w2=90,center=true, d=undef) > cube : Cu(x=10, y=undef, z=undef, center=true) > ring : Ri(R=10, r=5, h=1, center=true, D=undef, d=undef) > ring_half : RiH(R=10, r=5, h=1, w=0 center=true, D=undef, d=undef) > ring_segment : RiS(R=10, r=5, h=1, w1=0, w2=90, center=true, D=undef, > d=undef) > sphere: Sp(r=10)) > sphere_half: SpH(r=10, w1 = 0, w2 = 0) > torus: To(torus(R=10, r=1, w1=0, w2=360) -- View this message in context: http://forum.openscad.org/trouble-making-a-round-flange-with-holes-in-tp20961p20995.html Sent from the OpenSCAD mailing list archive at Nabble.com.
Wed, Mar 22, 2017 11:24 PM
2017-03-22 19:24 GMT-03:00 Parkinbot rudolf@parkinbot.com:
shortcuts.scad
you get the output:
That is a good practice but what do you do when you have several libraries
in <use>, each with its help() ? There is no way to qualify an used
function or module.
2017-03-22 19:24 GMT-03:00 Parkinbot <rudolf@parkinbot.com>: > That is why I implement a help() module in every library. For > shortcuts.scad > you get the output: > That is a good practice but what do you do when you have several libraries in <use>, each with its help() ? There is no way to qualify an used function or module.
Thu, Mar 23, 2017 1:59 AM
in
<use>
function or module.
  1. There is a help_/library/() synonym (another naming convention)
  2. You always can include the library you want to call help() latest (yet
    another hack, I know)
View this message in context: http://forum.openscad.org/trouble-making-a-round-flange-with-holes-in-tp20961p20997.html
Ronaldo wrote > That is a good practice but what do you do when you have several libraries > in > <use> > , each with its help() ? There is no way to qualify an used > function or module. 1. There is a help_/library/() synonym (another naming convention) 2. You always can include the library you want to call help() latest (yet another hack, I know) -- View this message in context: http://forum.openscad.org/trouble-making-a-round-flange-with-holes-in-tp20961p20997.html Sent from the OpenSCAD mailing list archive at Nabble.com.
