Is it possible to highlight in some way the part of the preview
represented by the editor line that the cursor is on ???
This would certainly help me when I'm modifying someone else's complex
and uncommented design.
Regards,
Dave
Sorry, I should have added that I current use "Color()" but using the
cursor would be much easier/convenient.
Dave
Regards,
Dave
I just put a # in front of the object, which can be quite helpful.
Sent: Wed, Mar 24, 2021 8:24 am
Subject: [OpenSCAD] Re: Enhancement request - Object Highlighting ??
Dave
Regards,
Dave
With Openscad 2021.01 you can right click on a model to find where it is
defined in code, to reverse the creation process.
In the other direction you can use #, % and color( ) to highlight.
Dave
Regards,
Dave
mailto:discuss-leave@lists.openscad.org
! is also useful to show just the line you place it on.
From: Dave softfoot@hotmail.com softfoot@hotmail.com
Dave
Regards,
Dave
!! Well !! I have read the documentation but that just goes to show that my motto should be RTFM ALL OF IT 😂
Many thanks for pointing me at the appropriate sections.
Regards,
Dave
On Wed, 24 Mar 2021 at 21:34, <jw+openscad@stusta.de> wrote:
With Openscad 2021.01 you can right click on a model to find where it is defined in code, to reverse the creation process.
In the other direction you can use #, % and color( ) to highlight.On 24/03/2021 16.03, William F. Adams via Discuss wrote:
To: OpenSCAD general discussion <discuss@lists.openscad.org>
Subject: [OpenSCAD] Re: Enhancement request - Object Highlighting ??Sorry, I should have added that I current use "Color()" but using the
cursor would be much easier/convenient.Dave
> Regards,
> Dave
To unsubscribe send an email to discuss-leave@lists.openscad.org_______________________________________________ OpenSCAD mailing list To unsubscribe send an email to <a href="mailto:discuss-leave@lists.openscad.org" moz-do-not-send="true" target="_blank">discuss-leave@lists.openscad.org</a>_______________________________________________
To unsubscribe send an email to discuss-leave@lists.openscad.org<pre class="moz-quote-pre" wrap="">_______________________________________________ OpenSCAD mailing list To unsubscribe send an email to <a class="moz-txt-link-abbreviated" href="mailto:discuss-leave@lists.openscad.org">discuss-leave@lists.openscad.org</a>
