Hello,
I am using openscad for a small project and the number of variable is
getting pretty big and my code messier. Some part of my code have "hard
coded" variables and other parts are much more parametric -clean - ie depend
on other variables.
I wish to make the whole code clean and I thought a parser making a
dependency graph for all the variables in my code would allow me to visually
and easily track what is to be changed and remove all parameters that could
be calculated instead of hard-coded.
Altough I could go over each variable one by one I thought it would be
cooler to learn how to automatically generate a graph.
What are you using to achieve that ?
Thank you,
crevettedragon wrote
Hello,
depend
on other variables.
visually
could
Thank you,
Discuss@.openscad
There is nothing built in obviously, I don't use an IDE, perhaps there is
support in some?
