On 3/22/2023 9:05 AM, Sanjeev Prabhakar wrote:
module rot_ang(p=[])
rotate([0,0,p.z])
rotate([0,p.y,0])
rotate([p.x,0,0])children();
Isn't that exactly the same as rotate() itself?
You are right
rot_ang() does the same work as rotate()
Wrote just for readability
On Wed, 22 Mar, 2023, 10:42 pm Jordan Brown, openscad@jordan.maileater.net
rotate([0,0,p.z])
rotate([0,p.y,0])
Rotate using a vector requires needless brainpower. It’s more verbose but I always use xrot, yrot, and zrot from BOSL2. It’s much more readable. I use up/down, left/right, etc. for the same reason. WIth these, reversing an action is always pretty obvious.
-Bob
Tucson AZ
On Mar 21, 2023, at 14:04, Steve Lelievre steve.lelievre.canada@gmail.com wrote:
Hi everyone,
I have a small problem relating to how to use OpenSCAD to 'unrotate' things. I hope someone here can help me ...
Say I have an object that I have rotated to a new position. I want to get it back to where it started. However, rotating back with a negated version of the first rotation doesn't bring an object back to its original position. The following code sample shows the issue: the red cylinder does not end up superimposed over the green cylinder.
r1 = [30, 40, 50];
r2 = -r1;
color("green") cylinder(h=50);
rotate(r1) color("orange") cylinder(h=50);
rotate(r2) rotate(r1) color("red") cylinder(h=50);
I realize this is because of the way rotation matrices/vectors works but I don't know enough about the algebra to get to the solution for myself. I also understand that I can break the reverse process down into three steps to get the desired result by using rotate([-r1.x,0,0]) rotate([0,-r1.y, 0]) rotate([0,0,-r1.z]) rotate(r1) color("red") cylinder(h=50);
Doing it with three steps is a cumbersome fix, so I want to generate the required r2 directly from r1. How do I do that?
Thanks,
Steve
